Yes, unless it can't be touched with the tester's 100mm sphere.
If you have Marlin side exhausts, you can point the tips under the car for the test like I did - this takes the edge away from the tester, and has the added benifit of directing the sound away from the SPM on the noise test.
There are other workrounds - you can get slip on collars that attach with a jubilee clip that have rolled edges - I forget who used these to get through. Patrick made up a little bar that projected past the exhast tips.
I'm sure the chaps will chime in with other suggestions.
