4th December 2018, 18:29
Originally Posted by IanA
Make the table frame larger than the base frame and fit legs???
Go with what you know.
Correct about the legs and width. The lift width is 42m the top rails are 700mm as are the foot rails. The stabiliser struts will effectively be the legs, and at made of angle iron hinged at the top and lockable along the foot rails. One on each corner. There should be no twist torsion applied to the lift itself, it only goes up and down. The only risk is at raising and lowering. That can be mitigated by fixing a cross strut to the stabiliser legs front and back.
7th December 2018, 15:42
Just a quick update, the lift is rated 135kg and a scooter weighs 75kg. I should not rely on my faltering memory for hard facts. A regular motorcycle lift is rated around 350kg at least.
7th December 2018, 15:57
That seems light. My old SX200 with fuel and without side panels tipped 120kg on a weigh bridge.
7th December 2018, 16:02
I found some other sites that say 104kg dry weight. The SX200s had bigger blocks, but being aluminium, that wouldn't account for the difference. Was your Party 7 still on the floor?
7th December 2018, 16:06
Just looked at Cambridge Lambretta Workshop to make sure I wasn't going mad. This gives SX150 at 120kg and the 200 at 123kg. The Li was 105kg. Beauty must be heavy.
7th December 2018, 16:09
Wow, I thought the SXs were just different panels and headsets with the option for the 200cc motor. Obviously more to it than that. I'll bear that in mind if I ever get an SX for restoration though, and not lean on the worktop!
26th December 2018, 18:06
New Dowsett Comet
https://youtu.be/UEmJBdRG37s
Reminds me of the Z3gato, but the Z3gatos looks are way better balanced!
26th December 2018, 18:14
Yep, the car looks a muscled up version of several Zagato designs. You can see the step up from the Ferrari. The front reminds me a lot of the MX5 version that Zagmad scrapped in order to pursue the slab sided Lancia saloon. Where did that get to I wonder?
26th December 2018, 18:50
Looks great with great detail to the finish. Could it be a TVR rival?
Lose the roof and it would be perfect.
27th December 2018, 08:42
Looks like someone glued a Zagato and 250 California together then stuck it on the helium pump at their local Hallmark card shop... #grinch
EDIT - went back and watched again and actually retract crunch statement. It certainly has presence. Interesting to note treatment of the Dunlop style wheels with black gloss centres and polished rims with spinners - really effective.
13th January 2019, 17:44
Any updates? It must be nearly there.
13th January 2019, 20:04
Just saw xxxx ML Zagato in the classic car special on Astons.
Very beautiful car!
26th February 2019, 06:54
Just to confirm that this project has not stalled or stopped. After getting the lines on one side agreed with Chris late last year, the process of tweaking the back and front, then completing the other side has taken a while, and Chris lost some time out with a bad back. Chris should be in the "fill and sand back" any day now, and has some ideas about the window surrounds that he wants to try out. I promise that I will get some photos up shortly (a few weeks). meantime, now that the weather has started to warm a little, I may be tempted to swap the dashboard out. The only trouble is that I am wary of painting the new one in this colder weather. Is it a big risk?
26th February 2019, 07:46
Hammerite do a smooth satin black, easy to apply and gives a great finish, I am intending to give it a go on my dash. You can paint it on the kitchen table, but top tip, wait until the wife is out!
26th February 2019, 11:59
A black wrinkle finish was used on the originals. Looks better me thinks.
26th February 2019, 15:58
The wrinkle finish can be a bugger to get right, if it isn't perfect it looks crap. Having had a couple of goes with the wrinkle paint I am sticking to the Hammerite satin.
26th February 2019, 16:41
I warm the spray can of wrinkle in a pan of hot water, get the oven going (with wife gone). Spray from at least a foot away and follow remainder of directions. A warm can is a good can!
1st March 2019, 18:26
I have already got some plastic primer, satin black and the wrinkle finish to go on top. If anyone can foresee a problem, shout out now please! After the warm weather this week, I am tempted to get going before Easter if it repeats. I will post pics regardless of my assessment of success.
ps I shortened the legs on a trundle bed frame a couple of weeks ago. Cut out sections, cut a slice out of the extracted tube and then squashed and used it as a strengthener in the residual bits, then welded together again. I used a rattle can (old English White) to touch up the blackened mess. I thought i had contained it pretty well, using newspaper and masking tape. Sadly, the patio table looks like it has leprosy, as well as the plague from where I converted a double bed wooden frame to a single and had to re-drill dowell holes. I clamped the pieces to ovehang the edge of the table where I was drilling..... I thought.
13th March 2019, 07:17
Battery drain
I know you were having problems with battery drain, I was suffering the same problem. My car gets used depending on its position on the drive. It can be used every day and then gets blocked in for a few weeks. Sometime the car will start fine if left for a few weeks other times it can have a flat battery after just a day or two. Finally tracked down the problem, the passenger door catch on the B post was slightly loose, most of the time it was fine but occasionally it was loose enough to move and the switch for the interior light is on the catch so it was occasionally left on causing the drain. Worth checking if you have a drain problem or removing the bulb and see if it stops the problem.
13th March 2019, 07:24
I checked drain by plugging into each fuse location. First it indicated door lock, and I removed them refitted driver side actuator. After the garage super charged battery, it has been good for up to 2 weeks at a time. However, it has not been used whilst I wait for it to go in for seized brake calliper, and it was flat after 10 days. Passenger door is seldom used, but I'll che k put connections on both soon. Thanks for the tip.
