Old 7th July 2008, 11:39
AutoCustomEng AutoCustomEng is offline
Kit Car Dreamer
AutoCustomEng is on a distinguished road
Default Kit Car Parts
Hi All,
Hope the builds and kit cars are running well and progress is good,
we would like to offer you our parts and services that we have accumulated and soon to be readily available on our website when it is complete, In the meantime, Please read through this list and see if anything can help,
Our product range is getting bigger by the minute and we will be offering the biggest discount possible if you quote this site,
Goodridge;
We are a supplier of Goodridge parts in the U.K We have the facility to make to order brake, fuel and oil pipes that are needed along with a full range of adaptors and fittings of any size, All banjos available
We also supply from them;
fuel caps and Filler Necks
Oil Coolers of many different sizes and brackets available
Remote Filter housings, can be mounted any where in line,
Facet fuel Pumps,
fuel Shut off Valves
Inline fuel filters
Coloured heat shrink to fit over hoses to colour code, protect from corrosion and abraision, Also availabe is heat guard to protect pipes from exhaust heat
House separtors; These are anodised aluminium separtors, they look great and allow routing of pipes safe and securely with style, different colours, are blue, red and grey, and different sizes
PClips, full range of p clips available in different sizes and anodised in different colours,
Lockwire and lock wire pliers. aircraft grade stainless steel wire and pliers
House end finishers, Instead of having jubilee clips everywhere why not have these hose finishers, look neat and race spec avialble for all different sizes and colours, Also a better grade clips and give that racing effect
Brake light switches, Pressure sitched brake light sensors, one of the best on the market, also brake light remote inline body to allow for any place fitting, Much easier then fitting a conventinal switch,
Big Brake Kits, we do Big brake kits for All makes of kit cars that have a donor and Caterham, We can do up to a 12 pot caliper and rotor discs, we also have handbrake calipers and EBC brake pads,
We do a full range of parts for the Duratec, Zetec and GM C20xe (redtop) these include:
Bellhousing adaptors, These bellhousing adaptors are designed to allow these engines to mount to the Type 9 gearbox this can be of hydraulic or clutch operation, We also do lightweight flywheels for all the engines,
For all the engines we also do Dry Sump Kits These kits reduce the sump height to allow for a lower car/ more clearance from the road reducing the chance of grouding and serious damage to the engine, These kts come complete with belts pulley etc to bolt straight onto the engine, These kits are driven by a 3 stage scavange pump and are of brilliant quality,
Inlet Manifolds, we also do a full range of inlet manifold for Weber carbs for all three engines, these are machined aluminium, and for the red top have with or without the water inlets,
We also do a full range of bilstein suspension for kit cars;
we also do a full range of engine management and igntion only systems, Sensors and adaptors, The igntion only is brilliant method for running carbs as it is simple and effective with setup guide and easy to install, can work on nearly any engine,
The engine management system is an Australian based company that we are dealing for in the Uk We offer a full mapping service and fitment; please visit there website at : www.tfelectronics.com.au
On top of all this we offer a full workshop service, We at A,C,Engineering have 15 years experience building kit cars and in Motorsport, We offer servicing, full/part builds, Custom Parts, engine Upgrade, flowing porting, cams, custom turbo applications, chassis farication, Upholstery and much much more
If you would like to contact us please feel free to ring us on: 01483 219 589 or email us on enquiry@autocustomengineering.com and we will be happy to help
Daniel Wilkie
A.C.Engineering
Old 22nd May 2013, 17:16
Spartan2 Don Spartan2 Don is offline
Spartan2 Don is on a distinguished road
Hello there Daniel,
I am in need of a Spartan 2 rear bumper. Can you help me? I am in Arizona, USA.
Thanks Don
