15th February 2020, 16:05
Now bodyshell from old no.7
Sorry to steal Dan’s thunder but just popped up on Facebook
New on the want list , top of the want list
https://www.ebay.co.uk/itm/Old-no7-A...53.m1438.l2649
15th February 2020, 17:26
Looks interesting, I did a bit of Googling as the ad on ebay is a bit vague. More than a hint of Maserati A6 about it. Not sure what glass will fit into it, seems to have Karman Ghia shape to it as well, at least from the rear.
16th February 2020, 10:12
More than a hint of Maserati A6 about it. Not sure what glass will fit into it.
Porsche 356 coupe windscreen. Flat toughened glass side windows and lexan rear screen to follow.
Source https://www.facebook.com/pg/TributeAutomotive/posts/
16th February 2020, 20:20
Wow, love it
17th February 2020, 00:12
Who made it?
17th February 2020, 06:02
That's lovely and has great potential. Is it a one-off or will there be more if the demand is there?
17th February 2020, 06:35
I think the bodies are available to order .
I would be tempted to find a couple of inches each end so it would fit over a Scimitar SE5 99" chassis, better than a Herald chassis as suggested.
17th February 2020, 07:41
Was thinking that myself
As above front glass is 356
Hi Mark
The windscreen is from a 356 coupe.
The side windows will be made by us in glass similar to the Swb kit. The rear screen we are trying to source something that’s production and suitable but if not we will have them made in plastic.
Kind regards
19th February 2020, 11:06
just make a convertible with aero screens - problem solved
19th February 2020, 19:25
That’s called a Formosa gr120
19th February 2020, 20:58
Doesn't 'convertible' suggest a cloth roof? What would you attach it to at the front?
20th February 2020, 21:57
Maybe convertible was the wrong word ..... I meant topless!!!
20th February 2020, 22:00
The 120 has a different body shape though.
I really like the 120 but it'd need a few tweaks to make it look 'right' (for me)
This thing reminds me of Steve Moals 'Gatto' creation which is partly inspired by the Maserati I think
21st February 2020, 08:30
Yes.... Topless is good, reminds me of Summer
21st February 2020, 16:51
I hadn’t seen this very nice
22nd February 2020, 09:39
I looked at this the other day whilst visiting Chris as Tribute are moulding a new bonnet option for my Formosa 120 GRs at present ... Chris straightened out my buck and is moulding it and pulling the first one before the mould goes to my usual laminator ...
They are very pretty ... Definitely A6 GCS inspired and great potential if you put the effort in ...
An SE5 tweak wouldn't be straightforward ... I looked at that and apart from the track being a bit narrow , which you may be able to deal with using skinny MGA steels or something , but it is close .... The seating position in relation to rear axle means you'll be sat on top of the 4 bars in its current setup ... So the 4-5" stretch will need to be done behind the seat and in front of rear wheel arch ... And even 4-5" may not be enough , so it may be a case of adding extra there and taking a bit out of the front .... That may mess with the silhouette too much ...
I'd suggest looking at something other than Scimitar .... Locost etc maybe where the rear 4 bar is much shorter ...
22nd February 2020, 10:21
I thought Lotus 7 style donor but then thought the standard style doors would open against the high chassis rails of a 7. Not a problem in an open car but with a roof I don't think you could get in or out !
If you wanted a 7 inspired donor the only one that would accommodate the body is a Locust with ladder chassis. There might be other ladder chassis options but there won't be much choice.
23rd February 2020, 12:28
Citroen 2CV is the right wheelbase...
Treat it to a BMW R1 conversion from Sparrow Engineering, give the Tin Snail's suspension a bit, okay, a lot of lowering, and, with a big dollop of imagination, you could have a jaw-dropping little road rocket that returns 60mpg and can cross a ploughed field without breaking any eggs.
23rd February 2020, 16:35
Original VW Beetle has the right wheel base. I'm not a fan of the air cooled flat 4 but there are lots of options to bolt onto that gearbox.
23rd February 2020, 17:06
Maybe the Pie Valley Buggies chassis (which has been designed to replace the beetle floorpan) would make an ideal basis for this bodshell. With a VW lump in the boot (turbo charged) or an Audi it would be a real hoot!
Currently Active Users Viewing This Thread: 328 (0 members and 328 guests)
