5th June 2016, 16:12
High Craig
Don't know if this is too late but have been on holiday for the past week.
The spacers are 12mm thick and I have used pvc plastic for the rings, this bring it just enough to give you the space to get the rings on.
I also had to drill a hole in the bottom of the light bucket on the car to be able to put screw in, as the lights that I have got have got the diamond shape and a P700 badge in them so screw is on bottom of lights as you put them together.
Nick
5th June 2016, 16:47
Hope you had a good holoday Nick. 12mm? That seems a lot. I had thought about having to drill a hole to get the screw in to hold the chrome rings on. Now I know someone else has done I will be doing the same. Cheers for the tips.
10th June 2016, 21:24
Getting ready for the back end to be bonded on over the weekend hopefully. Carpet bonded to parcel-shelf and soundproofing and head liner all bonded in.
11th June 2016, 18:44
Doing the head lining before bonding is such a good move its a pain once the body is on !!!!
11th June 2016, 21:02
Well that was a productive day finally the back end is bonded on with all the head lining in place and just a bit of trimming to finish off. I am glad that I put the head lining in first, can quite imagine it being a nightmare putting it in after you have bonded on.
Also got round to moving the wing mirrors forward which I think look better in that position.
Feel as though I'm getting somewhere now that the car is one piece, and getting to point where it just needs body work doing, now that all the fabrication and problem solving of getting things to work is done.
[img]http://www.madabout-kitcars.com/forum/attachment.php?attachmentid=3669&d=1465678067[i/mg]
12th June 2016, 10:16
Looking really good , did you make your mind up regards the colour ?
12th June 2016, 10:34
Gotta be black
12th June 2016, 12:14
Have got my mate trying to convince me to do gulf racing colours or burnt orange. But I can't make y mind up.
19th June 2016, 19:10
Well first day of many of noting but, arm ache, dust,and more dust.
19th June 2016, 19:18
What rear lights are you using?
19th June 2016, 19:39
Using 90mm round LED with inner one's fog & reverse and outer Light, Break& indicator.
19th June 2016, 20:08
Looking good
25th June 2016, 11:10
Back end nearly filled and shaped, on with the final fit of the front to give my self a break from all the dust.
Reason: add photos
25th June 2016, 11:18
Did try and use photo bucket to post photos but guess I didn’t get it right.
25th June 2016, 11:22
Looking good.....as I am soon doing the rear end on mine.....can I ask, did you sand all the "flashing" flat on the ducktail or build upwards? It might be a but different on mine as its the convertable
25th June 2016, 12:38
I sanded all the flashing back, because didn't want the filler to be any thickness in case it shrank and caused cracks or stars in the paint work latter on.
25th June 2016, 12:57
Looks good not long and you will be ready to take it for a spin.
25th June 2016, 17:23
They are lovely looking cars. I am getting itchy.
26th June 2016, 06:39
Nick - If I click on the attachment "P1100065.jpg" then I can see both the photo and the following "address" at the top of the screen:
http://www.madabout-kitcars.com/foru...4&d=1466853461
If you put [img] in front of that address and then [/img] at the end, the photo will appear in the post.
So the code will look something like this:
[img]http…..0065[/img]
And this will be how it will appear.
So you need the full Photobucket address for each photo, which will be something like http://i1046.photobucket.com/albums/...uteAutomotive/ xxxx.jpg
Hope that helps, Paul.
Your car looks good.
26th June 2016, 11:39
Thanks Paul for the help. Have got it working by adding the code to the photos that I have download to forum can't seem to get it to work from photo bucket.
