27th April 2012, 10:27
Gary, do you need a hand, "I guess a round of applause is the last thing you need" boom boom Icould blast up the north devon link, Pat
27th April 2012, 11:36
pat i think you should bring skippy up to meet mine sometime anyhow, im still waiting for my new clutch to turn up but thanks anyway
gary
27th April 2012, 17:52
well my new clutch is fitted guys along with new clutch housing and new thrust bearing, engine refitted, just need to refit my rad and fill with water for test....fingers crossed....
27th April 2012, 18:16
cool. you don't mess about!
28th April 2012, 12:49
my problem is still the same guys, biting point in the carpet. master or slave, is the question....i guess my mrs is the master and im her slave...
28th April 2012, 17:56
WAY too much information!
29th April 2012, 10:48
Have you checked the amount of free play in between the slave cylinder and the release arm. If you grab hold of the release arm there should probably only be about a millimetre of movement back and forth. Same thing at the pedal end, and if there's adjustment on the rods, both master cylinder to pedal and slave to release arm (I've not looked that closely at my Vitesse but Jaguars are all adjustable for free play), then taking up excess free play will bring the pedal bite point up. Hydraulic clutch systems are self adjusting and your pedal should stay the same as the clutch wears.
Hope this helps
Hope it makes sense too!
Best of luck
Len.
29th April 2012, 12:12
thanks len
ive removed the slave cylinder there`s no adjustment on the push rod, im going to fit new seals, and then the engineer in me says. Renotch the pinch bolt and see if i can move the slave clyinder forward a small amout. in return will give me a higher up bite on my pedal.
2nd May 2012, 09:07
OK gents, ive re`sealed the slave cylinder and moved it forward 10mm on the pinch bolt, I have a little more movement on my pedal away from the floor before it bites, but its still low to the floor, any IDEAS
2nd May 2012, 11:24
Do you have a lot of pedal travel before the clutch fork starts moving?
Have you tried jamming fork as I previously suggested to make sure hydraulics are OK.
3rd May 2012, 16:41
Has to be a leak at the master cylinder end. Remember these can leak past the piston without losing any fluid, unlike the slave which shows if it leaks.
3rd May 2012, 16:43
A quick test for this which I think should work. Prop the pedal down and leave for a bit. If the pedal is still down but clutch is disengaged it's a leak in the hydraulics.
3rd May 2012, 19:05
Arm
Hi guys, when you bought the car was it a driver. If it had stood, what was the clutch like. I have seen cars that have stood where the release arm has siezed or was at least binding, and when the clutch was operated it actually bent the arm so ultimately you had no "throw" on the clutch. The ford 100e engine in my "another One on the road" thread was just like that. I bought the gearbox seperately and when joined together, I found the clutch had no throw no matter how I adjusted it. As I didn't have another release arm, in true motor trade tradition, I looked at it, studied it, went and made a cup of tea, studied it a bit more, offered it up and followed it's natuaral path of operation and then bashed it with the biggest hammer I could find and it then worked! I have had this on other early Fords and Vauxhalls as well.
Just a thought!!
4th May 2012, 13:04
hi Rocker, i had the release arm out all seems fine to me, there isnt very much movement, and its only a tiny clutch plate, i think i will upgrade my master cylinder tho.. give me bit more push .
4th May 2012, 15:12
what's the condition of the clutch release bearing and does it match the type of clutch? The parts catalogues show different numbers for diaphragm and coil spring clutches - there might be a dimensional difference causing you problems...
Baz from Brussels
