Old 27th August 2014, 12:46
Slip Hazzard Slip Hazzard is offline
Slip Hazzard is on a distinguished road
Default seeking Andy
Could any of you guys help help with contacting Andy.
When I took delivery over a year ago the screen was to follow - I cannot raise him by email, has he he changed contact details? Thanks.
Old 27th August 2014, 13:42
Wotcha matey, the company has now changed hands and is in the process of changing back to being Sammio.
Here's the thread, along with the new contact details:
http://www.madabout-kitcars.com/foru...ead.php?t=5035
Fingers crossed for you!
Old 27th August 2014, 16:13
Viatron Viatron is offline
Good luck in your search you may have more joy contacting MickyMo as he seems to be the only one that can get hold of him these days.
Mac
Old 27th August 2014, 18:51
Slip Hazzard - I have a Cordite screen you can have, as I will be fitting twin Brooklands screens on my car.
I have bases for the main screens and the two side screens.
I have both a used and a "still wrapped" new main perspex screen.
Unfortunately, I will be recycling the side screen perspex & fixing bolts for my rear view mirror deflector.
Obviously it would be a bit of trip down the M11 to collect them.
Just let me know, cheers, Paul.
Your build thread could do with a bit of an update and a few photos.
Last edited by Paul L; 28th August 2014 at 08:04.. Reason: Decided I'd better keep all the side screen perspex just in case.
Old 28th August 2014, 13:18
Really, that would be handy, I can make up side screen no probs as they are flat. I have to venture in to the M25 on 20.09 if you are about?
Yes you are right about pics, just got to sort a load of work stuff and I will be on the case. It has become somewhat 'radical' as I have chopped all the Triumph back end off, now fitting trailing links, an A bracket and coil spring/damper units, plus for easy access I have made the rear body section demountable - plus the Rover V8 up front of course!
Old 28th August 2014, 13:20
Thanks a lot, I have other options now - see below.
Old 28th August 2014, 13:22
Thanks a lot, other options now possible so I can move forward - see below!
Old 28th August 2014, 13:24
I have answered all three guys - thanks to all of you, hopefully you can view my replies as I can't!!!
Old 28th August 2014, 16:44
Originally Posted by Slip Hazzard View Post
... I have to venture in to the M25 on 20.09 if you are about? ...
I should be around on 20th Sept. as we have some friends coming round the next day.
So I will probably be gardening.
Well, that is after I have removed all tools and car bits from inside the house.
Let me know if you are still coming a few days before and I'll send you my address via a PM.
As a rough guide I am only a few miles from Wembley stadium.
Looking forward to seeing photos of your project as it does sound radical.
Old 28th August 2014, 17:20
Ok thanks, will do.
