14th December 2014, 20:47
Cheers Paul
Finished the pedal box and the floors today then moved onto the rear back panel.
Floors fitted into position pop riveting them together with angle line for strength, only have to finally fasten them to the sub frame i made, they are made from 3mm ally sheet with steel box section in place underneath which i intend to pick up with the seat mount bolts. The pedals now sit at the right height for the floor I've fitted which is higher than if i had used the standard sunken floor panels.
Rear panel cut to size, made a cardboard template first then transferred to the 1mm ally plate, used 1mm as it's very easy to work with and flex into place as i wanted it to be in one piece but to follow the shape of the body. Once i am happy it will be pop riveted in place with polyurethane sealer around the edges. The removable panel will have the edges folded over to add strength as it too is made from 1mm ally sheet.
Looking at various ways to hinge the bonnet and i think i will make a couple of mount brackets out of ally to fasten to the front chassis rail then fabricate a tubular frame to carry the whole bonnet, hopefully the tubular frame will add strength to the flimsy bonnet, i might have this started over the xmas hols.
20th December 2014, 19:19
Made a little more progress today.
Sprayed the back of the seat's rear ally panel with etch primer before fitting to the sub frame also etch the underside of the ally floor panels.
Then made a fan exhaust trim out of 1.5mm stainless steel, first i made a drawing on cardboard then cut it out stuck together with sellotape and folded to shape to make sure it looked ok and transferred the template onto the stainless sheet. Cut it out by hand and tig welded the seams, the sides and end plate are angled slightly out over so the end plate was separate from the main body so more careful tig welding so as to give a smooth edge all the way around. Gave it a brushed finish with 180 grit wet and dry followed by a rub over with a scouring pad, the 60mm id tube was rolled by hand using a piece of 40mm od bar as a former.
The second image shows the fan trim fitted to the single exhaust pipe, i may not use it if i decide to fit twin tail pipes but will wait and see how it looks.
Made two covers out of 1mm ally sheet, the large one goes behind the seats to cover the tank inspection access and the black one is for the back of the boot to cover the suspension access point. The edges have a 25mm fold which stiffens the 1mm ally sheet and also gives a better edge to bolt through.
Well that's it for now see you soon.
21st December 2014, 18:32
The weather was pretty good up here for this time of year so i decided to make a start on cutting the bonnet up, had to push the car outside to be able to see what was required plus cutting outdoors keeps the dust down in the garage.
After looking at what Viatron and Paul have done to their bonnets i followed suit in much the same manner.
Cut the front nose section on the offside and moved the front part forward by 20mm which has brought the nose parallel with the front wheel hubs, i used the wheel hub center for a datum then bridged the gap ready to glass over.
These images show just how much the wheel arches are out in relation the tyres but also the distance between the light housing and the oval grill aperture differs, i've added a couple of red lines to show what i mean.
With this in mind i decided to cut the offside arch off then move the bonnet over to cover the nearside wheel, the extra distance created should make the headlight to oval nearly the same on both sides give or take a couple of mills.
Used a weighted piece of string as a guide to mark the cutting line onto the bonnet.
21st December 2014, 18:39
It looks worse than it is with the wing cut off, its just as well the kit was not an expensive one otherwise i think i would be thinking twice about cutting lumps off.
I screwed the chopped bonnet to the bulk head after cutting the bonnet where it meets the bulk head, by screwing it in place it was easier to re attach the offside wing while balancing the front on a trolley jack.
Wing back on ready to glass over.
Gap glassed over so will leave it a day or two as the temperature is low at the minute so the glass takes that little bit longer to go off.
Fitted a new rubber seal to the original triumph petrol flip cap.
21st December 2014, 19:08
I applaud all of the work that you are doing to do a quality build and correct the body. You'll have a special piece in the end.
