Old 23rd February 2018, 08:28
wharfedale wharfedale is offline
wharfedale is on a distinguished road
Default spiy
sorry I got it wrong the herald is 91.5 inch and the spit 82.9, this resulted in my cab been shorter and the difficulty in fitting standard saets,
https://www.dropbox.com/s/5z6onasjhx...%2017.JPG?dl=0
you can just about see thejoint in the bonnet.
Old 25th February 2018, 08:49
http://www.madabout-kitcars.com/foru...ead.php?t=3380
this is the thread showing how the spyder body went on the spit chasis, Is the new alpha spyder for spit or hearald chasis?
Old 25th February 2018, 16:50
Yorkshireman Yorkshireman is offline
Yorkshireman is on a distinguished road
Hello Keith my Alpha body will be fitted to a spitfire mk IV 1500 chassis. I guess if you ask Mike at sammio hq he will be able to confirm what chassis options are available for the Alpha Spyder.
Old 27th February 2018, 07:36
micky1mo's Avatar
micky1mo micky1mo is offline
wharfedale the SAMMIO ALPHA is designed to fit the Triumph Spitfire chassis using most of the original floor-pan and bulkhead so a solid donor is needed.
The original SAMMIO SPYDER is still available and is designed to fit the Truimph Herald chassis using just the original bulkhead.
Both the ALPHA and SPYDER bodies are constructed from a single skin lay-up so can be chopped to fit a lot of different chassis
Old 21st March 2018, 17:40
Well some good news today from Mike. My Alpha body will be ready for Monday 26 march. I now need to get home and get the garage clear, moving the sammio spyder out but that won't be while at least the 4 April and crew change fingers crossed
Old 3rd May 2018, 14:07
Default Delivery of Sammio Alpha
Well 19th April is the day I took delivery of the Sammio Alpha
So with that the build has officially started.
Old 3rd May 2018, 15:52
micky1mo's Avatar
I'm pleased to see you'v got to grips with the photo editing.
Old 5th May 2018, 08:07
Thanks for that Mike, but I am still in the learning process with this photo uplink.
Well due to skill or luck I will try and upload some photos of the Sammio Alphas Doner which members of the household have nicknamed Harry.
Old 5th May 2018, 08:21
So after a first trial fit of the body and photo.
it was time to move Harry to start the stripdown.
Which also required emptying the car of spares and trying to find locker space for them.
Old 6th May 2018, 06:57
Goods like you have got a very tidy Spitfire donor there.
Old 8th May 2018, 11:59
Thanks Paul I spent some time looking for a doner. i wanted to limit the build time and I needed a good base to start with due to the construction. This spitfire ticked all the boxes so I think the extra outlay was worth it.
So these photos that follow are the first fitting of the body to the spitfire tub
As you can see from the photos the body is sitting high at the rear and also at the front so a steady aproach with the grinder removing small amounts untill the body sits correct.
First photos show the top of the dashboard.
Working towards the back of the spitfire this was the next area to be trimmed.
finally the back of the car. There was much more trimming and body trying before I got to this point as my lift assistant for the body pointed out to me.
I Now turned my attention to the fuel tank and repostioned and trimmed away the rear top pannel to give better acess for the boot area.
[url=https://ibb.co/h3DX3n]
more to follow on the build.
Old 8th May 2018, 12:08
So after the first day the photos below show how far I have got.
Iam happy with progress so far and now before the body can be bonded i need to sort out the arrangement for hanging the doors and the hinges.
So car pushed in garage and beer sought to help with thinking process.
Old 8th May 2018, 12:16
Barber's Avatar
Barber Barber is offline
Old 8th May 2018, 18:09
Default looking good
looks so different from the steel subframe build, I will be interested to see how the wheelarches meet the existing steel, are you going on wires, I got my second hand ones powderchromed at cas coatings near you £26 a wheel, cant tel it from chrome and it washes in two minutes. I have a couple of 72 spoke ones spair if you get stuck, keep up with the info, and good luck!
Old 8th May 2018, 18:50
micky1mo's Avatar
Looking good.
Old 9th May 2018, 05:32
I really like the way this kit seems to go together.
As there is a lot to be said for keeping the donor car as intact as possible.
Old 12th May 2018, 18:11
Wharfdale I will take you up on the offer of wheels. As you can see below I have managed to collect a few different styles of wheels over the last year so maybe its a bit early till the cars painted. but I am thinking minilight or 14 mgb wire wheels.
I guess the biggest decider will be when the arches are finished.
Barber Micky1mo Thanks for the reply I welcome your icons of suport
Paul L Yes Paul the build for the main body was much quicker and simpler than the sammio syder. However the next challenge will be the doors and fitting the bonnet.
Old 13th May 2018, 13:19
micky1mo's Avatar
The ALPHA's wheel arch was curved to suit 14" wheels.
This ALPHA is fitted with VW 14" wheels and 185/70/14 tyres
Old 19th May 2018, 06:00
Thanks for the info on wheel size Mike. I will fit the wires on the car to get the wheel archs gap right.
With last trial of the body. it was time to prepare for bonding.
Which means the grinder was out again.
I then prepared the area and cleaned and got all the drills ready, screws and back up drill as the cure time for bonding was only 20 mins.
The time taken was about 1 hour the front panel where the windscreen use to be was the trickest to grind the longest to grind was down the two sills. To grind the lower sill area that meets the lower bulkhead I had to lift and remove the front wheels to gain acess. I consider I was lucky as removing the paint i found good steel. otherwise it could have involved welding in repairs. However removing the paint will require major touching up once bonding and body work is complete.
Old 22nd May 2018, 05:36
Did you get a chance to bond the body shell on?
The very short time from body shell arriving to bonding is amazing.
At this rate, you will have got further in months than I did in years!
