Old 10th March 2007, 20:11
craig's Avatar
craig craig is offline
Really hope you sort it quickly as I have never heard the demo car running so am looking forward to hearing yours and it will give me a spur to ensure I am finished for next spring.
08 plate
Old 10th March 2007, 20:39
alackofspeed's Avatar
By the way, the ECU pin outs are in the Helm RSX manual - I hadn't looked closely enough before, but found them today when scratching my nuggin and double checking my wiring.
http://downloads.hondatech.info/Auto...e%20Manual.zip
Pages 263-269, section 11-20 onwards.
Old 10th March 2007, 20:46
craig's Avatar
Cheers John, will have a good look tomorrow tried to sort it today but stuck on that one pin
Old 10th March 2007, 21:09
craig's Avatar
Just had another look at the wiring from that file and I it defo looks like I dont have a pin 8 on ecu e plug heater relay, never been one there either it's just blank........hhmmmm
Old 10th March 2007, 21:23
ahhh.... that's one of the subtle differences between european spec and US/JDM - I believe it's because they use variable current wideband sensors, whereas european cars with PRA ECUs (I think that's right, but ECU is in the garage...) are designed for zirconia narrowband sensors.
The us/jdm ecus, can by virtue of their wideband interface, work in closed loop target lambda mode (the wideband sensor works from about 11.5:1 to 30:1 AFR), whereas the narrowband sensors only work as glorified switches, so they are only any good for closed loop dithering, and the ecu runs in open loop mode once beyond a defined load point.
www.johndry.com/pra_wiring_diagram.pdf - might help.
Old 10th March 2007, 23:57
craig's Avatar
Not sure whether it's just my browser but that file is not ledgible John and the mag button just blurs it more?
Old 11th March 2007, 12:43
ooops - I should have checked the PDF closer.
try this:
www.johndry.com/Engine_loom.doc
Old 11th March 2007, 18:04
craig's Avatar
Cheers John, been pouring over the file for an hour or so and there sees to be a few differances to how mine is wired
1.I have the main relay pin 87 spliced to pin 85 on the fuel pump relay which in turn runs to 02 heater relay(diagram main relay 2) but it seems spliced to pin 86 in your diagram not sure where it runs to blue square with an a in it?
pin 86 on mine runs to e1 grn/yel
2.Pin 86 on my main relay runs to e7 red/yel but again on your diagram seems that pin 85 runs to e7 red/yel
This is based on the fact that it matters as I don't know a great deal about relays other than they are a switch
3.can't see 02 relay anywhere?
4. Totally fu**ing confused now...........
Old 11th March 2007, 20:27
Craig - on my type-r donor, there was no relay for the O2 sensors, all wires went directly to the ecu.
On standalone ECUs I've installed in other cars as a matter of routine I've installed relays for the lambda heaters, as I didn't fancy flowing teh current through the ECU. I was toying with doing the same with the Honda ECU just to be sure I didn't zap it.
I believe the JDM / US cars have relays, as they work with the wideband lambdas, which have different power requirements. I might be wrong though.
The 2 PGM-F1 relays on my donor were wired in exactly as shown on the wiring diagram document posted above.
There's a constant fused 12v feed to pin 30 on relay 1, an IGN-1 feed to pin 85, 86 goes to the ECU (which switches to ground when the ecu see an IGN1 feed on E9). Pin 87 goes to pin 30 on the second relay (fuel pump). The other pins on the second relay are as follows: pin 87 to the +ve side of the fuel pump, 85 is linked to pin 30, and pin 86 goes to the ecu, which again grounds when activating the fuel pump (2 seconds when first turning the ignition on, and then continuusly when seeing a crank signal).
It's certainly quite a brain teaser sorting it all out! Check out the laughably messing current state of my wiring.
http://www.johndry.com/gallery/main.php?g2_itemId=8479
Old 12th March 2007, 09:44
craig's Avatar
That picture is certainly interesting I would not know where to start! I'm going for the bare minimum with wiring, I think that I am going to spend the day trying to get my ignition sorted so that I have power at least
I did my engine mount last night (gearbox) after an hour or so it was sorted and looks at lot more upto the job.....but I had made a crucial mistake one that I would not normally make if I weighed things up properly but it was late and I wanted to see it finished.
I had not taken into account when welding the new mount in place the flexability of the new one so when I dropped the weight of the engine back down (yes you have probably guessed it the engine sloped slightly)
My own fault so off it came re-welded and back on looking good
Craig
Old 12th March 2007, 10:01
craig's Avatar
I have hopefully put a picture on and will try for another
Old 12th March 2007, 10:05
craig's Avatar
Another one
Old 12th March 2007, 10:10
craig's Avatar
Last one
