Old 8th August 2009, 20:00
MartinClan's Avatar
I asked Woolies (well I did buy some there 20 years ago when I built my last kit car...) They confirmed that it should be as Peter suggested - concave side towards the material.
Old 14th August 2009, 08:05
MartinClan's Avatar
Well the tonneau fitting is almost complete. (Pictures tomorrow) It's been pretty tricky to fit and in the end I have come to the conclusion that it would have been better to go to a local coachtrimmer and had one made to measure.
The problem is that, as Marlin leave the body fitting to the builder, each car is slightly different. After struggling to get the tonneau to fit satisfactorily (it seemed to fit fine one side but not the other) I carefully eyeballed the rear body section. And - I found that it it is not quite square - only about 6mm out - not enough to even notice - but enough to make fitting the tonneau difficult.
I suspect the problem stems from when I had to remove the plates on which the door catches mount. These are the only thing that locate the rear body so that it is square with the chassis. Of course I fitted the new plates so that they lined up with the doors - not thinking about the consequences of mounting the rear tub. I also suspect that rear tub is also not quite symetrical.
So my advice - if you intend to fit the Marlin tonneau make sure your body is a 100% perfect fit first!
Old 14th August 2009, 21:27
peterux's Avatar
peterux peterux is offline
My hood fitting is not symmetrical either.
With a hood you have the added dimension of the position of the hood sticks.
I couldn't figure out if it was the chassis, bodywork, hood stick mounting, position/angle of the windscreen or the hood?
The good thing about a hood is it's bloody difficult to see both sides at the same time, so its generally only me that can see the diffrence
I am actually quite pleased as it was the first hood I had fitted and I reckon its as good as Marlin's own fitting.
Old 16th August 2009, 09:21
Patrick's Avatar
Patrick Patrick is offline
As you know I don't have a hood but I did try to fit my tub scientifically using a tape measure. I gave up pretty quickly as both the chassis and the tub are not symmetrical, so I would guess that will translate into a wonky hood as well!
