13th September 2015, 06:59
Good Luck Swifty
Everyone says prep is the key and they are right.
Ive sprayed a number of cars now - all outside and I have been happy enough with the results.
As Mr T said I have used etch primer on some but to be honest tack cloths and panel wipe made the biggest difference to my finished job
What colour will the top coat be?
13th September 2015, 17:35
Hope the spraying went well.
I'm looking forward to seeing this in one colour.
13th September 2015, 18:52
Cheers Guys.
Mr T i had intended in using etch primer but after reading the technical sheet for the plastic primer it advised against this so applied the plastic primer straight onto the fiberglass/filler surface.
Jones I've never sprayed a car before so i can't really say if the plastic primer is a wise move, i was advised by a local spray shop to use this first as it is supposed to seal and bond the surface and hopefully prevent future flaking plus give a good key for the primer to stick to.
First the whole of the car was wiped down with panel de-greaser before any spraying commenced, i use two cloths one to apply the de-greaser and the other to wipe over dry. Then wiped the whole car again with a tack cloth but to be honest after seeing the finish of the plastic primer it was probably a wast of a tack cloth.
The plastic primer was then sprayed on using a 1.4 needle, it has the same viscosity as thinners with what looks like very small pieces of metallic flake mixed in.
Picture of the plastic primer applied, it gives a fairly rough satin metallic finish but the spray shop said not to flatten off as this would remove the primer.
Waited one hour then applied the high build primer with a 2.0mm needle, the viscosity of this is very thick to say the least but relatively easy to spray. I found that mixing 300ml at a time took about fiteen minutes to apply and the pot life is about 20 mins, each time i had to do a quick gun clean before mixing another batch, also another point is i removed the small filter fitted internally in the spray gun due to it blocking up the first time i used the high build primer.
Did not get the whole car covered in high build primer as i ran out with a third still to do so will have to buy some more tomorrow, I've used 1 litre so far so think another 2 litres should finish off and allow for a second coat. The second image was a before shot for comparison.
All in all its very satisfying to see the car in one colour and its looks more like a car now. Need to finish off the high build then wait a couple of days before dry sanding back any imperfections as there are a few small pin holes showing through the high build primer.
15th September 2015, 12:57
Very nice indeed.
17th September 2015, 19:35
Finally finished spraying the car with high build primer so maybe this weekend I'll get a guide coat on and the whole of the body rubbed down again to see were the high and low spots are.
The new stainless exhaust parts have arrived, two cherry bombs, 1 into 2 fitting and some 45 degree bends.
Not sure where the exhaust's look better, either center or to the outside.
Placed the cherry bombs roughly in place to see which looks better, once Ive decided then its a case of cutting fittings etc to size, tacking in place under the car and removing to tig weld all the new joints on the bench.
18th September 2015, 08:59
Swifty - As far as the exhaust pipe layout goes...
Central pipes are always a popular option with Sammio builders, as that is how the standard Triumph twin exhaust pipes are supplied.
Obviously that is what I am using, as did Mac.
Although his were hung pretty low, whereas most are "tucked up" in to the body work.
This is Psycho Pops' Sypder and again, I'm doing something similar on mine.
By chance, Micky1Mo posted this photo of his G-46 yesterday with a "wide" pipe set up.
Which I think is just how the original Scimitar pipes were laid out.
Overall, very few people have fabricated their own exhaust system.
When Mister Towed fitted his cherry bomb it was part of his side exit design.
Personally, I think your car is going to look great which ever option you pick.
18th September 2015, 16:24
Looking good Swifty, what was the final colour to be?
18th September 2015, 19:34
Paul Thanks for the pictures, they have been useful.
Scottie Cheers, final colour still on the shelf.
Cut and mocked up the exhaust this afternoon ready to be tig welded.
Parts assembled read for welding. A good trick to mark out the pipe to cut to a straight end is to tighten a jubilee clip around the pipe then draw a line around, you can also leave the jubilee clip on and use as a guide for the hacksaw. I used the jubilee clips to joint the 45 degree angle tube's together after cutting to size, if you are thinking of tig welding pipe then it's wise to have no more than .5mm gap between each pipe end when butted together.
Pipes fitted in place, need to weld a couple of tags onto each silencer and also the boot floor to use a hanging brackets. I decide to go with the center mount which i felt is more of a sporty look and the twin pipes mounted to each side indicates a V engine.
Guide coat applied and you can see some low spots in the first image after a slight rubbing down with 320 paper, to the eye before the high build was applied all looked ok but this has show otherwise. Second image shows a smooth flat wing top.
