Old 7th May 2017, 22:09
Aus Simmo Aus Simmo is offline
Aus Simmo is on a distinguished road
Ross, if I had 1/10th of the talent of you and others on here I might just do that. I'm handy with spanners and sockets but have no fabrication skills whatsoever.
I'll keep dreaming for now and see what happens. Thanks for the comparison pics - interesting to see the "family tree".
Old 7th May 2017, 22:15
thecarbuilder246 thecarbuilder246 is offline
thecarbuilder246 is on a distinguished road
Originally Posted by rossnzwpi View Post
Simmo,
I think CASCU (on this forum) makes his body from a genuine 246 while virtually every other manufacturer used the mould in one form or another taken from a 206 which had its rear wheel arch shifted to fit a Lotus Europa wheelbase. CASCU's body looks very straight. He doesn't make a kit though - only replica 246 chassis which require 246/308/Mondial suspension. Maybe you could use a CASCU body and make your own chassis? Or adapt a DeHavilland chassis to a CASCU body?
cheers
Ross
You use to be able to,but he was messed about by someone who ordered a 246 shell then went and got one from dehavilland!! He will now only supply full body /chassis units.
ian
Old 30th September 2018, 00:59
nostraloom nostraloom is offline
nostraloom is on a distinguished road
Default Body work
It seems pretty quiet, so I thought I would post some pictures. The nose of the car has been cut off and glassed on higher up to compensate for the droop that Deon/Classic Replicas always seem to have. I have been body working all summer, trying to get the bodyline down the side and wheel arch lines sharp. The car is now almost ready for paint. I would love to see pictures of some of your cars and what you've been doing. Cheers/ JonDSC00581.jpg
Old 30th September 2018, 01:03
Default Body Work
DSC00552.jpgMore pictures.
Old 30th September 2018, 08:16
Barber's Avatar
Barber Barber is offline
Nice
Old 2nd October 2018, 12:38
Default droop
Hi
Looks good. How much did you cut of? and do you have any photo's of the work? Have you left the rear of the car alone? as the deon is much lower at the back as well. keep us posted
ian
Old 4th October 2018, 00:27
rossnzwpi rossnzwpi is offline
rossnzwpi is on a distinguished road
Nice work on those arches Ian - looking crisp and metallic rather than soft curve fibreglass.
Old 4th October 2018, 05:17
Axel Axel is offline
Axel is on a distinguished road
The front and the rear from the Deon always drop because it is moulded from the early Dino 206 GT which had this shape, with the 246 GT Pininfarina has corrected this...
Old 4th October 2018, 19:21
Default nose and tail droop
dino3.jpgThe rear is left alone. For some reason, the back of my car doesn't droop as much as some other cars I have seen. As for the front, There is an illustration for what I did, on the first page of this thread. The only pictures I have of this, are photos with a large glassed area on the top of the front wings.
Old 5th October 2018, 05:16
Sorry, I should read the whole thread before saying something you already know...
Old 5th October 2018, 10:23
Default droop
Hi all
Going back over this post I was looking at the photo's of side on dino's. The first JHClassic car (the blue one) looks almost correct at the front to a 206 from which it was ( allegedly ) moulded from.I know the original 206 was lower at the front and back than the later 246. Also I know the rear wheel arch was move to accommodate the lotus chassis. This also seems to have carried over into the replica dino body shells.
But then later bodies seem to have drooped more at the front. If you look carefully at the photo's of the more serious droop you'll notice it has also affected the shape of the wheel arch in no longer being round more of an ellipse shape.And the body swage line instead of being almost level points down towards the ground resulting in the bumpers looking wrong.
I seem to have been lucky with my shell has the nose is only about 8mm lower than it should be,but it still required about 8mm adding in length to the bonnet!!
