Old 26th May 2018, 08:29
keith keith is offline
keith is on a distinguished road
Default Morgan/Moss build ?
Hi Just a intro to me and my build. 50 something and been looking at kits since 18 so hopefully will get there.
I have started my build after a trip to ebay found what was described as a Morgan/ Moss shell last year. have also got a Triumph Herald chasse with running gear and log book from ebay. Keith
Old 28th May 2018, 04:48
Been planning build so looked at different engines and have got a 2.8l v6 Chevrolet Camaro engine and auto box. This requires altering the chasse to much so have decided to make a new chasse and go through IVA. But use Triumph suspension.IMG_20180103_122225534.jpg
Old 28th May 2018, 05:09
Next turned to rear suspension needed better diff BMW e46 would do so had adaptors cut to fit Triumph drive shafts but leaf spring would not fit over so converted to wish bone suspension part Triumph and rest made. Had to alter top wishbone to get coil over through but rolling chasse now.IMG_20180320_211140468.jpg
Old 28th May 2018, 21:34
froggyman's Avatar
Nice work. Keen to see how this works out with your chassis. Have had similar thoughts myself but not put into practise as yet. Keep the updates coming with plenty of pictures.
Old 29th May 2018, 18:47
Thanks will try and keep it up to date
Old 29th May 2018, 19:10
I plan to fit discs brakes all round up rated Canley classics up front and mgtf rear discs with golf calipers and make up carriers and have fitted 1500 spitfire anti-role bar to the rear and standard herald to the front. Also fitting pcd adaptors to give better wheel selection, with the 35mm I made the chasse wider and the adaptors the wheel base is 70mm wider.IMG_20180419_164943321.jpg
Old 30th May 2018, 07:14
As this is being made up with a new chassis and so many different donor parts, will it end up as a Q reg?
Old 30th May 2018, 18:23
Yes it will have to be a Q plate, but as long as it is road legal and I can drive it, I don't mind! after all the work what does it matter its just numbers and letters.
Old 31st May 2018, 07:07
JG's Avatar
JG JG is offline
JG has disabled reputation
Very interested to see progress on this. Love a scratch built car. Also nice to see a healthy attitude towards a Q plate. I could never see the problem with a Q myself.
Old 31st May 2018, 18:59
Originally Posted by JG View Post
...Love a scratch built car. Also nice to see a healthy attitude towards a Q plate...
+1
It certainly looks & sound like you know what you are doing.
But good luck anyway, Paul.
Old 1st June 2018, 06:29
Thanks I do a lot of research into each bit but probably over engineer everything as I normally work with wood.
Old 1st June 2018, 19:47
Just found time to add more pic of work I have done over the last 6 months so almost up to date, started the body work had to cut bulkhead d in half and widen by 70mm to bring wheel arches out! alter one thing alter all. Also fitted angle around the floor to give me something to fix the engine tunnel to and a prop catcher. Also made up a frame to carry front of fenders, most parts are just tacked in place and will be fully welded when all fitted and works.IMG_20180505_154753694 (1).jpg
Old 3rd June 2018, 21:04
Managed to get a good day and a half on car this weekend and have started framing the roof so good progress.
Got an image in my head of where I want to go from a Morgan's April fools seen on line, so this will be my take on it I hope.gt3ttrgte9bv0upn7ibm.jpg
Old 10th June 2018, 20:23
Kept looking at the roof and could not make my mind up it looked like a 2CV so have re jigged it with moor curves, changed the back window and built a sun shield. I think this might work? just need to finish all the rails.IMG_20180610_141657207 (1).jpg
Old 11th June 2018, 18:25
redratbike's Avatar
Great work
Old 30th June 2018, 20:24
Not got to much done over the last 3 /4 weeks keep looking at the roof still some thing not quite right so bit the bullet and chopped the roof down by a 100mm I am a lot happier with it now. So have started the bonnet side frames today.IMG_20180630_151328224 (1).jpg
Old 9th August 2018, 15:56
Dpaz Dpaz is offline
Any progress? This is an awesome build.
Old 9th August 2018, 18:30
Hi thanks not much done over the last 4/6 weeks with work and other commitments but hope to have some done soon
Old 27th August 2018, 19:38
Managed to get all the framing done now and have started with some of the panels. I Have decided to bond the panels on and joggle the joints and will put in some small counter sunk pop rivets in as required, to hold the joints. The panels are in 1mm mild steel I have sanded the backs and cleaned with acetone then bonded with ever build sticks all extreme. So hope this will do the trick.
Old 27th August 2018, 20:11
Looking really good. It is a shame how work and other trivialities interfere with real life!