Well that's it for now and maybe i will have the whole car flattened off this weekend.
20th September 2015, 05:16
Swifty - I hope you get the paint finish all your efforts in prepping the car deserve.
Although I am seriously dreading the effort required to get my car's bodywork into shape for paint.
20th September 2015, 06:35
Theres nothing like cherry bombs this should sound great
20th September 2015, 20:33
Paul The prep work is where the finished result is based on or so i am led to believe and i to hope that it will be worth it.
Roadster I did have a single stainless back box fitted which sounded throaty so i'm looking forward to hearing the cherry bombs.
Well after 12 hrs of rubbing down over the last two days i sickened myself and decided to do something else to relive the boredom.
The bonnet never close flat with the side of the car and after a number of ideas I've ended up fabricating a couple of plates from 3mm ally sheet.
The plates were bent to suit the bonnet inside lines and holes were drilled to give it a key for the bonding paste. First the inner bonnet surface was rough up, then paste applied, then plates pushed onto the paste and held in place with the bonnet closed until dry.
Two layers of fiber glass put over the top and will rub down before applying some body filler to finish off.
The body to plates have about a 3mm gap for the angle plate fitted to the bulk head/wing edge to locate into when the bonnet is closed.
The ally angle line fitted to the bulkhead circled in red.
The edge of the bonnet is now flush with the body were as before it stood about 5mm proud. Two leather straps with buckles will hold the bonnet down securely.
21st September 2015, 14:02
I may well steal your approach to aligning the bonnet when the time comes.
21st September 2015, 16:24
+1
21st September 2015, 20:47
Paul & Oxford Fill your boots guy's, you may even improve on the design, one concern i have is how the bonding between the fiberglass and ally plate will hold up over time.
Finished off the mods to the exhaust today.
Tig welded all the joints, the pipes were held in place in the 1 into 2 section with stainless pop rivets (circled in red in first image) which were fused in once all the joint welding was complete. Also welded a couple of hanging brackets onto the cherry bombs.
Covered all the welds in pickling paste to clean all the crap off which makes the welds look a lot cleaner and shiny.
The 1 into 2 came in two parts and really was for 1 3/4" pipe (the supplier only had these in stock so i took a chance) but as i was using 2" pipe i had to make and weld a couple of joining plates into the sides, the triangle shape section in the red border, the other option was to make reducer's to take the 2" down to 1 3/4", the plate was the easier option with the bonus of less obstruction to the exhaust gases. Thought i would mention this in case anybody else comes across the same problem.
A couple of shots with the exhaust's in place which i am happy with, the mod has also kept the center pipe up inside the chassis rails and the tail pipes as close as is possible to the rear of the underside, may be tomorrow i will fabricate an ally plate to mount on the body above the exhaust tail pipes plus i am thinking of hanging the center pipe from a couple of rubber hangers because at the moment the exhaust has only two mount points, the manifold and cherry bomb hangers.
27th September 2015, 20:18
Its been ten days since the high build primer was put on and at last the whole body has been rubbed down reveling a few low points which will be flashed over again with more high build before i hope the final rub down before the under coat goes on.
A couple of pictures.
A low point in the body, the mottled look is the black guide coat in the low points, the blue gel coat is just starting to show through the high build so i had to stop so as not to break through the plastic primer coating.
Ally trim made and tried for size.
28th September 2015, 08:20
Love the exhaust Swifty!
It should sound marvelous. Keep up the good work.
28th September 2015, 18:26
I am sure your paint finish will reflect all the effort you have put in.
3rd October 2015, 19:28
Cheers Scottie and Paul.
Well one step closer to putting the final colour on the body. Last night i put three coats of primer on ready to flatten off today which ive now completed some 7 hours later. The under coat was applied with a 1.8 needle in the spray gun with a ratio of 20% standard thinners.
The top coat will be thinned with high gloss thinners rather than standard thinners.
Wet flattened with 800 grit paper then cleaned down with clean water and a squeegee ready to rub over with a tack cloth and de-greaser tomorrow before starting to spray with the final colour.
It looks good in one full colour rather than the blue and filler colour of the past months.
Sprayed inside the rear wheel arches and the boot area with grey etch primer ready for a quick coating of the body colour tomorrow to give a uniform look when on the road.
4th October 2015, 06:01
Swifty - Your body shell looks extremely smoooooth.
Looking forward to seeing what top coat colour you have chosen.
4th October 2015, 06:51
Looking very well prepared - lots of great cars on here I hope to see them out and about next year
