10th January 2014, 02:14
happy days, the parts (bushes, bolts + shocks) i ordered from rimmer on monday arrived on my desk this morning (sydney time). Good work Bro's.
will post some picks when my chassis is blasted and powdercoated. anyone recommend any further treatment over that?
10th January 2014, 07:24
To use the vernacular I expect ' She'll be right' in the Aussie climate. With hindsight I wish I'd had my chassis and bulkhead galvanised over here though.
10th January 2014, 11:35
If galvanising is as cheap over there as it was for me over there then i would definitely consider it, just be aware of the pitfalls, galv filled threads etc
14th January 2014, 22:52
I'll look into the gal. The blast and powdercoat includes a zinc prime, and given the outstanding state of preservation it is already in over the last 50 years, it will last another 50 no worries, I reckon. i am thinking of a clear coat, or something to give added protection from stone strikes etc under there.
thanks for all the ongoing support guys.
15th January 2014, 06:58
You could also consider the bed liner stuff i used for the interior, i reckon it would be excellent for chassis protection, see my build thread here
Macs Build Thread
Mac
15th January 2014, 07:05
The bed liner bit starts on page 15
Mac
15th January 2014, 07:35
No worries. Must drop in and take a look at your progress if I happen to be passing...
17th January 2014, 00:30
you planning a trip down under, mr t?
Reason: revision
17th January 2014, 09:41
Erm, no, sorry Tim it was meant to be a sort of joke.
Wife's sister and her family emigrated to Aus last September but they haven't decided where to settle yet, so no trip planned at the mo.
I did have a weekend break in Melbourne a few years back though, after popping to New Zealand to look round for a couple of hours...
26th January 2014, 21:10
Ok, can anyone tell me how I can get the rear diff mount bushes into the hole or have I somehow got the wrong size metal ringed bushes? ( I got the old ones out with a hacksaw and strength)
26th January 2014, 23:33
Like I always say, if you can't get it in the hole you either don't have enough lubrication or you are not using enough force!
27th January 2014, 03:39
Yep brute force wins the day! Try giving the hole in the diff case a good clean using a small flap wheel, then drag them in using some thread bar, washers and a couple of nuts. And then thank The Lord they don't need doing too often!
27th January 2014, 06:47
The diff bushes was the task that nearly beat me. I tried all of the above and had to resort to a press.
31st January 2014, 03:25
all the above is failing me at present. When i get a good tension on the long threaded rod the bush jerks off centre rather than going in evenly. hammer does not help any harder and i'll damage the bush (more). As a last resort I will try smoothing and extending the small taper on the diff housing. Oxford what kind of press? Did you take it to a workshop?
31st January 2014, 06:40
Take a look at the tools on the web type in bush press kit garage tools and you will see whats required, a make shift tool is a socket out of a socket set, length of stud similar in diameter to the hole through the bush, a couple of nuts and thick washers, small amount of lube. Make sure the bore is clean.
If you know some body with a lathe they can make a top hat type washer which helps to keep things square and aligned.
31st January 2014, 06:59
Wot he said!^^^^^
Biggest problem I recall having was snapping cheap thread rod, got some good quality steel bar and threaded it myself, just make sure your all lubed up, couple of turns at a time and I found that just tapping around the perimeter of the bush with a small hammer helped get it started.
HTH
Mac
1st February 2014, 10:59
Thanks guys. I will persevere.
4th February 2014, 00:54
Well, with an improvised lathe (a drill in a vice) i put a 1mm shallow taper on the end of each bush to help them in, and success! At least partially. The threaded rod i bought for this purpose keeps stripping, and i have each bush part way in. I will be picking up a high tensile bolt this week and some matching big washers (one i initially used stacked 4 high ended up like cones) to get them the rest of the way in.
Thanks guys for your suggestions. When i have the chassis painted I will post up some picks of it and the assembly. Then I have to get in touch with mike about the kit!
Tim
6th February 2014, 05:59
here is the result of the first attempts, note stripped thread rod, and partially in place mounts..
something funny has happened to photobucket on my phone. had to get this via friendface.
9th February 2014, 06:22
diff mounts almost in. just about 6mm to go and snapped 2 high tensile bolts. it seems not only the bolts the issue but the washers as well. will need some more wd600071's as ruined 4.
