25th January 2019, 18:56
Part 2
When I pulled the leather inside out and put the foam put back in gave me this.
Hopefully, by time I trim the bottom corner edges of the plywood I will be able to smooth the leather out better.
This is the passenger side, which means I should be able to do a better job of the driver's side.
25th January 2019, 18:57
Did you round off the plywood edges to prevent tear through? Hope so.
26th January 2019, 06:30
Molleur – My apologies, after re-reading my last post I realise I should have been clearer…
When I wrote ‘trim’ the bottom corners of the plywood, I actually meant ‘round off’ the bottom corners.
As these bottom corners are definitely trying to poke though the leather at the moment.
So I will be taking my angle grinder to the plywood at some point to fix that little issue.
(All the other edges of the plywood were sanded smooth after I cut the shapes out.)
Effectively, the shape of the leather, when fully sewn up, now determines the final shape of the plywood.
Which means the final headrest will not actually be a perfect match to the original cardboard template.
But, hopefully, the shape will still be close enough and that is certainly good enough for me.
Based on what I learnt from making this first one, I am going to make one key change for the second…
As I’ve decided to join the two edge pieces at both ends before I start sewing them to the face.
I need to be very careful about how I measure the length of material required, but it should work.
This will also allow me to position the two edge joins symmetrically along the bottom of the headrest.
As I messed up the position of these joins along the bottom edge of the passenger side.
This was mainly due to the fact I forgot that both edge pieces had extra length added to them for ‘pinning’.
(So I shouldn’t have joined them together the first time at the very ends/edges of the leather.)
Unfortunately, I only remembered this after spending a long time sewing and I couldn’t face starting again.
The good news is that very few ‘normal’ people will ever notice the difference in the real world.
And anyone who wants to point out this design fault in the headrest will be told where to shove their own head.
Finally, I went through my original build thread to check how I joined the passenger hump to the bodyshell.
I’d forgotten that it took me two attempts to get the fixing brackets lined up properly at the bottom.
Which accounts for the surplus holes in the face of the hump.
Thankfully, there are no brackets behind the upper section of the face where the headrest is going.
At some point I need to do some testing of hole sizes for the ‘fir trees’ in both the plywood and fibreglass.
Luckily, I have plenty of spare stuff to practise with.
Looking back at all the Frankenstein cutting and shutting I did on the bodyshell is scary!
Those brackets are either side of the 'scar' left after I cut the whole rear shell in half.
I'd also left a gap in the brackets for the cut through the humps I was planning for the boot.
In fact, I still can't quite believe that I actually got this car on the road at all!
26th January 2019, 07:51
Paul - you certainly are on the road, and I thoroughly enjoyed my Swordfish experience. I think it may be the car that has had the most forum members in it.
Your build thread filled many of us with awe. Your ambition and relentless drive put me to shame. And, you provided the most comprehensive build thread of all time..that included summerhouse cleaning and hedge trimming tips.
The fact that you built the Swordfish outdoors makes me shudder at the thought. On that note, my new garage is now at waist height, and should be ready to take the car sometime in February. Then I just have to kit it out (garage not car) - electrics and lots of perusing of the Rapid Racking and the SGS Engineering websites.
26th January 2019, 12:19
Ditto Oxford1360 comments!
26th January 2019, 13:13
27th January 2019, 08:44
Oxford & Molleur - Will you two behave, as you are going to make me blush.
Jokes aside, I found other build threads really helpful so it seemed only fair to me to cover my build in the same way.
Initially, I just wanted to show that if an accountant with no car building experience could do this, anyone could.
Little did I realised at the time just how much work my unconventional Frankenstein HillBilly build approach would take.
But the one thing I hope came across from my build that was that if you keep chipping away then it will get finished eventually.
Sure I made mistakes, went down blind alleys, completely underestimated how difficult building outside (on a sloping driveway) would be, etc.
