4th October 2013, 21:50
And this
Had to fiberglass in where I had cut the kit to fit the cheap ebay quick fix exahust extention.
Reason: cocked up
4th October 2013, 21:54
Oh,and not happy with the left front so cut it back drilled out some rivets and have now filled it again!
4th October 2013, 22:13
Just needs sanding now.
4th October 2013, 22:15
Looks better without the transverse exhaust box.
5th October 2013, 19:23
Sanded back just needs stopper.
5th October 2013, 19:24
With stopper.
5th October 2013, 19:27
Closer look, needs sanding back.
6th October 2013, 20:04
Sorted.
6th October 2013, 20:07
The other side.
9th October 2013, 19:54
Hi Tony, Do you think you could message / phone me; ref your dateless number plate. i have found some on ebay. Wonder if it's same guy you got yours from ? I am a little concerned about sending original logbook to a stranger on ebay, particularly a "one man band" with lowish feedback.
We met at the Tribute open day earlier this year (I bought Hammy's car).
Your car is Loooooooooking good.
Cheers, Chris
9th October 2013, 21:31
Hi my plate was from John Duncan, the transaction was as smooth as a babys bottom, his number is 0771 5871628, I bought the chepest he had at the time (about a year ago), someone said there are irish plates for a tenner, not sure if this is the same guy but I had no problems. He was from Co. Antrim and I would recomend him. Hope your kit is going well, thanks for the kind words! (rememember meeting you as you had a hat, I got sun burn)
10th October 2013, 08:00
Just checked and he is still on ebay at £20 for UU4xxx plates. Seems to be the cheapest on there.
10th October 2013, 17:01
Went to my local scrap yard today and got some shorter gas struts for the boot, Saab 9000 bonet ones work a treat, also saw a rather sad tired Jag so I bagged the side repeaters as my MOT is looming and I'm not sure if it will pass without as its a 93 car.
12th October 2013, 18:01
More filling and sanding done today, thought I'd post a picture of the boot with the gas struts, old mazda hinges cut reversed and refitted as mounts.
2nd November 2013, 18:27
2nd November 2013, 18:36
2nd November 2013, 18:41
I will not use the F word but my kit did not pass its MOT today, side repeaters now fitted free re test on Monday. (had the lights just in case, taken from a scrap Jag).
3rd November 2013, 08:17
Is that all it failed on?
3rd November 2013, 15:25
No coupleof lamps out due to wiring issue now sorted, and head light adjustment that I will do at the retest on their machine, not bad though.
3rd November 2013, 15:28
Only minor points
