Old 2nd January 2020, 19:08
Topcat2Vin Topcat2Vin is offline
Topcat2Vin is on a distinguished road
Default Panel alignment question
Hi,
I have been reading a few build treads and I am curious, is it difficult to fit the panels and get good gap alignment, does it take a bit of fitting and refitting or fettling with the unibond?
If anyone can highlight the process or has some photos that would be great.
Thank
Vin
Old 2nd January 2020, 21:37
Which kit?
It varies depending on the kit, the donor, the weather and your understanding of 'a little more pressure will align just fine"
Old 2nd January 2020, 21:40
mine is a bit wonky in places because I am not that fussed but I have seen a couple of the SWBs where the panel gapping was EXACT. if it was 4mm between the door and the body then it was 4mm across the car.
Mine was quick and painless, drives just fine and is much admired. Theirs sold for £30K.
Old 2nd January 2020, 22:40
Go back a couple of pages on the forum and you'll find some very detailed build threads.
The consensus is that the basic panels fit easily enough, a little fettling is required to get a good fit. Take your time, there isn't anything difficult as such.
It does depend which kit you buy, the Z3 based Kobra and Z300 go together very quickly. You can be on the road in just a few days and be ready for paint.
Old 3rd January 2020, 20:12
Hughandjen Hughandjen is offline
Hughandjen is on a distinguished road
Mine is taking some time, filling and flatting. Half way through the boot.
My boot wasn’t a good fit tbh and needed a lot of work.
File Type: jpg 238BFD21-F77A-42AE-A769-69A0922B0C12.jpg (18.9 KB, 34 views)
Old 3rd January 2020, 22:08
Thanks guys. If the boot taking time as it mounted slightly off or twisted or does it just take the fettling?
I had thought it might be better to fit the lid first to stiffen it.
Old 4th January 2020, 09:33
If you can get the fit close enough your body shop will do the finer points before they paint it ! They'll also have all the kit and experience to do it quickly and to a high standard.
Old 4th January 2020, 15:43
The bottom lip of the boot was proud of the rear clam by 5-10 mm. If i cut material off the front edge the 90 degree bend didn’t fit. But hey ho you just have to be patient and you will get there in the end.
