Old 2nd September 2013, 09:11
That looks very neat.
How did you manage the details, like the gearbox to prop shaft/differential connection, electrics/ecu, high pressure fuel system with tank return for the injection etc etc?
Old 2nd September 2013, 18:27
micky1mo's Avatar
micky1mo micky1mo is offline
We firstly had the engine running on the deck, so we sorted out most the details before fitting the engine such as the loom, remote fuel pump ect.
A fuel tank is yet to be "found" and fitted, but looking at a VW beetle tank
Used the gearbox UJ from the BMW fitted the Herald prop shaft via a machined collar, thanks PJO engineering
Still waiting on a replacement oil sump.
The next real problem is the exhaust down pipe as there not a lot of room between the engine and chassis rail, I might have to use flexi pipe
The diff is standard but what else is there ?
The bonnet will end up with a very large "power" bulge
Old 3rd September 2013, 08:22
AndyP57's Avatar
AndyP57 AndyP57 is offline
I know we're a distance away but we've got a beetle tank here you can have ;-)
Old 3rd September 2013, 08:31
micky1mo's Avatar
Hi Andy, thanks for the offer but I have one here, just got to re-plumb it and make it fit
Old 3rd September 2013, 10:08
AndyP57's Avatar
make it fit
Old 3rd September 2013, 14:58
micky1mo's Avatar
Thought the hard works was over but spent most of the day re-mounting the alternator
