Old 27th January 2016, 10:39
timbo timbo is offline
Default Fuel Sender
As I head into the final stages of the re-wiring, I have come across a small problem.
I'm using the Marlin supplied fuel sender, and am attempting to connect it into an E30 loom. Whilst I think I understand that the low fuel warning light will never work as I don't think the Marlin sender has such a facility, it would be nice to get the actual gauge reading fairly accurately.
Adem had labelled two wires (purple/green and green/white) as fuel sender. When I connected up the green/white one this morning, the dash dial went all the way up to full (when clearly the tank was mostly empty).
Is there a simple fix for this, like adding in a resistor or something??
Any suggestions much appreciated.
Thanks, Tim
Old 27th January 2016, 15:20
phil.coyle phil.coyle is offline
phil.coyle is on a distinguished road
You have to match the gauge with the sender unit. Depending on make some gauges read full on low resistance and others vice versa. Check with your multimeter the value from your sender and check the resistance for your gauge you could have a look at the VDO data site to check the values.
Sometimes you can't just plug and play.
Phil
Old 27th January 2016, 15:50
peterux's Avatar
peterux peterux is offline
Not sure but you might need something likethis...https://www.spiyda.com/magento/index...izard-500.html
Old 27th January 2016, 16:19
I think that is a very good interpretation of my(in a nut shell) fuel gauge/sender problems that may be incurred.
Phil
Old 27th January 2016, 21:59
Thanks for your help guys.
They have a Mk 3 version available so have gone for that one. Seems pretty straightforward to wire in and calibrate. Will be sure to post progress!
Tim
Old 30th January 2016, 10:06
Well the Gauge Wizard Mk3 arrived this morning, fitted and programmed in about 10 minutes! Seemed too easy, but appears to work perfectly.
Should be able now to just velcro it out of sight.
Thanks again guys.
Tim
Old 30th January 2016, 20:07
peterux's Avatar
Well that's impressive!
