Old 3rd November 2012, 11:27
6981marlin 6981marlin is offline
6981marlin is on a distinguished road
Default New builder
I am a new (ish) owner of a part built sportster and thought i would post up as i have been lurking for to long. The sportster was bought as a kit in 2005 and has been built up to nearly all the body panels fitted. I have managed to get the car to start, but it will only start and run for a few seconds then cuts out. Can anyone advise me on what is best to start with to fix this problem, it is based on a 325 1987. This may seem a silly question, but i will fire away. How does everyone fit the bumpers, other than welding them in?
Old 3rd November 2012, 13:45
Hello and welcome to the forum.
Your engine starting, running and then cuts out sounds like a fuel supply problem. It may be the filter is blocked up with crap from the fuel tank. Mine did that on it's first run despite flushing the tank.
Depending on the type of filter fitted, you will need to replace it or maybe dismantle it to clean with carb cleaner.
The bumpers are fixed with a bolt through the chassis tube. My front ones use the same bolt to fix the axillary light bracket.
Drivers side bumper by marlinpeter, on Flickr
At the back the bolt is underneath the car.
Good luck fixing your engine running and finishing off the car!
...peter
Old 3rd November 2012, 19:54
Patrick's Avatar
Patrick Patrick is offline
Welcome, I can only echo Peter's comments
Old 3rd November 2012, 22:11
GreatOldOne's Avatar
Ditto here - all I'll add is that you need to fashion your own driving lamp brackets for the front - which share the fixing for the front bumpers.
Also, when drilling for the rear bumpers, it's probably a hell of a lot easier to do if you have a willing helper hold the bumpers level and true whilst you drill up from below.
Old 4th November 2012, 09:33
MartinClan's Avatar
I clamped both of mine to a straight piece of timber running accross the rear of the car ensuring they were both horizontal and in-line. (My willing helper is never very willing lol).
Old 4th November 2012, 22:32
Mike Mike is offline
Good tip: my willing helper lost interest years ago!
Old 3rd March 2013, 15:26
Default Best place for air mass boot
I need to find a new air mass boot, does any one know where best place to get one is? I have had a look on the bay, but could not find any.
It is a 1987 325i
Last edited by 6981marlin; 3rd March 2013 at 15:42.. Reason: not adding the engine model
Old 3rd March 2013, 16:00
Hi there,
The boots are readily available from your local BMW parts desk. According to the BMW parts site:
http://www.realoem.com/bmw/showparts...97&hg=13&fg=15
The part number number is 13711708800
Jason
Old 4th March 2013, 17:27
I've got one like that spare as well, after buying a different boot to fit a replacement idle valve Robin sent me.
