Old 19th October 2015, 07:59
miilor miilor is offline
miilor is on a distinguished road
Default hola from spain
Hi I'm from Spain, I am determined to build a Renault 4 car kit based, in Spain
is the only thing that I can work (also 2CV, but very little power?,.My
base is a Renault 4 1100cc, but can put a 1400cc 75hp engine, I need to
know if the kit is valid in my case, I guess the tubular structure may not
be used if designed for Triumph but I have no problems with construction a
new frame .
I'm looking at options kit, I tried to contact ribble kits but email is wrong, as I can contact ??
Old 19th October 2015, 13:46
Miilor - Ribble Kits have closed down, even though the "Sammio" website still looks open.
Micky1Mo is the new owner of the Sammio brand and his company is called Replica Rides.
( I believe both the Sammio name and website will be re-used in the future. )
Contact details here:
http://www.replicarides.co.uk/replica-rides-contact.php
There is some information about plans for future kits here:
http://www.madabout-kitcars.com/foru...ead.php?t=5058
But I couldn't tell you if either the old Sammio Spyder kit, or the 2CV version are still available.
Although I do know that the Sammio Cordite / Ribble Navigator is definitely not available.
Sorry if that is a bit vague, but hope it helps.
I don't know much about using a Renault 4 as a base either.
But I do know that you can make some drastic changes to the body work in order to make it fit.
Old 19th October 2015, 18:58
redratbike's Avatar
Someone was on here a while back designing a re panels 4 based kit car but in what syptyle I don't know
Old 19th October 2015, 18:59
redratbike's Avatar
Found it
http://www.madabout-kitcars.com/foru...hlight=Renault
