26th May 2009, 22:06
![peterux's Avatar](image.php?u=181&dateline=1694029053) |
Originally Posted by peterux
Hi Robin,
The arms are adjustable length but I still had to cut a small piece off each one to get the right length which was easy as the arm just slides right out. You also have to put 'more angle' on the arm crank.
Just found some more photo's...........
![](http://farm4.static.flickr.com/3319/3266510189_e4c8fff32b.jpg)
27th May 2009, 11:57
![Patrick's Avatar](image.php?u=177&dateline=1240759848) |
Yeah on ours we cut down the length of each arm, drilled new holes and attached with two screws. They also needed the angles fine tuning which took a vice and a lot of force, took a few goes before it was right. Also found once the springs were in it need a more fine tuning.
27th May 2009, 12:36
![MartinClan's Avatar](image.php?u=129&dateline=1286459660) |
Thanks guys
3rd June 2009, 16:17
I have a question about the wiring for the wiper motor (I am being lazy not wanting to work it out for myself)
The Lucas motor requires a +ve feed for the self parking. I assume this should just be live when none of the other feeds (1st or 2nd speed) are - is that correct?
I am using the BMW fusebox and loom. Does anyone know what this provides for the motor and whether I will have to modify anything for it to operate the Lucas motor? I seem to remember Richard saying he had to fit a relay for the parking feed.
3rd June 2009, 16:37
I just used the K10 relay in the fuse box it has all connections nessecary.
http://ogamedk.net/accessories1.jpg
Stuart
4th June 2009, 07:39
Stuart - did that also give you the self parking as well? I have worked out how it operates on the Lucas motor and I can't see how the standard BMW connections would work without the addition of a relay.
4th June 2009, 16:31
I have worked out how the wiper motor is actually wired internally.
If you use the standard Lucas switch then when you turn the wiper off, it connects the park terminal (2) to the 1st speed terminal (5). The park contact is made until it is parked and supplies power to the single speed winding. When the motor is on either 1st or 2nd speed the switch disconnects the park terminal from the 1st speed terminal.
Simple really and, I suspect, a bit different to how the BMW switch and relay works.
4th June 2009, 17:29
If i remember correctly the BMW switch and K10 relay works exactly the same way park becomes live when switch is turned off.
4th June 2009, 20:30
Thanks Stuart. That makes it easy then.
5th June 2009, 14:09
Did anyone locate a source of the connector for the Lucas wiper motor? The spades in the connector don't seem to be the standard size. I could always solder wires on I suppose but then that's a problem if it ever has to be changed.
5th June 2009, 14:25
Solder then put a multiplug after it ![Smile](images/smilies/smile.gif)
5th June 2009, 20:49
I've seen proper Lucas connectors and looms on ebay but they were rather expensive.(about £10?)
I just used some small connectors which I had in my box which I think were 4.8mm crimp terminals like these...
http://cgi.ebay.co.uk/4-8mm-NON-INSU...3A1%7C294%3A30
Try and check the size of the spades as I am not 100% sure on the size on this one but I did find some that fitted OK,
8th June 2009, 12:27
Hi Peter
You said your arms were right hand park - but in the picture they appear to be parked on the left. Did you just flip (turn over) the arms after you had cut them to length by any chance?
![icon_confused](images/smilies/icon_confused.gif)
8th June 2009, 20:08
Hi Robin,
I checked my Europaspares order and definately ordered ITEM : 5.2mm RHP - U71300 X 3
You can't flip them over as there is a pip that fits the wiper blade.
I think a better description would be Right Cranked as on the TEX website....
http://www.texautomotive.com/images/...ers/U70300.jpg
I looked at this website and then ordered by the part number.
They were tested in extreme weather conditions on Sunday morning!! ![lol](images/smilies/lol.gif)
9th June 2009, 07:18
Hi Robin,
Thanks. I was thinking about you Sunday morning when I was out in the garage finishing the fitting of the windscreen. On to the wipers next!
2nd September 2009, 07:34
Can anyone remember how thick the fibreglass is where the wiper spindles pass through? Mine are from a Mini and I think that they may be too short at about 2". (I think the ones from SVC are 2.5")
PS saw an awesome car at Knebworth - an Alfa Romeo Superleggaro - from the '30s I guess. The sort of car you normally only see pictures of in glossy classic car books. Quite why the owner decided to drive it up a dusty track and display it in a field (Knebworth) I really don't know....
2nd September 2009, 21:01
Robin,
I think the GRP is was only about 3mm thick. I also think my wheel boxes are from a mini and fitted Ok with some home made spacers. The spacers are expensive but i think if I did it again i'd buy them becuase i spent far too much time messing about making them.
So where's the pictures of this super car at Knebworth??
2nd September 2009, 21:07
the thickness varies a bit, you might need to sand it back a bit which is what I had to do on mine ![Smile](images/smilies/smile.gif)
3rd September 2009, 07:22
Still on the camera!
3rd September 2009, 07:29
Robin,
Thanks guys. That was what I was hoping. Looks like I can use my Mini wheel boxes (Ebay bargain) although I still have to get a third one. Should have the wipers installed just ready for when the car comes off the road for the winter at this rate....
On a related point I was looking at a couple of NG's that turned up at Knebworth. Their windscreen is a similar dimension to the Sportster but they only use 2 wipers. But it does leave large patches of the screen unswept. I was wondering how legal that is....
