Old 14th May 2011, 18:06
morris's Avatar
morris morris is offline
Default poly bushes
Hi all,
I've finally finished stripping and repainting all my E36 rear suspension components and have started on the hunt for replacement bushes. this offer on ebay from a company called strong-flex in poland looks very good. £125 for a complete rear kit excluding the diff cradle mounts which are about another £35 a set
http://cgi.ebay.co.uk/BMW-E36-REAR-S...item414a1f86d0
Does anyone have any experience of these or know of a better option? Powerflex are a lot more expensive and don't cover all the bushes needed. There's another company called flo-flex based in north wales that offer a similar price but again, don't cover all the bushes needed. BMW prices for original rubber parts are way too expensive but there are some good deals out there on after market rubber components
Old 14th May 2011, 19:00
GlenSL GlenSL is offline
GlenSL is on a distinguished road
Sorry Morris, I just replaced the bushes I needed to with aftermarket from local supplier.
Glen
Old 15th May 2011, 11:29
GreatOldOne's Avatar
I have flo-flex bushes in the front suspension, as I had to replace the original rubbers when I sent my wishbones for replacement during the recall.
They seem to be fine - no problems here.
http://www.floflex.co.uk/product_inf...roducts_id=532
They also do a range of generic 'top hat' bushes that may be suitable for the other ones you need...
Old 16th May 2011, 18:27
morris's Avatar
I may go for that flo flex set then as you've had a positive experience and they're still competitively priced. At the moment the top and bottom wishbones still have the original bushes on the diff end so I'll leave them for the mo. It's just the outer top ball joint and outer bottom bush I need then so I can either go for aftermarket rubber or try out these ones from Poland.
I don't think I have a choice on the ball joint
cheers
