26th November 2021, 19:25
You could always use the TVR trick
Drill holes in the floor to aid drainage!
Not as stupid as it sounds, I have 5 z3's on the drive and they all have varying amounts of water in the front floorpans, unlike older cars there is quite a bit of electrics under the floor.
The way the foam is bonded to the underside of the front carpets, you won't realise you have a problem until it is about 3" deep.
26th November 2021, 21:10
!/2" drain holes are featured in my Audi A6 floor too !
26th November 2021, 21:20
Surely to go authentic Italian the holes should be jagged and rusty rather than neat and drilled?
I remember a friend sticking his foot through the floor of a fiat 127 when he slipped from standing on the seat - he was loading a roof rack or something. His foot went through and his leg was then trapped by the bent, rusty metal like a man trap. We were on the floor laughing for ages before anyone actually bothered to help him.
27th November 2021, 10:37
A mate at uni had an Austin 1100 with a Fred Flintstone floor.
In the Z300S I ran a fan heater and dehumidifier in the passenger footwell for about a week and got 400ml out which I thought wasn't too bad but yes- I do worry about all of the wiring under there. Especially having had the rotted battery cable on my TFS (under the driver's seat) where the insulation had been breached.
2nd November 2022, 09:22
Second MOT pass
I MOTed the TFS yesterday for the second time. All was going fairly well until the emissions test where it comprehensively failed at everything!!! Then the tester reset his rig and it passed when we ran though the process for a second time.
The item I'd worried about was the headlight aim. I've recently replaced the front shocks and taken the opportunity to shorten the springs to drop the front of the car slightly. I removed about 10cm of each spring and wished I'd taken off a bit more. Having ditched the authentic but hopeless tripod lights and replaced them with a standard 7" type along with Nightbreaker 200 bulbs, I'd also adjusted them against a garage door to get them in a reasonable position. No problem at all now.
I left the car there and came home on buses while they replaced the rest of the front suspension (using a kit I'd supplied) and two rear tyres that I'd had stored. (Avon WV7 winter tyres) I got a call to say that one of the support brackets for the anti-roll bar bushes had broken so I ordered one on eBay. I expected all of the parts that could be fitted to be on the car but when I collected it, they hadn't refitted the complete anti-roll bar with its new drop links- we put it in the boot!!! When the bracket arrives it shouldn't take too long to refit it all. The idea of having them do it was so that I didn't have to grovel in the gravel struggling to get the taper joints apart.
31st January 2023, 21:34
Just re-read this thread and have to say that I still love the TFS. Truly unique and bloody good looking car Ian.
Must see it one day this year.
1st February 2023, 09:18
The ARB was easy to refit and I took the opportunity to fit all new bolts, washers and Nyloc nuts.
Next job is new discs and pads on the front. I'm considering drilled discs to replace the standard ones.
1st February 2023, 10:48
If your brakes work ok why bother? IMHO the pad material is the most important factor.
1st February 2023, 16:28
I don't know what make/spec the current pads are. It seemed obvious to upgrade whilst replacing the discs. My Z300S has dimpled discs which I'd assumed were standard.
1st February 2023, 16:56
And there lies the difficulty - what info can we get about pads? What is marketing 'hype' and what is possibly downright dangerous (unknown brand?)
Some buy 'racing pads' thinking they are better - but are they suitable for the road? - they may not be very effective at all unless really racing so the discs are almost red (clearly not on the road). So softer ones are better for the road, but would quickly fail on the track.
I tend to buy brands I recognise, and the last pads I bought were Ferodo, from a recognised source. A late friend bought some 'never heard of them' brand from his local motor shop and if he did a couple of stops from 50 MPH they faded badly (no good from residents of Milton Keynes) He challenged the shop and they said 'we'll test them in our MOT bay' and of course deemed them to be good, missing the point entirely. I guess the drilled discs are to enhance cooling, but being drilled introduces other (albeit small) dangers. I'd suggest any benefit is marginal for the extra cost, and better spent on good pads (back to our unknown though ![icon_question](images/smilies/icon_question.gif) )
1st February 2023, 17:30
I've used PAGID pads on a few cars and have no complaints. I've heard that Hawk pads (where available in size) are a good compromise as they provide race-like performance but require much less heat to operate effectively on the road.
2nd February 2023, 13:24
PAGID on mine. They work fine and I drive like a complete tit a lot of the time :-)
2nd February 2023, 15:07
As good a recommendation as any. Especially from an automatic gearbox car driver.
I'm surprised at how little I use the brakes except when bedding in new pads when they get hot quite quickly.
2nd February 2023, 19:05
Brakes, tyres, oil etc etc just buy a familiar brand at the best price you can find, you're unlikely to see the benefit of spending over and above unless you are intending to drive at the limits or track days regularly.
15th February 2023, 14:51
Weymouth Bike & Classic Car Nights
Weymouth Bike & Classic Car Night is held every Thursday evening from the first Thursday of April to the last Thursday in September on The Esplanade, Weymouth.
That's April 6th to September 28th in 2023.
The fun starts at 6pm and all bikes, American, Classic and performance cars are welcome.
Charity donation expected: 3UKP for cars, 2UKP for bikes.
Reason: Forgot that you can't use a pound symbol on this forum!!!
3rd July 2023, 07:41
I took the TFS to the Malvern Show on Friday then went home on Saturday to attend to the cats we're looking after and returned in my Jago. A total of 260 miles in open cars in superb weather.
3rd July 2023, 21:16
That explains it ! I saw your car from the road on Friday ( didn't know it was yours Ian ), then couldn't find it Saturday morning when I went to the show ! Have you got any more photos of this one Ian, don't think I've seen any on here apart from a couple just after completion .
5th July 2023, 07:52
9th August 2023, 15:11
50s Specials Show - Cotswold Wildlife Park - Burford, Oxon.
The 2023 50s Specials Show at Cotswold Wildlife Park is on Sunday 13 August. Remember to tell them at the entrance that you're there for the car show and the driver gets in free. The rest of the park is accessible.
Entry for anyone other than the driver has to be booked via the Cotswold Wildlife Park e-ticket booking page here:
http://www.cotswoldwildlifepark.co.u...ticket-prices/
I'm taking the TFS & meeting friends for a picnic.
10th August 2023, 11:01
Ferrari No82 in 1962 Targa Florio is up for auction
My second inspirational car for the TFS (after Tigga's Tribute car) is coming up for sale next week at Sotheby's auction in Monterey.
I will be buying lottery tickets between now and then.
https://rmsothebys.com/en/auctions/mo23
