23rd February 2016, 19:57
Bonnet continued
Second coat of gel and a run of roving woven applied
Cut out the glass mat for the rear of the bonnet, laid it on the applied the resin
Left that to set for a few hours, cut out a sheet of mat for the front of the bonnet and applied resin…
Cut out and laid on some edge reinforcement mat and added doublers for the bonnet hinge positions, the latch bracket and the trailing corners
And finally applied resin, now to let that little lot set off nice and hard then onto positioning and bonding on the hinge and latch brackets.
Reason: .
25th February 2016, 17:23
26th February 2016, 16:46
Bonnet continued
Right here goes, went around the edges using a piece of plate and a pair of mole grips to break any over bond…
After a bit of struggling hey presto its out, what a relief, no damage to the bonnet and a small amount to the mould…..
Trial fit of the aperture and its looking good, I now need to clean up the edges until the fit is good then back into the mould to complete the strengthening and final mat later…
26th February 2016, 22:16
Congratulations on a great rescue of that mould, looking good indeed!
27th February 2016, 08:20
Cheers, I just need to get back into it, first a holiday and then off I go again...
27th February 2016, 11:11
Looking good.
What other mods have you planned or is the end in sight?
27th February 2016, 11:59
Originally Posted by Roadster
Looking good.
Thanks, once the bonnet is finished I will be adapting a RX-7 rear spoiler to fit onto the front, upside down, I have shown that idea previously in the thread, I would also like to lower the rear arches as these cars always sat too high from the wheels and I have a Mercedes McLaren air brake I would like to incorporate into the boot lid, I will have to make some actuators for that though, I have loads of ideas but the main thing now after the front spoiler is to get the car on the road and the rest can evolve later. I think my next big headache will be the wiring as I am adapting the Honda loom for the whole of the car, ripping out whats not needed and sorting out the rest.....
27th February 2016, 13:34
Bonnet looks good, well done, perseverance certainly paid off. For that we will give you a few days holiday! Lol.
P.S. Look forward to following you through the other mods planned. Air brake sounds a fun thing.
27th February 2016, 15:10
Thanks, the air brake has similar shape to the lip on the rear of the boot lid so with a little thought blending it shouldn't be too much of a problem, the problem will be with sourcing the actuators and control system, I will put out my tentacles and see what comes back...
28th February 2016, 13:47
Bonnet continued
Lined the mould with cling film and after cleaning the bonnet edge placed it back into the mould for finishing touches.
Doubled up some fibreglass sealing ribbon and bonded it around the bonnet, this will then be soaked in resin and glassed over
Next the final layers of glass mat…
28th February 2016, 16:45
Bonnet continued
Shrunk on some heat shrink over fixings to avoid contamination when applying resin
Applied resin to reinforcing ribbon..
Next to lay up the final layer of mat and seal all the edges with gel coat…
29th February 2016, 13:06
Great idea about the heat shrink - I am guessing not the first time you have done that or is from experience of not covering them before?
It is a really informative build - thanks and keep up the good work!
29th February 2016, 14:01
Must keep ones threads clean or I will have the moderator after me....lol
29th February 2016, 15:46
Thanks for this thread. All of it looks beyond me - but bl@@dy interesting
Good luck
29th February 2016, 16:17
Thanks Dave, he who dares wins so they say, just take it all in small bites and it won't overwhelm you, I am lucky because of my engineering skills and able to use nice machinery and have some really good welders who have helped me when needed, anything you are not sure of google it and have a try or ask on these forums, lots of people are willing to pass on good info....
4th March 2016, 17:50
Pompeyal - Great work on the bonnet.
Does the "roving woven" stuff work in the same way as normal fibreglass matting?
Also your "sealing ribbon" looks like it does a much better job than the string I used.
12th March 2016, 10:40
Hi Paul, sorry I didn't respond earlier just got back from a holiday, yes roving woven works the same, it has the glass as woven threads and has good tear strength, the web I used is made of glass thread again and is normally used a boiler door seals. I just need to get settled back at home then I will finish the bonnet off....
20th March 2016, 16:22
Bonnet continued
Sorry for the delay, had an holiday… back to the bonnet then, cut a piece of glass for the back final skin and applied the resin
Next using the fibreglass ribbon I made up an air dam to stop any water ingress through the scoop to get to the ignition electrics
Once positioned a coating of resin was applied and allowed to set giving support for when the glass mat when applied
Next the mid mat section cut and resin applied
Next allow this lot to set off before the last piece of mat…
21st March 2016, 19:32
21st March 2016, 19:58
The bonnet looks great on this side.
So I really hope it comes out of the mould the way you want it.
