Old 24th March 2012, 11:40
Default Suspension bushes part 2 - How do you get the **** in?
Put the bits together and apply a load of lube and a little pressure
a little more pressure and
Release everything and try again
and then
I am getting a bit sweary. Any suggestions?
Old 24th March 2012, 13:09
The 1958 Rocker The 1958 Rocker is offline
The 1958 Rocker is on a distinguished road
Default Bushes
WCA Don't get sweary, get even! Ha ha. Bit of a fiddle but what I did once was find a piece of tube slightly larger than the bush inside, lube it well put the bush in and then place over the eye in the arm. Then with a tensile bolt or decent studding through the middle and a washer just small enough to pass through the piece of tube and a big washer the other end jus wound it down gently till it went in. Bit of a pain, but thats the sort of issue we have to deal with where I work very regularly because half the Dealer special tools are not far from Heath Robinsons finest,
Good luck Matey
Old 24th March 2012, 17:21
volospian volospian is offline
volospian is on a distinguished road
I put both the bush and the rod (that you need to fit the bush into) into boiling hot water and let it soak for a while, then some lubrication smeared around (soapy water seems ok to me) and all mine have slid in first go.