However, the bigger the obstacles during the build, the bigger the sense of of pride at the end when you know you overcame them.
I'm currently working on a reply to a thread on Rods 'n' Sods' about why so many projects don't get finished?
As I've come to the conclusion that, at some point, the sheer scale of the work left to do makes builders lose heart.
That, and the fact that 'Life' has a habit of getting in the way and a car project must always come second to family & health.
I remember posting about reading the Harry Potter books to my children and I would never trade that time for a faster build.
Which leads me to one of my favourite build motivational quotes:
How do you eat an elephant?
One bite at a time."
The reality for me is that as long as you are making some progress, no matter how small, or how slow, it all counts towards finishing.
I've also come to the conclusion is doesn't actually matter how long a build takes, the real achievement is getting the car on the road.
One of the best builds on Rods 'n' Sods took over 20 years to get from this…
To this…
And that included retro-fitting stuff to pass BIVA after the DVLA withheld his V5C.
Anyway, my apologies, I seem to have started rambling.
Oxford - Great news on the garage building.
I am really looking forward to seeing work on your car resuming, as your own take on how to build these cars will be special when done.
Jag - How exactly will this save me time and trouble after I have finished making my own versions?
Jokes aside, the headlight covers were really just a stepping stone to making the headrests.
Some progress…
Sorry about the terrible photo, but I started by joining the two edge pieces for the driver's headrest together at one end.
I then wasted some time trying to position the two joins evenly along the bottom edge.
As after lots of measuring and re-pinning and more measuring I finally realised I could just move the material after it was joined.
Therefore, all I really needed to do at this stage was get the length right and mark up the lines needed to sew and cut along.
As you can see below, once I had finished sewing the other join, the position of the joins relative to the corners can just be moved along.
With a bit of luck I will get a chance to join this edge to the 'face' later today.
Reason: Typo
27th January 2019, 14:01
Apologies - Yet More Bad Photos…
As soon as I started to pin the pieces together I realised I had made yet another schoolboy error.
As I forgot to take into account the effect of sewing around the corners which puts folds in the leather.
By the time I had sewn together a section of the bottom edge it was clear the edge piece was slightly too long.
So I had to sew the pieces together from number of different starting points until I was left with just this corner to do.
Impossible to see from the photo, but the holes for the stitches on the face are further apart than those on the edge.
So for the same number of stitches, I was joining the longer edge piece to the shorter face piece.
This resulted in the collection of 'extra' folds in the bottom left hand corner when looking at the inside.
I then pulled it all inside out and put the foam back in.
Which left the front of the headrest looking like this.
Thankfully I gave up any noble quests for perfection in my build many years ago, so this is certainly good enough for me.
Next steps are to sort out the final plywood shapes and test/drill holes for the fixing 'Fir Trees'.
28th January 2019, 15:22
Just a quick update...
I spoke to the garage earlier today and I have an impressive mix of leaking oil seals and gaskets in both the engine and gearbox.
So it is definitely engine out time!
Based on my previous chats with them, I fully expected this, especially as I occasionally get the feeling of clutch slip too.
So I've authorised them to do whatever is required to sort this mess out once and for all < Touch Wood>.
Even though the final bill will be in the eye watering category, it will be well worth it.
As the reality is that even if I had the first clue about fixing engines, I have no where to do the work.
I would also like to travel longer distances with confidence and do a track day at Goodwood.
(And know from my motorcycle racing days that those who leak oil on a race track should burn in hell! )
29th January 2019, 18:14
And still the bad photos come…
I had a chance to take some photos of the headrests in the daylight which I hope makes them easier to see.
(Obviously, I can't pull the leather tight at this point.)
As there is snow promised I had to get side tracked for a bit clearing twigs & leaves and other crap off the lawn.
This makes it safer to walk across the grass down to the Summer House when it is covered in snow.
By the time I'd finished, it was dark, which is the signal for more rubbish photos to appear.
The tidied up garden.
