26th October 2013, 17:38
Viatron: - Sorry Mac, I was just previewing my post when you posted your links.
27th October 2013, 14:24
The Calm Before The Storm - Part 1:
Thankfully it was dry this morning, although the wind was already blowing quite strongly here.
So I managed to get a few hours in before it was time to batten down the hatches for the approaching storm.
Rather than follow the actual time line, I will group the work together.
Windscreen Support "Holes":
Cutting the windscreen off the body shell obviously left a couple of "wounds".
I had already started cleaning up the metal around these area with the grinder the other day.
So today I applied some "Kurust" to the insides of the holes (as I can't use noisy toys first thing on a Sunday morning).
Notice my high tech way of getting at those hard to reach places...
The other end of this section can be reached from the inside of the bulkhead.
So I will extend the treatment in this area when I turned it "upside down".
Next up was cutting out a couple of metal repair sections to cap these holes.
Although for some reason I don't seem to have taken any photos of them.
When the rust treatment was dry I sprayed some etch primer into the holes.
The masking tape was to keep the metal clean for welding rather than over spray protection.
I am sure the wind did not help my welding attempts, but the repair panels are in.
There are a number of holes blown through the metal that I need to come back to.
Bulkhead Repair / Replacement Panels:
As making cardboard templates doesn't disturb the peace, I looked at other repair panels required.
The first was for the gaping hole in the box section underneath the driver's side of the bulkhead.
While I had the Kurust out, I put some on the inside of this section.
Later when I had cut a large section of metal out, I was able to reach all of the inside.
I think this section of Spitfire sill will be perfect for the job, once I have flattened it out a bit.
At this point I am not sure how far down the repair panel needs to go, so I have included "extra".
The other panel I needed to make was for the cut out behind the brake master cylinder.
This is the cut out on the passenger side (I assume for the USA export market).
And this is roughly where I need to insert a similar cut out on the driver' side.
I did consider "swapping" the cut out panel over, but figured the less holes I made the better.
I found these two sections in my Spitfire scrap yard and think I can make them work.
It didn't take the angle grinder long to cut out these repair panels.
Then it was time to play with my two lump hammers until I had the shapes I wanted.
It was very easy to flatten the sill...
But the cut out section is still a work in progress...
The current plan is to fit these two sections top & bottom by welding the edges to the bulkhead.
I will use the existing bulkhead metal for the sides by carefully cutting the hole and hammering them out.
Depending on the final shape of the pieces above, they will either join up, or need a small section at the back.
Back in a minute with "Part 2"...
27th October 2013, 14:26
The Calm Before The Storm - Part 2:
Box Section Repairs:
When the body shell was cut in two, these joins had come apart, so I cleaned them up.
Then clamped them together.
Before finally welding a large chunk of the join back together.
( I will finish the bit on the left, after I have got the repair panel in on the right. )
I will need to do this on the passenger side as well.
Yesterday's Bulkhead Repairs:
It didn't take long with the grinder to finish tidying up the welds & then I applied some anti-rust treatment.
The next job here will be to add a layer of filler to tidy things up a bit before a quick coat of primer.
Overall, I am pleased with today's progress, although welding thin metal is still a challenge.
Re-Body Inspection Rules:
I've been following Scottie22's A352 build "next door" as it is another Spitfire based kit.
http://www.madabout-kitcars.com/foru...ead.php?t=4553
He had removed the brackets for the original bonnet hinges and bumper mounting.
Chris @ Tribute + Mister Towed confirmed this was OK, which is not how I understood it.
I checked the rules which include the words "the original unaltered chassis".
I will check with the DLVA, but it seems that these brackets are not part of the chassis.
If true, this would be a big help as these brackets are a PITA getting in the way of my bonnet hinges.
What I haven't got my head around is the difference between these brackets and the Herald's rear outriggers.
As traditionally, Spyder builders leave these in place until after the inspection.
So are the Herald outriggers considered to be part of the chassis?
Anyway, I don't need to solve that problem today.
27th October 2013, 15:17
I can't guarantee that the inspector won't say 'Aha!' you've cut off the bonnet brackets, you're going to need to IVA it. Muhaha. Muhahahaha.'
However, it'd take a pretty anally retentive inspector to know what you've cut off so long as you don't tell them. The way I read the 'rules' is that they're intended to stop someone altering the wheelbase or presenting a home made spaceframe as if it's the original chassis.
Keep up the good work and you'll be on the road before you know it.
28th October 2013, 17:50
Mister Towed - Cheers mate.
For now I will resist the temptation to remove the brackets until I've double checked.
But that is one job with the angle grinder that I am really looking forward to.
Twilight:
No, not the teenage vampire/werewolf movies, but the only chance I got to work on the car today.
First job was the clean & clamp the passenger side of the rear chassis mounting bulkhead section.
Then I welded a section of the two sides together (as before the bits either side will be done another day).
By the time I finished welding up the last few holes in the windscreen support "holes" the light was gone.
So I will have to take some photos another day.
