22nd August 2015, 17:17
Originally Posted by ericholm
Understood........
DSCN3912 by eric holm, on Flickr DSCN3915 by eric holm, on Flickr DSCN3910 by eric holm, on Flickr DSCN3909 by eric holm, on Flickr DSCN3905 by eric holm, on Flickr DSCN3903 by eric holm, on Flickr DSCN3901 by eric holm, on Flickr DSCN3899 by eric holm, on Flickr DSCN3898 by eric holm, on Flickr DSCN3886 by eric holm, on Flickr DSCN3888 by eric holm, on Flickr
I was looking through your photos and noticed you have used sealant on the fuel filler. I hope this doesn't react like SikaFlex when in contact with petrol. Sikaflex partly dissolves and turns into runny slime and blocks up everything in the fuel system. I found out the hard way on my Robin Hood 7 many years ago. Had to replace the fuel lines , flush out the tank and rebuild the carb , nightmare !
Please check with the sealant manufacturer before its too late!
22nd August 2015, 18:04
22nd August 2015, 19:19
Worried.....
I just copied what Hurnleft did:
For me the tech specs don't really tell me much other than its probably alright...any other views?
Looks like this isn't good enough for areas that touch fuel, however as the aluminum pipe is a push fit and the sealant is around the outside edges, the amount of liquid petrol that touch it will be absolutely minimal if any at all, also the tight fit of the pipe wont allow it to go into the tank either, so looks like it should be ok all things considered, I am sad to hear of the trouble you had, can you (Lucky@Lemans) confirm that the issue you had was where the petrol liquid came in contact with the PU18 or equivalent, or did you just use it to seal the pipes so no gas vapour came out like me.
Thanks.
22nd August 2015, 19:23
Nearly there, just have to remove and reposition some extra parts from front end to get the front section down to correct position.
DSCN4462 by eric holm, on Flickr
DSCN4464 by eric holm, on Flickr
DSCN7654 by eric holm, on Flickr
DSCN4459 by eric holm, on Flickr
22nd August 2015, 20:46
Thanks to all of those following my build, I am trying to put as many pictures up as possible and use Flickr for this it says I have over 1000 photos loaded there. Heres the link again: https://www.flickr.com/photos/134265488@N05
Feel free to comment/ask questions etc. This is my first ever build so happy to hear all thoughts, etc.
111Imag2e1 by eric holm, on Flickr
PS - I have a huge stack of Z3 parts mounting up and will put on ebay at some point, however if you need any let me know!
22nd August 2015, 20:50
Worried.....
Thanks.
On the robin Hood I had to make a seal between the filler neck ( plastic tube) and the rough edge of the stainless fuel tank. I was quite generous when applying the Sikaflex to make a bead about 1/2" thick around the joint. On that tank there were no baffles so the petrol could slop around . I could only assume that is when petrol would come into contact with it. I replaced the Sikaflex with a proper fuel resistant doughnut type O ring seal in the end.
22nd August 2015, 21:31
Phew! thanks for the clarification, looks like I will be ok then, however once again sorry to hear of the trouble you had, must have been a nightmare
23rd August 2015, 07:31
Eric; you grinded off way too much fiberglass of the bonnet mouthopening. I think you will have issues to fit the grill neatly....
23rd August 2015, 13:58
Hi, I haven't grinded a thing off any part of the bonnet, this is how it came, oh dear!
23rd August 2015, 14:07
Eric - I just had a look at Bob/Hurnleft's build and found this photo.
Your bonnet looks very similar and you can see the extra grille surround piece on the floor.
So perhaps mobilerobbie thinks you have ground this piece down, whereas I assume you haven't fitted it yet.
Hope that helps, Paul.
23rd August 2015, 14:12
Yep that could be the reason as I have that part still boxed and can only fit when I know the gap behind the front once I have removed the fan etc.
23rd August 2015, 15:36
My mistake, I have the grille installed alrteady and that is much deeper then the original bonnet opening....
sorry
23rd August 2015, 16:57
sorry
No Worries,,,,,Phew!
23rd August 2015, 17:02
More adjustment to the front end today means that I get get the bonnet all the way down and locked, just some adjustments to do to line it up.
DSCN4519 by eric holm, on Flickr
As always loads more photos on: https://www.flickr.com/photos/134265488@N05
Also went to Newark Autojumble today and got lots more lovely parts for the build, can you believe I bumped in to Hurnleft!
And there was a red tribute MX5 250 GTO there, what were the odds!
23rd August 2015, 17:32
so when are the door skins going on????
23rd August 2015, 17:49
I've lots of electrics and tinkering to do before I get to the doors, also take rear-end off and refit, specifically getting the Fuel cap and filling fitting correct so the body goes flush.....Also not sure how the door skins go on? I know there is lots more fiddling to do with locking systems, so getting a lot more done before attempting that. Will start listing lots of parts on ebay now to clear some space.
23rd August 2015, 18:04
Good to see you today Andy, hope you found some other useful parts as well as the spot lights.
Due to head gasket troubles on my other car, I should be jamming some camping gear into the 250 and going to Ipswich for the Street Rod Nationals this coming Bank holiday weekend. Well worth a day out on the Sunday (public day) with several hundred hot rods, customs, American cars and even a lookalikeish Ferrari!
23rd August 2015, 20:10
Nice to see you too Bob!
Today I bought £185 worth including:
- 2 x Lucas L576 Fog lamps
- 40 x male and 40 female crimp connectors
- 8 x flexible cable clamp/ties
- Spring compressors
- Fine drill bit for detailing
- Stepped hole cutters for drill
- Set of Bullet wing mirrors
- 2 x cans for satin black spray
- Boot latch switch for boot interior light
- 2 x chrome washer jets
- Cig lighter and USB adaptor
- 1 x hotdog and 1 xCheeseburger and a bottle of Sprite
- 2 x Front number plate screws
- Large bag of 4mm long screws and locking nuts
Probably some more things but can't remember
23rd August 2015, 20:34
A proper 2 course meal
23rd August 2015, 20:41
Well it was our Sunday lunch so I had to splash out