One of the plywood headrest pieces after smoothing the corners with my angle grinder and sand paper.
I don't have an upholstery stapler, so I wanted to test if the 'tacks' I do have would hold the leather in place.
So some spare leather and plywood were joined together.
The good news is that I was able to pull the leather tight over the edge with no problems.
Finally, I tested two layers of leather as I am sure there will be some folding going on when I actually fix the headrests in place.
Next job will be testing hole sizes for the fixing 'Fir Trees'.
Until then, take care, Paul.
31st January 2019, 15:52
OCD Relapse
After all this time building, you would think that I should be able to leave little problems alone by now.
But no.
Unfortunately, the more I looked at these little ripples in the driver's head rest, the more I knew I couldn't live with them.
So I marked up the offending section.
And removed the stitching.
As I'd already trimmed off the excess material I came up with the idea of bull dog clipping the leather together.
Do not adjust your eyesight, the photo is blurred.
The good news was that by pulling the face to meet the edge, it looked like the ripples could be removed.
The bad news was that this would cut a chunk off the corner of the head rest.
This crap photo is showing where the original line of the corner was on the plywood vs. the leather.
Now if the small ripples were going to bug me, there was no way that I could live with this odd shape on one side.
So I decided to resew the face in its original position while trying to 'tuck' the ripples behind the corner.
This this sounded like a plan in theory.
It even seemed to work went I held it all together by hand/clip.
But in practise, there was no way that I could excess material 'go away' neatly .
Remind me whose dumb idea it was to do this job myself?
End of Part 1…
31st January 2019, 15:58
Day 2:
Having walked away from a mess of my own making, I came back for more self inflicted punishment.
I had actually convinced myself that I needed to unstitch the whole thing and start again with two new edge pieces.
Thankfully, it dawned on me that just lengthening the bottom section would be enough.
So after more removing of stitches, the old bottom panel was out and a longer piece prepared.
With one side done I was facing this corner for at least the fourth time.
At long last the face was all sewn back together and at least looked 'flat' on the inside.
Which corresponded with a much smoother looking front side too.
(Remember the leather is just folded over the foam and not pulled tight.)
The only fly in the ointment came as I remembered why I was going to remove both edge pieces.
Yes, the joins on the both are not equal distance apart.
Yes, the ripples had bugged me so much that I'd forgotten that the joins weren't 'right' either.
However, when I rediscovered this as I was sewing I may have turned the air blue for a prolonged period.
But, I do here by solemnly swear that I will leave this head rest as it is, fit it and forget about it.
31st January 2019, 16:23
High marks for persistence Paul!
1st February 2019, 18:26
Molleur - Thanks.
Quick Update
The good news is that I heard from the Triumph garage today that my engine is back in the car.
So subject to a final check and engine set up I might get the car tomorrow.
The bad news is that my garage currently looks like this.
At least I shouldn't need the oil drip tray any more.
Reason: Typo
3rd February 2019, 07:31
Honey, I'm home!
As always, there was a nice collection of cars in Enginuity when I went to collect my car.
Including this Trident Venturer.
But their Instagram account gives you a much better idea of how packed their workshop was.
( The Daimler 250 was particularly nice. )
https://www.instagram.com/p/BtYB9pllcDg/
Actually, my car made their Instagram page too.
( The Winter sun makes my car look more 'survivor' than usual. )
https://www.instagram.com/p/BtYCy0RlDV3/
Despite the cold, the car ran really smoothly on the short(ish) journey home.
( Unlike the bag of nails it was when I took Mister Towed for a spin. )
The garage replaced countless oil seals and gaskets and repaired a number of stripped threads.
( Which should mean that everything is now joined together tightly the way it is supposed to be. )
Also, a closer inspection of the carbs revealed this bent needle, complete with mole grip marks.
( Not a great photo, but hopefully you get the general idea. )
Thankfully, all the roads were clear of snow with the exception on my own driveway.
