Old 14th April 2010, 12:48
MadDogMoggy's Avatar
MadDogMoggy MadDogMoggy is offline
MadDogMoggy is on a distinguished road
Default Fuel Regulator - Type R
What fuel regulator have builders used for their Type R engines?
I'm assuming that it's got to work with injection pressures (higher than carbs) and have a return (to take fuel back to the tank).
I already have a separate pressure guage, so don't need that built into the regulator.
Any help, especially make/model/supplier would be greatly appreciated.
Thanks in advance.
Old 14th April 2010, 14:49
alackofspeed's Avatar
I'm using an FSE fuel pressure regulator, set (I think) to 47 psi (static - no manifold tapping).
Fuel system goes:
Rover tank pump (8mm pipe) -> swirl pot -> walbro 255 -> filter -> t-piece (with 8mm tapping to fuel rail) -> fse regulator -> swirl pot (6mm from reg to swirl) -> tank.
Fse reg is approx 300mm from fuel rail, to ensure the displayed pressure is as close as possible to that seen at the injectors. Some people I believe have placed the regulator and gauge near the fuel tank, which seems daft - it's best to regulate as close to the point of use as possible.
Old 15th April 2010, 09:50
Thanks - that's good info.
Did you getthe regulator from Marlin? I don't suppose you know the model number off hand?
Thanks again.
Old 15th April 2010, 13:40
I didn't buy the regulator from Marlin.
http://www.merlinmotorsport.co.uk/p1...duct_info.html
