Go Back   Madabout Kitcars Forum > Mad Build Area > Seven Style builds
Seven Style builds Westfields, Caterham, Dax Rush, Luego, Robin Hood, Tiger, Locust, MK, RAW, Quantum, you name it, you're building it, share it here.
Old 16th July 2012, 21:21
bobkat bobkat is offline
bobkat is on a distinguished road
Angry quick shift
hi can anyone explain how a quick shift works please and would it stop a problem i have going from 1st to 2nd sometimes it wont go in i have to go into 3rd as you can imagine i feel a complete pratt burning away in 1st then the revs go from 6000 to 3000 in 3rd its a type 9 sierra gearbox thanks
Old 17th July 2012, 09:19
Chris Cussen's Avatar
A quick shift gearstick has the ratio of the movement at gearbox end off the gearstick changed in relation to gear knob end, resulting in a smaller movement at the knob end. The effect is to require a bit more effort in changing gear. Its not a lot and you soon get used to it.
However if you have a problem selecting 2nd then I don't think a quick shift will cure the problem.
Old 17th July 2012, 09:24
hi chris thank you for that
