5th March 2015, 08:57
Thanks Mr T. The old Herald rad is pretty damned good to be honest so I'll give it a try. No doubt more pictures will follow in due course.
ATB
Slarti
7th September 2016, 21:32
It's been a long time .....too long. So many other things that "her indoors" has wanted done. Anyhow....the rad is now installed & throttle cable connected. I've laid some of the wiring back in and hope to be able to at least start the engine (or attempt to !!) within the next few weeks. ....Where have we heard that before.
Goodwood this week-end ...as part of the growing number in The Goodwood Actors Guild....hope to meet um with Mr Towed and have a closer look at his beautiful Sammio.
Let's hope it's not another year before my next post .....retirement is only just around the corner so I'll have bags of time to spend with a spanner in my hand.
Cheerio for now
Slarti
http://s1287.photobucket.com/user/sl...uzofz.jpg.html
8th September 2016, 07:18
Slarti - Good to see you are still chipping away at your Sammio.
If it helps, I was surprised with just how few wires I needed to connect to get my engine running again.
Good Luck, Paul.
Enjoy Goodwood.
12th September 2016, 19:31
Great week-end at Goodwood .....met up with Mr Towed and shared some stories and more tips.
Purchased a new coil, solenoid and voltage controller. Hope to get the engine started in a couple of weeks. .....watch this space
Slarti
25th September 2016, 16:13
After fitting the coil and solenoid ....I have a spark at the points....weak I'll admit ....but a spark none the less. A new condenser will be purchased and ...watch this space ..yet again. A couple of weeks ....I still have to work!!
Slarti
28th September 2016, 06:09
Slarti - Sounds like you are getting closer to the engine firing up.
5th July 2017, 15:54
I can't believe that my last post was back in September !!! Then I was saying that it was only a matter of weeks before I had the engine started! Well now I have finally retired and more time to get on with the job of sorting out the Sammio. Today ...after a bit of tooth sucking I got the engine started and it runs very smoothly. Now I can seriously think about mounting the body and sorting out the steering and dash. Photos to follow ....I promise.
Slarti
5th July 2017, 19:27
Good news on the retirement and the engine start.
I'm looking forward to seeing your build burst back into life.
5th July 2017, 21:47
Welcome back Slarti. Have you retired from acting too?
6th July 2017, 06:45
Certainly not Mr T ! See you at Revival? I'm on duty in the Drivers Club but should get time to meet up if you are going. If you would like b&b facilities at our house do get in touch. Only 30 minutes from Good wood. Best, Slartibartfast 😋 😋
6th July 2017, 12:38
Good to hear that you'll still be Thesping at Goodwood and I'll be there on the Friday and Saturday. What character have you drawn this year?
Thanks for the B&B offer but I booked a hotel room nearby back in January and it's non-refundable.
See you at the revival, which is just two months away now...
9th July 2017, 16:50
I'm in the Drivers Club this year. They are setting up a Henley Regatta scene. I'll be playing a rowing coach of all things. Should be fun ..... looking forward to it. Hope to see you there.
Slarti
17th July 2017, 10:32
Gentlemen !
I'm now doing a bit of a trial fit of the body shell before bonding it to frame. Am I right in thinking that nothing actually lines up perfectly? I'm trying to get a true center line to work from but I'm finding that the cills don't line up too well with the chassis. Is it matter of getting as close as possible and then working round it to line up the bonnet. Any advice great fully received. Perhaps someone can direct me to the relevant part in a build.
On a positive note, the clutch and brake circuits seem to be working ok and I've checked some of the lighting circuits which again seem ok.
Slarti
17th July 2017, 19:24
It's a hard one to explain on here , standing next to the car is the best way to run through it ...but , in summary , yes ...they aren't great in the lining up dept....
I usually start by centreing the rear wheels in the arches and setting the cill and bulkhead height as best you can ...use scissor jacks , stands , blocks or wood , whatever to get the height adjusted and lots of eyeing up as the tape measure will only frighten you ..so do it all by eye initially ...
The bulkhead has a handy lip on the bottom which makes it tricky to get that wrong ..so ..basically , set body at height in the bulkhead area ..centre the rear wheels ..one centre's better than the other ...when you have the first one centred , fix the bulkhead that side with a tech screw or similar ..then pull or adjust the other side to centre it and fix that side down on the bulkhead too ..this temporary fix will get you started .....
The bonnet can have many variables ...again wheel arch alignment is tricky ..but when you are happy with the body position and its fixed nicely ...then the easiest way is to fit the bonnet on the bulkhead line with a few tech screws again and raise and lower the front on a trolley jack until you are happy-ish .....One arch will fit nicely ..the other not so nice ...many people have left it alone , but its a fairly straightforward adjustment , if it bothers you ...
You will need to practice the art of ''some compromise'' and acceptance of symmetrical unimportance !!
Lots of people have done no adjustment ...some a bit ..others a lot .... great looking cars have come from all 3 camps ...
18th July 2017, 07:25
Thanks for that. It all makes sense and VERY helpful. Awaiting stud converters at the moment before fitting the wheels. Pictures to follow .....thanks again for your help & advice
Slarti
4th August 2017, 17:55
Stud converters not yet received ....so I've been working on fitting electric fan to the rad: I purchased some dials from Europa and ordered some Saturn seats. Slowly , slowly but all good fun and good for the blood pressure
Slarti
5th August 2017, 06:36
On the road for the Revival this year then...
5th August 2017, 18:10
.........very funny Mr T.. next year's Revival is my aim.
See you there and get a few more tips.
23rd October 2017, 18:24
https://www.photobox.co.uk/my/album?album_id=5069548768
https://www.photobox.co.uk/my/photo?...d=500212106926
Hi all, I'm back at last.
Been working away slowly. I hope I have attached some links to my update. I now have a working handbrake after a small engineering works helped out with the mounting bracket. I've put in some rubber matting rather than carpet just in case I'm caught out in the rain. A trial fit of seats and a mock-up dashboard before I start work on bonding the body to the frame.
More updates to follow.
All the best to Mr Towed on his new project ...
Slarti
23rd October 2017, 18:29
