14th May 2015, 15:28
Parts for any new Ribble / Sammio builders
As i come to the end of my build i find myself with a ruck of new and used parts including but not limited to:
Trunnion Rebuild Kits New
4 speed gearbox used.
Couple of wishbones and rear uprights used
plastic gearbox cover new but has a hole cut in it
loads of brand new bearing bushes etc
boxes of used but perfectly serviceable imperial nuts and bolts
4 brand new 185/70 R14 tyres which were fitted and then removed in favour of something a little skinnier
A brand new pair of seat runners.
Various pipes brake tubing unions etc.
At least one driveshaft
A prop shaft
Used but good waterpump
A Weber DCOE 40 in bits
At least one used from upright assembly.
I really cant be arsed to go through it all and sell a bit here and bit there for £5 so was wondering if anyone want to come over with an estate car or van and take the lot? Price is negotiable but will probably be less than i could weigh it all in for. I need the space more than i need to profit from the sale of the bits as my next project is sitting in the wings.
14th May 2015, 15:42
just realised there's a fuel tank as well
14th May 2015, 17:23
Might be interested in the Weber DCOE in bits if I could tempt you to sell that separately?
14th May 2015, 19:58
hmm make me an offer. Its a complete carb but totally stripped.
14th May 2015, 20:39
What series is it? Looking for an 18.
15th May 2015, 07:45
What gearbox is it, and where are you?
15th May 2015, 09:27
Craig,
Your in luck
you can see why i stripped it, the previous owner painted in a nice lurid green PM me your best offer mate.
Mac
Marc,
Pic of the gearbox
Im in TernHill Shropshire
Mac
15th May 2015, 09:51
Thanks Mac - do you know if it is 3 or 4 syncro - I have a Mk3, which is only 3, but I understand the Mk4 was 4 syncro.
15th May 2015, 10:26
Marc I don't honestly know, its what came with the "donor in boxes" I bought which is a MKIII 1300 with an FD prefix engine. Unfortunately I cant find out how to tell the difference even after 30 minutes on google!
15th May 2015, 11:14
The gearbox should have a number with a two letter prefix, that's the code you need.
15th May 2015, 11:22
actually just read somewhere that the 3 synchro has a square output flange and the 4 synchro has a round one. If that's the case theen its a 3 synchro.
15th May 2015, 11:23
Ed so what is the difference in prefix between the 2?
15th May 2015, 11:48
Without doing a lot of research I don't know but here is a link the Rimmers Spitfire gearbox pages...
http://www.rimmerbros.co.uk/ItemList...3-Rail--m-3167
Ben Caswell is your man, he would know off the top of his head, I am sure.
I have what I believe is a freshly factory reconditioned Dolomite 1800 single rail with a J Type o/d and the two letters nailed the exact box. I don't want to part with the Dolomite box right now because I might need it, it fit's my 1275 'A' series BMC engine. I think the two letters are stamped on the top next to the lid, from memory but your box may be different.
Reason: Forgot to paste link...
15th May 2015, 12:24
PM sent
15th May 2015, 13:17
Weber DCOE has gone to a new home.
15th May 2015, 22:15
Only way to be sure its a four synchro is take the top off and have a look. If it is a MkIV box the prefix is FH the number is on the top edge of the main case.
15th May 2015, 22:36
Well there you go! Cheers Ben.
16th May 2015, 09:44
Gearbox's are a black art to me that's why I have a a "gearbox man" what am i looking for when and if i pop the top off?
16th May 2015, 12:33
The back synchro hub should look a bit like the front one, if it's four synchro, if it's three synchro, the back half of the back synchro hub will have a steel dog clutch instead of a bronze synchro clutch.
You should see the difference in the Rimmer link I posted above.
