31st May 2015, 15:03
Originally Posted by landmannnn
In my experience oldish hyraulics don't like being left unused for even a few weeks.
Any suspended solids sink to the lowest point and gum up the seals.
I would buy 5 litres of brake fluid and give the brakes and clutch a really good bleed.
+1
31st May 2015, 21:28
It's looking great!!
Took a few cockpit detail shots of a D-type today in Coventry motofest - not sure if they are much use now to you but I can post them up tomorrow if you want
1st June 2015, 07:13
Thank you all for the feedback, what you have written sort of echoes a lot of my own thoughts about it, I think I was rather hoping for an expert to say, " tighten the X screw a bit and it will be all like new" Don't we all pray for something like that?
The clutch still actually works, there are no leaks, and the fluid is not getting past the master cylinder seal, and pumping does not make any difference.
A friend of mine that helped me establish that little lot, thinks I am being paranoid, and there is nothing wrong with the system at all!
I have had so many setbacks on this build, he may well be right.
I will get the two new cylinders and some fluid, and tackle this at a later stage. All the time the car is on my patch and not the road, it is not a huge problem.
1st June 2015, 07:49
I would definitely replace the fluid, both in the clutch and brakes, it should be replaced every two years anyway, irrespective of use. It may LOOK OK but it absorbs water and deteriorates over time. Either use DOT 4 or DOT 5.1. NOT DOT 5, which is silicone based and not compatible with glycol based fluids.
http://www.advancepetro.com/differentbrakefluid.htm
http://en.wikipedia.org/wiki/Brake_fluid
PS. Better to buy small containers of fluid, once opened they start to deteriorate by absorbing water from the air.
Reason: Added PS.
1st June 2015, 10:03
Thanks for that info Ed, you always amaze me with your in-depth technical knowledge! You seem to be so well-informed.
I will take your advice and get some of that stuff.
1st June 2015, 10:39
LOL [blush] I spend too much time reading and browsing I guess. I just try to share info when it's needed.
Have fun!
1st June 2015, 11:12
1st June 2015, 11:20
Thanks for those pics CP, much appreciated, and I'm sure Mick O'Malley will be interested, of course, as he is building a D Type!
1st June 2015, 11:21
no probs
1st June 2015, 16:25
Monday
One good thing about this forum is the fact that if one reads other peoples threads, one can learn from other people, and thus avoid making the same mistakes.
Mr Towed kindly posted his experiences during, or just after, his build and told of getting caught in the rain before he'd had chance to fit his under bonnet rain splash panels / wheel arch panels, and how he was rewarded by a battery-box full of water amongst other things.
So today I started work on mine. As access to anything seems to be such a big problem on this car, and not having chosen a flip-front, any splash panels I fit under the wheel arches must be removable for access to other things.
I plan to put in anchor points for and aft, and attach the panels with self tappers, so I can remove them for any maintenance.
I had intended to stick the anchors in with fibre-glass paste, like I have just about everything else, but having spoken to WCA, I will use Sikaflex, as he told me a horror-story about fibre glassing that he did on the underside of his bonnet.
Having painted his car very nicely, he decided to re-inforce the underside of the bonnet as it was a bit too flexy, so he went ahead and did the usual resin,matting and build up to make it stiffer.
During the drying/curing process, maybe due to the heat build-up or the contracting forces, his bonnet developed "fluting" wrecking the paint in the process. You would have to look very closely to see it, which I did, as its not very obvious, and I would not have noticed if he'd not pointed it out.
Anyhow, not wishing to have the same problem, I decided to stick my panels to the underside of the wing with Sikaflex, which should not have the heating problem.
So today I got the first of four anchor points in place.
To these I will screw on the splash panels, and hopefully not get a battery-box full of water.
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
1st June 2015, 16:31
I think that was largely caused by him being a cock and slapping too many layers on too quickly but not worth risking it after all your sanding and mopping
1st June 2015, 16:46
Very well put WCA!
You certainly have a way with words!
Really...
1st June 2015, 16:51
Nice Shots and XJ13
Nice shots, thanks
You can buy a replica XJ13, but you probably need to win the lottery first............
http://www.twrreplicas.com/
Regards, Mick
1st June 2015, 19:43
Yeah I'd seen them
1st June 2015, 20:25
Yeah, there was a company down near Exeter that used to make the fibre-glass bodies, but when they went bust I lost my £2500 deposit, or I'd be driving one now.
I still have the rebuilt engine, gearbox and all the bits I never used!
1st June 2015, 23:37
Wow
2nd June 2015, 07:03
Youravinalarfintcha?
£5,000?
www.ebay.co.uk/itm/Jaguar-D-Type-Replica-Kit-Car-/151700480526?pt=LH_DefaultDomain_3&hash=item23520d a20e
2nd June 2015, 07:39
I wonder who made that shell?
2nd June 2015, 07:56
To state the bleedin obvious there should be a matching mould somewhere, more precious/valuable than the shell, which seems to have suffered from handling abuse.
2nd June 2015, 08:53
Is it just me or does that front end look more like an e-type than a D-type?
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
