Old 1st May 2020, 12:49
ChrisS ChrisS is offline
ChrisS is on a distinguished road
Default M52TU Engine Question
In the process of finalising all the ancillary pipes around my M52TU25 engine. I have what looks like a vacuum pipe coming from what I believe is the crankcase purge valve at the front end of the engine under the inlet manifold. Can’t find anything that looks like it on realoem.com but the Haynes manual shows it.
Trouble is I can’t find any indication on where to connect the other end of the vacuum pipe. Just doesn’t seem to be shown anywhere.
Any ideas? Is it possible to just ignore it?
Old 1st May 2020, 12:56
peterux's Avatar
peterux peterux is offline
It could be the fuel tank vent pipe but without a picture it's difficult to say for certain. Is a small nylon pipe?
Old 1st May 2020, 13:09
The item and pipe in question
File Type: jpg 888C37E1-293D-4EC3-B7B7-46071D4AC348.jpg (21.8 KB, 10 views)
File Type: jpg 75A34B6D-1231-494B-A248-344B28DEF845.jpg (21.4 KB, 6 views)
Old 1st May 2020, 18:36
peterux's Avatar
I'm pretty sure that is the fuel tank breather purge valve.
I have a slightly different engine to you but I removed the valve and plugged the hose that goes to the inlet manifold.
Old 1st May 2020, 21:07
