Old 3rd May 2017, 15:09
swifty's Avatar
swifty swifty is offline
Default 250 SWB Head Linner
Being putting together a plan to build a hard top 250 swb and was wondering what other people have done to cover the underside roof area to hide the fiberglass.
Old 3rd May 2017, 15:46
hurnleft's Avatar
hurnleft hurnleft is offline
I used the stretchy fabric/carpet stuff for lining vans. It's very forgiving but if you use spray glue, like I did, it will sag down in warm weather. It was easily re-glued though.
Old 3rd May 2017, 16:55
swifty's Avatar
Cheers Hurnleft that sounds like a good solution, i should of thought of using this fabric as i have a mate who converts camper vans and use's the same stuff but he has a spray glue that is temperature stable to stop it falling off.
Old 3rd May 2017, 17:07
An alternative is to take a splash of thin GRP from inside the shell and upholster that. A few thin "mounting blocks" could be 'glassed in for mounting.
Old 3rd May 2017, 21:40
aofb aofb is offline
aofb is on a distinguished road
Mines lined in black acoustic carpet using spray heavy duty contact adhesive, direct to the fibreglass.
Old 4th May 2017, 15:25
ned ned is offline
I used the black acoustic carpet swell , i used a spray adhesive that is supposedly not affected by the heat but i can't remember the name, its an age thing sorry
Old 11th June 2017, 00:52
Egdik Egdik is offline
Default roof insulation
Recently I 'discovered' that an epoxy coating on the ceiling is extremely sticky the next day, when first some extreme dynamat was added, followed by the cbs lead foam sandwich.
For a headlining 'card' Chris made a grp panel off the top of the car and we have cut that in half longitudinally and covered it in foam & lining. It will fit above the strengthening frame. The frame is also covered in foams and the same wool lining, plus a thick foam on the front cross tube. It is all a tight fit, but hopefully, will give good insulation and appearance.
Sealing the doors and window frames is a much greater problem . . . .
