21st July 2014, 23:03
Can't you just mount a normal light in series but place it inside the body work. This will slow the exterior bulb and give your engine a disco experience whenever you turn a corner?
22nd July 2014, 10:13
Yes I'd considered that as well, but in parallel. I'm not totally happy with the front indicators anyway. They have a nice low profile but don't reflect in the headlights enough. I have obtained some small lenses and some 21w capless bulbs so may end up incandescent rather than led anyway.
24th July 2014, 21:00
Exhausted?
Always wanted to do this:
ever since i had a Lotus Seven S1 with similar. But real.
Should fool the casual observer:
and will all be in matt black of course.
24th July 2014, 21:05
And would be quite easy to double up.
24th July 2014, 21:22
Needs to match the bore on the real pipes. Looks a bit like a hoover adaptor in the smaller size. love the idea though and better than my attempts at fake side pipes
24th July 2014, 21:33
Would have made it larger but used the pipe I had lying about in the garage and didn't want it to be too heavy an ornament either.
24th July 2014, 21:49
Not meant as criticism, perhaps just bigger tubes at the end next to the real pipe?
1st August 2014, 18:04
More Flash
The original front indicators with their bright LED elements were very neat but just didn't seem prominent enough for everyday driving.
So I bought these:
they are incandescent but still low wattage so I've left the ballast resistors in circuit.
For 2014, I see that Bruce has mounted repeaters on the front edge of the wheel arch - could be a home for my now redundant ones.
1st August 2014, 18:05
Did you mention his stripes look wrong?
1st August 2014, 18:07
Not yet- I want some hi-res pics of those Mille Miglia number panels first!!!
10th August 2014, 19:12
2014 Historic Specials day 10 August Burford, Oxon.
Pretty damp down at the Cotswold Wildlife Park today so not a great turnout...
The pics from both the 2012 and 2014 shows are here
13th August 2014, 21:00
Still not heard from the DVLA but the insurance company called today and they are dumping me with 7 days notice- "we don't insure modified cars".
13th August 2014, 21:19
Try Adrian Flux
13th August 2014, 21:34
Or 'A' Plan, they've given me excellent service -
http://www.aplan.co.uk/
14th August 2014, 14:50
A-Plan now have my business as of next Monday.
15th August 2014, 12:22
Amanda Price - we love you
Amanda Price is now on my Christmas card list...
Received today.
15th August 2014, 12:44
And it's now correct on the DVLA Enquiry database:
using
Vehicle Registration Mark
"T210YHO"
Vehicle Make
If the make does not appear in this list, select 'Other' and complete the text box below.
"Other"
...or other make(only if you selected 'Other' above)
"Z300S BARCHETTA"
Reason: additional detail
15th August 2014, 14:41
Wow, so no inspection any more then, just fill in a form?
15th August 2014, 15:43
Yes- just sent in the V5, V627/1, the receipt for the work from Chris and 4 pictures of it (from front with hood up, from front with hood down, from rear with hood down and an under-bonnet shot clearly showing the retained front protection "bumper" and the BMW name on the engine).
TBH, I think the detailed receipt from Chris swung it with wording like "Supply ... kit to fit BMW Z3" and "To fit the above to customer supplied BMW Z3 Reg. No. T210 YHO..."
That made it quite clear that it was only body panels that were involved without modification to chassis, drive train or suspension. My pics were taken with the wire wheels fitted.
15th August 2014, 15:51
Getting mine re-registered again!!!
As it stands, mine is a replica.
Probably of yours Ian :-)