21st December 2014, 20:01
Tony
Interesting that you seem to have had to widen your bonnett more than Paul or I have? But by the sae token seeing others follow the same route at least reinforces how much some bits are off! As you say good job it's not an expensive kit! I think it was Paul who said that if Sammio had still been going when he looked closely at his body he probably would have returned it under the sale of goods act!
Keep at it
Mac
21st December 2014, 20:02
Actually..scrub that I've just looked again and it looks about the same
Mac
23rd December 2014, 08:20
Swifty - Great job on the bonnet.
( As it's Christmas, let's just gloss over why such wholesale butchery is required in the first place. )
Looking at your "nose job", I think I might try to copy that approach myself.
What sort of bonnet scoop design are you planning?
24th December 2014, 18:10
JMC14 Thanks for the comment it's now becoming one of those projects that i keep thinking while i am at this stage i'll just do another slight mod to the body which goes on and on especially due to the poor alignment issues.
Paul Thanks, i think the scoop will more than likely be curved to match the body shape but to be honest i may change my mind as time goes by as i make it up as i go along.
Did a little more to the bonnet mods today before the xmas celebrations begin.
A before i start to fill in the gap photo.
Filled in the gap with fiber filler to get a rough shape.
I made a card borad template of the nearside bonnet edge to compare with the off side which is a mile out and decided to cover the area in expanding foam as i did on the rear wing.
You can see in the second photo the difference between the two sides which i felt was unacceptable to leave as is. The gap i felt was a little too large to fill just with fiber filler so i used expanding foam, once the foam goes off i'll shape it then cover with fiber glass matting before finally blending in with body filler to match the nearside.
Fiber filler roughly sanded ready for the body filler to be applied.
24th December 2014, 18:15
Body filler applied and smoothed over ready for the under coat, hopefully in a couple of days the foam will of fully cured so it can shape to match the nearside and blend the whole area in.
Also finished filling and sanding the internal side of the boot lid and gave it a quick coat of under coat, i think you'll agree it now looks better than it did as the rough fiber glass surface.
Well that's it for today and it's time to settle down before the big guy in red arrives tonight.
See you all soon and i hope you all have a good Christmas.
26th December 2014, 09:47
Swifty - Your bonnet is starting to shape up nicely.
Plus your boot lid now looks the part too.
27th December 2014, 17:21
Made a little more progress with the bonnet mods and started the interior side walls while the filler etc was going off.
Started by cutting the foam back with a hacksaw blade to an under size shape to match the opposite side.
Foam shaped and a layer of fiber filler applied to fill any air holes and seal the foam surface before two layers of fiber glass mat was applied for strength, the remnants of the shaved foam are on the floor.
First layer of body filler applied which i will sand back tomorrow. The second image shows just how much the bonnet profile/alignment was out.
I've also noticed that the front valance is not symmetrical so this area may need a little attention but will take a better look tomorrow outside in daylight.
Well that's it for today off out for a few beers now, see you all soon.
29th December 2014, 19:10
The weather out side was -2 today with clear blue sky, i needed to do some welding and cut the bonnet so decided to push the car outside to tackle the jobs while there was no rain or snow and i can say it was brass monkey weather and i don't envy Paul L in any way having to work outside he must have excellent thermals.
Welded the seat belt mounts into position before the ally panel is fitted to the rear of the seat area. Made from 6mm steel plate with a nut welded to the reverse side, the plate was tapped in line with the nut threads for a secure mount.
Finished the front nose alignment but will cut the lower valance once i have the hinge brackets in place to see how much clearance is required to hinge the bonnet up. With this in mind I've now moved onto the sides.
I did have the front balanced on a jack but after a lot of swearing i decided a more secure way would be to screw two bits of wood to the headlight mount area. First i marked the center of each light then positioned the bonnet at the height i think is ok and measured from the floor to each light center datum point to make sure they were equal then screwed the wood in place, hey presto the bonnet now stays in place.
Once the bonnet was position i used a spirit level to mark a line across to the top of the wheel arch and cut the lower arch off. I had the top lip of the bonnet screwed to the bulkhead to prevent it moving.