My wife took this picture of me cleaning up the welds which gives you some idea...
I really wanted to get some filler over the top of my previous work, but it was not to be.
Recess for brake master cylinder:
Although I have already started work on this, I had a much better idea on how to approach it.
It would be easier to make the whole recess as a single piece & then weld it into the bulkhead.
This gives you a very rough idea of what I now plan to do.
There needs to be a bit of a curve / slope on the top edge to match the bulkhead.
This approach would also allow me to use a single length of metal "top to bottom".
Then I would just need to add the two smaller side sections.
If I just cut out a hole in the bulkhead, I would be able to weld the tabs on 3 sides straight away.
The right hand tab needs some more thought as there is cross brace welded to the bulkhead at this point.
Note:
Not sure I've done a very good job of explaining that, but hopefully it will become clearer.
29th October 2013, 09:43
Flying Visit...
I'm supposed to be doing something else, so I'd better be quick.
This is what the windscreen support "holes" looked like after my grinding in the dark.
To be honest, that will do, as I will be covering the whole repair area in P40 filler.
But first I gave the bare metal a quick wash in Kurust.
Then I mixed up some P40 for the washer/wiper holes and the heater section.
( This will be sanded back a bit before I add paint. )
Last night I turned a cereal box into the outside dimensions of Mr T's micro heater.
( Given the heater's shape, it doesn't take up all of this space. )
I could then use the box to work out where it would fit behind the dash.
This is where the Spitfire heater was fitted and there is plenty of room around here.
Not surprising really given that this is the comparison with the original heater.
Right, got to go, Paul.
30th October 2013, 17:22
A small collection of poor photos:
Another brief session outside at twilight which made limited progress.
I really must get a new camera to document this build as the photos are getting worse.
I got some etch primer on the inside of the box section before I start welding the repair panel over the top.
( I'll also add some waxoil after the welding has been done. )
I hammered the remaining inside edges of the box section together on both sides & welded them up.
I then cut a small metal cap to seal up one of the passenger side "tunnels".
As the wiring will not go through the bulkhead, but along the side of the body work instead.
This cap is not required on the driver's side as that was part of the area I cut out for repair.
I also managed to get some P40 on the windscreen support holes on both sides.
Unfortunately the P40 I applied yesterday was still a little bit tacky.
So I may not have put enough hardened into the mix for the colder weather.
Hopefully it will be hard enough to sand down tomorrow.
30th October 2013, 17:24
Keep plugging away Paul, every job done is one less to do!
Im jealous as i haven't had grease or filler under my nails for a while now :-(
Mac
30th October 2013, 18:03
Get the wife's hair dryer on it that will get it going
31st October 2013, 14:34
Mac - Cheers, there is still a lot of work to be done on the bulkhead.
But I'm enjoying the fact that I can chip away at the jobs and see visible progress.
RedRatBike - Thanks for the tip, although I got away with it this time.
Happy Halloween!
Spend the morning pumpkin carving with my daughters & here are the results...
Bits & Pieces:
Only had the chance to do a few small jobs, but thankfully all the P40 filler has now gone off.
I gave it a very quick rub down and put a coat of etch primer over the top.
Cabbage had achieved a lovely, "GQ Smooth", bulkhead on his build.
Whereas, I have gone for a rough & ready, too many other things to do, finish.
However, whilst the repairs looks rough, they are solid and water tight which is all I really want.
Holes for wiper & screen wash:
Heater section:
Windscreen support - driver's side:
Passenger side:
I also dug the gearbox tunnel cover out as I want to see how that is fitting.
There seems to be excess holes in both the cover and the bulkhead which I will "fill in".
Bulk Head Age:
I came across the VIN plate from the second hand body shell I bought the other day.
I looked up the number on a website and it turns out it is a MkIV, not a 1500 as advertised.
It is also from 1972, which explains the state of it in places, as it is over 40 years old!
31st October 2013, 18:32
Bulk Head Age:
If you can obtain a V5c for that chassis number you will be tax free and can run black and white plates legally!!
Keep up the good work. Nice to see you are making good forward progress.
31st October 2013, 19:23
That one is worth following up, I chose my donar as it was a 1971 Spit, and as froggy says it is tax free,lovely black and silver plates, plus the added bonus of stating " Historic Vehicle" on the free tax disc
all very convincing stuff to a non believer!
31st October 2013, 20:49
Hi Paul,
It is becoming neat. Must be labour intensive work getting it all together like this. The trick is to keep up this kind of attention and not to bent for the urge to get it finished in a hurry.
Regards,
Michiel
1st November 2013, 10:09
Nice work Paul, it may seem like it's taking a long time but once you've finished you'll be able to place a proud hand on it and say I built this.
Couldn't agree more with the comments about using your '72 vin plate. These cars' identity is the vin plate. There's no number stamped into the chassis anywhere, so everything apart from the vin plate is a replaceable component.
