15th March 2013, 15:51
The suns coming
Hey Nick
All comes together once you paint it one colour , looks really good. How did the high build cover the imperfections ?
15th March 2013, 15:54
Hi Peeps,
Untill I flat back its hard to say, but the primer does makle you see lots of bits you have missed, and I mean real howlers! When its all colours its hard to see whats what after a while, but then primer gives you an idea of how far you have got. It fills in scratches and pin holes, but anything larger shows up more clearly so you can get it next time. I recommend a coat of primer just to regain ones sanity!!!
How is yrs coming along?
15th March 2013, 16:11
Been away so not much done. i want to get it outside as the dust is killing me. The garage is like ice, dampens the enthusiasm ! think I am going soft !
16th March 2013, 04:54
Originally Posted by seanick
Hi Peeps,
Looks blimn awesum in primer. You can see all the hard word and attention to detail really pays off.
Your customers are lucky to have found you as their pride and joy will be in good hands
20th March 2013, 21:00
There goes my last bit of two pack primer!
poor car!
[IMG] [/IMG]
21st March 2013, 08:01
I can see you were walking the plank...
22nd March 2013, 19:42
Now this is walking the plank! (and its quite a long way down!)
[IMG] [/IMG]
23rd March 2013, 08:31
Alll held together with trigger clamps, what could possibly go wrong...
I now see why you had so many clamps available in that earlier photo you posted.
27th March 2013, 15:09
Nick do you still have those primera vents mate? Cash waiting....
30th March 2013, 13:24
Nick how much clearance do you have from tyre rear arch mate?
14th April 2013, 22:52
Stoneleigh?
Hey Nick,
Only 3 weeks 'til Stoneleigh.....do you think that your masterpiece may make an appearance? (I hope so)
Rich
15th April 2013, 18:35
Hi Hammy, finally pulled up the covers. Tyre to arch clearance is 40mm, although 50 mm on the center. Hope that's enough!
Big Rich, re stonleigh, um, not sure, if yes then it will be in primer!
REALLY busy work wise, held up by the cold weather, so working eves and six days a week :-)
Mind you, bit of room in the shed now this one is in
[IMG] [/IMG]
16th April 2013, 20:18
To do the edges I stripped the foam off where the door seals will grip it to reduce the thickness.
Went around the door shuts and rear window.
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
The louvres will be covered with 5mm tinted perspex, which I have cut out, but not fitted.
[IMG] [/IMG]
[SIZE="3"Finally slotted it all together. Its held up by slotting into the front lip and the sides run above the door shuts so its a good firm fit.
Tomorrow is B day (bonding day)!
][/SIZE]
Nick
Will you be trimming the sides too or painting them mate?
17th April 2013, 16:04
Ply and foam backed black stuff over the top. I think I have done this already. no visible GRP anywhere inside.
17th April 2013, 17:11
Can the foam backed vinyl be stuck onto the grp directly?
17th April 2013, 17:24
It can be, and its what any sane person would do. However, I didn't because............
I wanted an air gap for insulation. Cool in summer, warm in winter.
I wanted to run the wires for interior lights and heated rear window under it.
It avoids possible wrinkles and compound curves on the lining.
Would I do it again? No, I would just stick the lining on !!
I also had to lower the roll bar a bit to make it fit!!
17th April 2013, 17:28
OK, cheers for that, think I will glue the foam backed on.
I can see from the last 16 pages that you don't necessarily follow the easy route!
17th April 2013, 21:22
Cheers Nick I'm just trying to plan my fortnight off to the nth degree mate
18th April 2013, 08:22
Out the shed this morning. Its now back home and under wraps for a few months untill I have time, space and enthusiasm to finish it.
[IMG] [/IMG] [IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
Shut line on the lower bonnet is a bit shit here, please ignore that for now!!
You have done a great Job and your kit looks really nice.
9th June 2013, 22:34
Hi Nick,
Long time no update...... how's it going? Can't wait to see the finished article (if a kitcar is ever finished!)
Rich