( Which spends most of the Winter months in the shade. )
I took it very gingerly parking and aimed high up the slope just incase the car started to lose grip.
( As I had a real fear that the car would simply slide gently down the slope into the side of the house! )
My wife and I were heading out shortly after I got back, so no chance to check the headrests, etc.
5th February 2019, 14:37
A bit more done…
These are the 'fir trees' that will hold the head rests to the aero humps.
So I took a scrap piece of plywood and drilled a test hole.
Which turned out to be the perfect size for a friction fit.
Then it was time to cut yet another piece off what remained of my bulkhead.
And put a test hole in that.
I then put a hole in the bit of plywood I had been testing leather tacks on.
As the leather will be pulled over the back of the plywood, I joined the two pieces together like so.
The front face would look something like this.
Except that there would be the foam and leather in front of the fir tree 'dome'.
Despite the fact the fibreglass off cut was not completely flat, this was a very solid join.
I then drilled four holes in each of the real plywood head rest pieces and sanded all the edges down.
Before adding the first coat of wood preserve.
Given the cold weather, it may take a while to get a couple of coats on both sides.
Reason: Typo
6th February 2019, 15:59
Watching wood preserver dry…
One more coat after this one should do it.
Had just enough time to unwrap half of the car.
And to start mocking up the gear lever gaiter.
My current plan is to leave a big enough gap at the top to slip over the gear knob.
Then use some elastic to pull the material closer together over the lever itself.
I then make a few rough and ready markings to give me an idea of the material required.
Which looks something like this when unwrapped.
So that will be the next sewing project when I get the chance.
6th February 2019, 16:48
Paul, did you get the cloth from Turin by any chance?
7th February 2019, 14:35
Barber - You're not the messiah, you're a very naughty boy.
Odd Jobs:
Test fitted the headlight grille covers and they seem to work OK.
Because I need to align the 'ears' I made with the three fixing clips, I have marked the covers like so.
I just need to sew this into the material and trim the excess elastic and that job is done.
Next I put some masking tape on the aero humps.
Before test fitting the plywood from the head rests.
In this layout, the bottom corners are equal distances from the body shell on either side of the hump.
But this just looked a bit odd.
So I switched back to a layout where the bottom edge is vaguely horizontal.
Whilst this does highlight the 'step' in the body shell, from one side of the hump to the other, it will do.
As the bottom line is I should know better than allowing a straight edge to come anywhere near the car.
So before I could change my mind, I marked up the holes for drilling.
In the photo above:
- The bottom edge of the masking tape runs parallel to the bottom corners of the hump.
- Where as, the bottom three holes align with the bottom of the headrest (middle hole is lower on purpose).
The good news is I keep coming back to my real world experience that no one else will care!
End of Part 1…
7th February 2019, 14:38
Part 2:
Unfortunately, by now, the clouds were beginning to gather overhead.
So I quickly switched to mocking up the leather gear lever gaiter…
I started by making a rough cardboard circle to match the widest part of the gear knob.
Which will leave me with this much material to 'gather' once the gaiter is slipped into place.
I am now thinking I might simply use a cable tie to pull this together, rather than elastic.
As the cable tie could be simply cut off and replaced if I ever need to removed the gaiter.
( A bit like the one that was holding the overdrive wires to the lever. )
I still have too much leather at this stage, so I had to mark the join like so.
( With the tape on the outside of one edge and the inside of the other. )
Last job of the day was to have a look at how a mirror plinth made of alloy sheeting might work.
( As I currently have more than I need to panel the cockpit interior. )
Note: I want to reuse the existing mirror holes in the side of the body shell.
But I think this will lead to a clumsy design, so I dug out the photos of my last design idea.
Which was going to be done in metal, with a couple of tweaks to the rod layouts & lengths.
The scary thing is that these photos were taken in March 2015!
So lets see if I can finish the job before four whole years have passed.
Anyway, at this point it started to spit rain, so I put the covers on.
