Old 21st April 2009, 15:31
jeremy jeremy is offline
jeremy is on a distinguished road
Default rear ride height
Having done a trial fit of the rear scuttle, I was shocked at the gap between the upper aspect of the rear wheel and the outer lip of the rear wing-I cant remember which springs I have in-but the ride height need to come down maybe 5 or 6 inches.Could any other builders measure their distance from ground to lip of rear wing in a line thru the centre of the wheel.Cheers.
Old 21st April 2009, 18:40
timbo timbo is offline
Hi Jeremy
My bodywork was fitted by Mark, and the distance from the ground to the lower lip of the rear wings is 66.6 cm (This is with 17in wheels and full fuel tank). I've had to chop some bodywork off behind the rear wheels to avoid fouling the spring seats.
Tim
Old 21st April 2009, 21:20
peterux's Avatar
peterux peterux is offline
Hi Jeremy,
mine is 65cm with about a quarter tank of petrol. Also, its an e30 based chassis and e30 supension. 15 inch wheels.
If you used the standard cars springs I think they will need shortening but I used some aftermarket 'lowered' springs.
cheers
Old 22nd April 2009, 13:41
Default springs
Thanks guys-The problem is I want the best of both worlds-the gap between the top of the tyre and the wing lip to be as small as possible,but not have springs to short to fall out at mot/IVA or to stiff to ride in!
Old 22nd April 2009, 15:10
MartinClan's Avatar
Hi Jeremy
Are you E30 or E36 based. I had some springs wound for me (E30) that give a pretty low ride height but keep the bump stops apart and are reasonably comfortable. I still have the details if you would like them.
Kind regards
Old 22nd April 2009, 15:47
Patrick's Avatar
Patrick Patrick is offline
I've used coil overs on the back of mine, I can seem to find a good photo at the moment. I'll measure next time I'm in the garage
Old 22nd April 2009, 20:36
Default springs
Thanks again. Robin,what springs did u you use in the end, and what ride height did it give you?I like the coil over ride height but modification needed makes my heart sink....Patrick has more stamina!!!
Old 22nd April 2009, 20:52
MartinClan's Avatar
I'll have to search for the specs - but they were made specially for me. My car rides at about the same height as Patricks with just me sat in it. (I am about 11 stone) If you go that route I would suggest you had them made perhaps 1/2" longer as I have wound down my spring plates a little.
Old 22nd April 2009, 21:10
Talking springs
Thanks Robin,can you factor in 13 stone...or maybe I shud cut out the kebabs when i am building the car!
Old 22nd April 2009, 21:16
AndyDane AndyDane is offline
I just fitted some aftermarket springs to mine to get it through the MOT - back of the cars shot up an inch or 2 - haven't decided what to do yet as shorter springs feel like they'd "fall out" of the springs seats when the cars up - i.e. when it's being inspected...
Old 23rd April 2009, 12:53
MartinClan's Avatar
I found the place I got them from - it was www.dfaulknersprings.com. I can't find the spec at the moment (must have it somewhere) but I am sure they must have it on record. It was about 2 years ago I had them made. I think they were about £80 the pair. Sounds expensive but I think it was good value as they are made to order.
I don't think a few kebabs (lol) will make any difference when the weight on the rear axle is about 450kgs anyway. But I would probably have them made about 1/2" longer or perhaps 10% stiffer if I were to do it again.
PS - I am running 16" wheels with 205/55 profile tyres