You'll need to do some digging with DVLA to make sure that the vehicle isn't still registered to someone else - after all, you can still buy blank vin plates and stamp them up to replace corroded or lost/stolen ones (I've been to a job where the vin plate was stolen from a classic car after they levered the bonnet open) but if it's shown as 'last keeper details only' or some such, you might just be able to register it in your name.
That way you would be able to legally run with black and white/silver number plates and save yourself £125/£235 a year in road tax (dependant on engine size).
Oh, and I raised this point over on the Tribute site, but the current fine for putting black plates on a post '72 car is £100, even if it's parked on your drive.
I got slagged off on the Tribute site by someone who said I didn't know what I was talking about, but believe me, I have white hatted colleagues who wouldn't think twice about slapping you with that fine if they twig you're trying to cheat the system.
Anyway, keep up the good work and I'm looking forward to seeing a Cordite actually on the road.
1st November 2013, 11:56
Oooh the RATS...
1st November 2013, 12:10
Towed - quick question about number plates and what is likely to happen in practise.
If I accidently left some 'show plates' in place over the top of my 'real' number plates and removed the 'show' plates as soon as plod pointed out my mistake, is the nice policeman still likely to slap the fine on me?
I know he can do it but is he likely to bother if the rest of the car is legit and I am poilte to him?
1st November 2013, 13:42
That would very much be down to luck - whether the individual officer recognises the deception, whether they're busy doing something else and don't have time to write the ticket, whether they exercise their discretion etc. - but, as with all Public sector workplaces, successive Governments have driven for 21st century Policing to be 'measurable and accountable'.
I'm all for the accountable bit, I don't believe anybody should be above the law in a democratic society, but measurable inevitably means target driven, and there's nothing more easily measurable than a sheaf of traffic tickets.
All forces are different, but I wouldn't be surprised if you were to drive your car through an area where the roads police officers have a specific number of tickets they need to give out each week to prove that they're out there doing their job, which kind of reduces the individual officer's discretion a bit.
Just to play Devil's advocate though, some forces have trialled a 'zero tolerance' approach to minor breaches of traffic law, giving tickets for everything - blown bulbs, emergency breakaway cable not connected twixt caravan and car, wrong type of number plates fitted etc. - and they've found that overall crime rates have dropped across the board as a result.
The sad truth is that criminals use vehicles to commit crime and the more cars/vans/homages to racing cars on iffy plates that the Police stop the more criminals get caught.
I know you're in a position where you can't really use a classic donor for your build because of the foot thing (don't mention the foot, I mentioned it once but I think I got away with it), and I obviously can't condone you breaking the law by fitting black and white plates to your BMW based Maser, but ultimately it's up to you to decide if it's worth the risk of frequent £100 fines if one of your local traffic cops cottons on to the deception, which they'd be much less likely to do if it had an ageless plate on it
I know what I'd probably do if I was in your position...
1st November 2013, 16:56
Thanks for all the suggestions about re-using the 1972 VIN Plate, I will look into it.
Although I'm sure the guy I bought the body shell from was also selling a rolling chassis.
In fact I'm pretty sure that was the only reason I'd kept the VIN pate in case he needed it.
But there is no harm in checking and a legal way of running black & white plates would be good.
Picking up on Michiel's point about the labour intensive repair works.
I'm actually enjoying bringing the bulk head back to life as I can see the progress I'm making.
There is still a lot of repair work to do, but I did manage to get a bit more done today...
Spitfire Bulkhead Repairs - Continued:
My daughters helped me to raise the Circus Tent in the back garden as the weather was a bit hit & miss.
I positioned it close to the Summer House where all my tool & parts are + power.
Note:
If you look closely at the photo you will see the pile of stuff I had to rake off the "floor" / lawn.
This gave me somewhere to work on the bulkhead in relative calm.
Note: The marks in the primer are where I gave the edges of the P40 an extra rub down this morning.
The first thing I did was put a coat of black paint on the repairs I put primer on the other day.
Although they still need a second coat of paint, I am calling these repairs completed.
Driver's Side - Before & After:
Passenger Side - Before & After:
Wiper & Screen Wash holes: - Before & After:
Heater hole: - Before & After:
Driver's Side Floor Pan Repair:
I cleaned up the repair panel I'd made from an old sill & drilled a few holes in it.
I also cut some more of the floor out to make it easier to make the repair panel fit & cleaned / drilled it too.
Then it was time to clamp it all together and start welding.
I did the welding in two stages as I wanted it firmly fixed before hammering the final section into shape.
Eventually I had the whole thing welded up and it is a solid, if a little ugly, repair.
( Sorry the photos are not great. )
The next stage for this will be to apply the P40 filler, sand, primer & paint.
As this repair will be visible when the car is having an MOT, I will try to get it a bit smoother.
1st November 2013, 18:13
Quite the fabricator developing there mate!
T, with ref to your comment about small triumphs not having chassis plates i beg to differ see below :-)
From all the layers of paint and rust it was under i have no reason to belive it wasnt factory fitted.
2nd November 2013, 11:34
Oops. Never seen one of those before...
