20th February 2017, 20:42
try sikkaflex or carbond its what the body shops use in the uk avaliable on e bay in tubes for use in a skeleton gun, various colors ,it works well on most surfaces.
21st February 2017, 07:54
I've just used Tiger Seal. It's worked very well.
6th March 2017, 15:49
Hello,
i finally bought some Terroson 5065.
Quite expensive, around 140 € for 3 tubes !!
So , now the kit is drilled
I still have to clean the paint and i hope to glue it at the end of the week
if it's not too cold.
Gerardo
6th March 2017, 16:01
crikey !!! thats expensive does it contain gold dust !!!
21st March 2017, 20:32
Rear is bonded
Hello,
today was a great day : i bonded the rear
I applied the bonding agent Teroson 5065
it was quite liquid.
I applied it to all the part where i had clean to metal and applied more just before placing the rear.
A few rivets later and now i have to wait 2 or 3 days for it to cure completly.
Gerardo
5th June 2017, 11:18
Color choice
Hello,
the build is going on slowly.
But, time is coming to think about the color of the car.
I was thinking in a very dark red, but i couldn't find the right colour (too dark or too red...)
but yesterday i saw a new Ford Fiesta in Ford Bohai Bay Mint.
That's completely different, but I really love that colour. there is a colour quite the same for the Fiat 500, but the Ford seems to be the one for my Mx250.
Still a few month before sparying the car , so i have time to think about it....
Gerardo
7th June 2017, 19:39
Under tray splash guard
Hello,
just a quick question :
do i have to keep the under tray splash guard (see attached picture)
or should i take it off ?
Gerardo
7th June 2017, 19:41
Personal choice there I think...
8th June 2017, 08:20
No need for it, mine has it removed but my son has his fitted. It may help with directing air under the car and hence help cooling.
11th June 2017, 06:13
Gerardo – Sorry for the delay, but I’ve finally got around to adding your build to the ‘Useful Info’ thread.
The idea of using that ‘Mint’ colour is an interesting one.
I think it could help to ‘age’ the car and there were certainly old Ferraris painted in pastel colours.
26th July 2017, 07:58
Fuel tank
Hello,
I finally connected the fuel tank to the new fuel filler neck.
There is the second small diameter pipe coming out of the tank.
I suppose that this is the breather.
How do you handle it?
Can in close it (my new fuel filler is vented)?
Gerardo
26th July 2017, 08:35
I connected it to some clear petrol pipe with a push fitting. I the drilled the top bend and epoxyed a rivnut to it which allowed me to attach the pipe to it, I simply used a small cable tie to hold it on. This is on the Z3 but I would expect a very similar setup on the MX5. fuel7 by jaguartvr, on Flickr
12th August 2017, 19:00
One more question :
what type of rubber seal are you using to avoid water and air coming over the windows ?
Gerardo
