Originally Posted by jeremy
Back building after long absence.Making dash,and pondering what depth of spacer tubes buiders have uses to drop down the steering wheel and allow maximum dash space above it.What depth have builders cut out of marlin dash to accomodate this?P.S. any templates for dash around-i have 2 large and 5 small smiths tailor made clocks.
Hi Jeremy,
my tubes are about 75mm long and the steering column is mounted upside down (if you get me?)
I made up a hardboard template and kept adjusting it until I was happy with the shape and fit. Then I made stick on dials by print pictures and stuck them on with blue tack until I could see everything from the driving position. I transfered the postions to the carbon fibre/ali panel by drilling small pilot holes through both.
You might spot that the final design was diffrent to these pictures
I hope that helps/
peter