I am using the fiber glass section cut out to fill the side of the bulkhead, made a small bracket to both strengthen and act as a spacer guide and temporary fitted two ally plates down the outside.
Then back filled the void with expanding foam, once this has cured ill shaped it back and fabricate a 3mm ally plate section for the top surface for the bonnet to drop down onto and to fasten the locator pegs i made some months back.
29th December 2014, 19:18
When viewed from the rear the nearside of the shell curves inwards at the point where the bonnet starts so my intentions are to build this area out over so that it replicates the offside as near as possible plus it will look more stream line.
I've tried to show what i mean with the curved red lines. It's more work but while i am at this stage it is wiser to align the body now.
It now look's like i will have to add another bulge to the bonnet as the front carb dash pot touches the bonnet, it's roughly where the black cross is to the left of the main cut out.
30th December 2014, 08:09
Swifty - I know you are putting in a ton of work to get the bonnet & bodywork right, but it looks like it will be well worth it.
31st December 2014, 09:04
Originally Posted by swifty
Attachment 1858
That opening in the bonnet looks like it will take a Lancia D24 style scoop perfectly -
Put a bulge or small secondary scoop over the dashpot and it'll look convincingly 50's race developed.
31st December 2014, 19:04
Mr T Cheers for the photos, i'm still out on what the finished car will resemble.
Did my last mods on the car for 2014 and worked out side most of the day as the temperature was relatively high and i had a bit of cutting to do.
Hole cut for the carb dash pot to poke through slightly, its not much but i'm trying to make the bonnet line as low as possible at the front nose.
Both side panels are now glassed in to position and bonnet trial fitted to see what it looks like. Side straps will help to pull the bonnet edges in plus i have a couple of locating pegs to fit to aid alignment.
Moved my attention to the front wheel arches which are all over the place so i decided to cut them up and reposition before glassing over.
Used a marker pen taped to a piece of wood rotating from the wheel center point, a bit Heath Robinson but it works.
Off to have something to eat now so will post part two of today's mods.
31st December 2014, 19:45
The front valance was lower on the nearside which looked out of balance so i decided to cut it up and re glass the area to give a more balanced looked.
Made a few cuts through the glass fiber and some cuts not all the way through but just enough to allow the fiber glass to bend, then held together with ally sheet before glassing over the inside.
Next was to remove the front part of the bulk head where the tyre's fowled on full lock. My intentions are to panel this area in ally sheet creating a recess to clear the tyre's. The second photo shows just how close the tyre's are to the chassis.
The seat belt anchor points are finished, i did manage to use the original inside mounting holes so in total i have four mount points per seat.
Well that's is for now and i wish you all a Happy New Year.
1st January 2015, 15:41
Swifty - Wow! You really are flying through the bodywork issues now.
It is great to see how you (& Mac) approach fixing these things, as it gives me lots of ideas.
2nd January 2015, 19:57
Paul Thanks, i am trying to have the car finished this summer if possible so are taking every opportunity i have to work on it.
Finally finished the front nose and valance area mods which have turned out ok.
My next mod is to try to blend the top edge of the bonnet curve to match the bulkhead curve, the reason it doesn't match is because i moved the bulkhead curve in to the center of the car as it was originally over to the nearside which looked out of balance.
This image was taken some months ago when i removed the glass fiber curve before re glassing and blending into the center of the car.
You can see how far the two edges are out with one another, this i think may be a bit of a challenge to complete as there are curves running in two directions on the bonnet in the area that requires re shaping so it may be a bit of a challenge.
The edges of the side panels are beginning to take shape and match up to the bonnet lines, i will be holding the bonnet down on the sides with a couple of leather straps for good measure. Before i finished tonight i gave the two side panels a final covering in fiber filler to level the surface's out before rubbing over and applying a thin layer of body filler tomorrow.
