Old 23rd May 2014, 11:16
completenovice22 completenovice22 is offline
completenovice22 is on a distinguished road
Default Wiper arms
Hi Peeps,
As anyone tried to fit these wiper arms http://www.motoringclassics.co.uk/wiper-arm/p2104 and if so how did you do it ? Rob
Old 23rd May 2014, 11:35
I have tex wiper arms on my mx250.
Need to buy an extentsion bolt to make them fit. Land rover one will fit and cheap.
Old 25th May 2014, 08:13
Hi Drummajor, just how did you fit them? I have the land rover extensions as recommended but can't figure out how you modify them to fit on the standard wiper screw tread.
Old 25th May 2014, 12:30
You will need to extend the existing thread so the landy bit is about level with the body.
The thread can be extended by welding a bit more thread on or by using a coupling nut together with some more thread.
Old 25th May 2014, 16:58
I welded a spacer between the bolt and the land rover part. Then painted it black. Job done.
Old 25th May 2014, 18:24
The land rover part I have has only a small hole in it for fitting, do you drill this out to get it accommodate the original wiper arm thread?
Old 25th May 2014, 18:31
No drilling required. Just weld a spacer on the bottom of it and then a nut on the base to fit onto the Mazda wiper box.
Old 25th May 2014, 18:34
Ahh, I see said the blind man, shame I don't have a welder.
Old 25th May 2014, 18:37
I don't either, got a friend to do it. Didnt take more than Five mins. Wasn't neat I just grinded it neat after then painted it black.
Old 25th May 2014, 18:42
Thanks, I'll try and source some bits during the week and then on with the other issues with the car.
Old 17th June 2014, 19:03
An update for this thread, I used an M10 rivnut off ebay it slides over the standard MX5 wiper arm screw thread. I araldited it to the thread. It has splines on so the TEX wiper arm just screws straight onto it,no welding required and it has a more postive contact with the windscreen. I'll update this post when I've used the wipers a bit to let you know how there doing as the car will be my daily driver
Old 21st April 2016, 13:43
nicedive4u nicedive4u is offline
nicedive4u is on a distinguished road
Default Which wiperarms and wipers?
Hi Guys,
I want to leaf my MX-5 as it is, but have always chromed original wiperarms with old Bosch wipers in stainless steel.
But would like to update the arms with stainless steel.
So which exaktly arms an wipers will fit with using a M10 adapter?
Thanks a lot
Thomas
