28th November 2011, 19:24
WCA... I thought you had a budget!
Or rather you did have? I don't know about you sobering up, I'm hoping your wife hasn't... What's her Christmas present gonna be? Actually forget that!
28th November 2011, 19:52
Budget blown, Christmas blown, last time I will get blown.
Wife sort of okay with the idea, well she is willing to be in the same room. Lets hope it is okay when the bloke delivers it on Wednesday.
28th November 2011, 20:03
Anyway, its a lovely car
I remember when they were out, when i was a lad... great sound, no need to suup it up! I would say it must be one of the best options to build on, ever. One i will look forward to seeing!
http://garyssammiospyderbuild.blogspot.com/
28th November 2011, 20:18
Congratulations! Now the fun begins.
30th November 2011, 12:27
30th November 2011, 12:30
So according to the e-bay ad, it's got 12 months MOT.
So what i think that most of us want to know is.....
Has it broken down yet?
Only kidding, how does it drive?
30th November 2011, 12:48
Scary fun in the wet. Power slide away from the petrol pump in Sainsbury!
Smells quite rich but that could be fumes coming out of this tube.
30th November 2011, 13:12
Does it sound good!
All looks very nice, almost a shame to cut it up... almost.
30th November 2011, 13:14
I will be leaving it alone for a while. I wasn't planning on starting until the new year anyway and this has already stretched the budget.
I might need some new rear tyres soon. I just got wheelspin parking it in the garage
30th November 2011, 21:04
that open pipe is a breather so you may get some fumes
30th November 2011, 21:38
Roadster is right. It probably was designed to have a positive ventilation valve (PCV) plumbed into it and then hooked up to a vacuum port on the intake. Might want to check to make sure that there isn't a port open which would cause a massive vacuum leak. If this were hooked up in this manner you would not be smelling "fumes".
In any case you won't want to operate the engine with the tubing open. It will allow contaminants to get into the engine. At the very least there should be some type of filter attached.
Just my 2 cents. Nice looking car.
1st December 2011, 09:29
Wow, that's a pretty adventurous donor and a far better choice than the MX5 imho.
Given the power to weight ratio I think you're probably going to get wheel-spin while it's parked in the garage!
I can't wait to see your build progress. Yee-haa!
1st December 2011, 09:33
I am glad to get your approval Mr Towed. I agree about it being 'braver' than the MX5.
I keep flip flopping between a state of extreme happiness and sheer panic.
I think I have traced a possible cause of the rich running. Under the big silver pancake is a choke that appears to be zip ties fully open!
1st December 2011, 09:38
hands off...
You're not meant to be playing with it til' the new year. You'll get caught. Axe and Tookers spring to mind!
1st December 2011, 19:27
WCA if you get wheel spin now - just wait until its a G46
The guys in their moderate powered Spyders all have lively sportscars thanks to their low weight-just ask Pat.
It will be a beast and it might bite.
I look forward to watching yourself and Garry create a unique Sammio
1st December 2011, 20:31
Me too....
Nice one WCA ....looks perfect for cutting up !
I quite fancy a G46 on this setup at some point - time and finances permitting !
I fancy a Rover powered Sammio Spyder as well .....
I think a TVR donor will be a bit special and still SVA EXEMPT !! You gotta love it..
1st December 2011, 20:45
WCA, very ermm! "got a new motor john" just yep thats the jobbie all TVR's where fun now it'll look good as well, PAT
1st December 2011, 20:47
Loving it already. I couldn't find the choke pull in the cabin so I took the air filter off to try and trace it. I found the choke was zip tied open.
There will be progress reports while I play with the TVR on Piston Heads ( http://www.pistonheads.com/gassing/f...=12&mid=208259)
I will start clogging up this forum when I start converting it to a Sammio. Probably in Jan/Feb depending on money.
If I can replace the high pressure EFI pump with one designed to run carbs I might even try a trip to see you Gary. At the moment the engine runs great and there is loads of power but the petrol fumes are a bit rich to drive anywhere for more than five minutes.
7th December 2011, 11:19
Fuel pump replaced.
Fuel Filter replaced.
Extra Fuel filter fitted.
Fuel cut off valve fitted (leaked and then repaired).
Cam vent fumes redirected.
Taxed and Insured.
Time for a reliability run. Southampton to Poole might be nice on a sunny day like today.
I will put my phone on charge and my faith in 25 year old Blackpool engineering
7th December 2011, 11:44
Fuel pump replaced.
Taxed and Insured.
Sounds like a Tower ing achievement. Let's hope the ride isn't rock hard or you might only be able to drive a golden mile without tram lining etc, etc...
