Old 27th February 2017, 14:05
SwiftyDS SwiftyDS is offline
Looks great - love the stripped out interior look. Have you decide on what you are doing with the dash yet?
Old 27th February 2017, 14:07
I have toyed with doing a Sierra/RS200 replica dash for my build but was struggling to get something close that still retained the air vents/screen demister and meant I could keep the passenger air bag. There are plenty of Ferrari replica dashes that build around the MR2 dash but they just look like tarted up MR2 dashes in the end!
Old 27th February 2017, 17:43
Badrep Badrep is offline
Badrep is on a distinguished road
Going to a very minimal look - Keeping to IVA radii as much as possible but as bare bones as possible - think I'm actually going to weld a few bars across the roll cage to make the dash.
Something along the lines of this but with the IVA in mind!
Old 21st February 2018, 08:46
Nostromo Nostromo is offline
How are you getting on with your build Badrep? We need some up to date pictures Bet it'll go like poop off a shovel with that motor in!
Old 21st February 2018, 08:55
I actually had to abandon the Volvo engine It was mainly for IVA issues.... but I did get a 2zz in there that I'm hoping to turbo at a later date.
I've been meaning to do a write-up for a long time... a lot has happened but no body yet - all interior and engine so far.
I'll just leave this little teaser here for now
Old 21st February 2018, 10:04
Well that looks awesome... no even a little bit jealous
Is the screen to act as a stereo and/or gauges? 3d printed panel? I assume you've gone along with the plan of removing the whole dash and replacing it with bars hanging off the roll cage? So many questions...
Old 21st February 2018, 17:17
OK - so here is the update - slightly mixed up order but to make it easy to follow I've done it in sections!
ENGINE
It was at that point when I realised that I was going to have to IVA the car as I'd created a notch in the chassis (instant IVA). After MONTHS of thinking about it I decided that I was not going to do that - way too much complication for what was meant to be a simple kit. So I went 2ZZGE - a common swap for the MR2 Roadster - this will produce half the power that the Volvo would, but still a pretty good 200bhp per tonne so enough.... I do plan to turbo it at some point ($$$) so will be looking around the 400bhp area once done. I just want to get it on the road first before I do.... it's been too long!
This did mean that I had to weld up the hole again though!
2ZZ arrived in early Jan
With downpipe and header from Rogue Motorsport via SJ autosport
6 Speed box with LSD and custom Gear Selector too:
And unlocked Celica ECU
First thing was to splice the Celica ECU with with MR2 one - this took ages to get my head around, however was really actually quite simple once done - it took me a day and a half to do, but would probably take me an hour to do if I did it again now I know what I'm doing!
I then removed the head to check the lift bolts and condition inside (as the outside was filthy!) - all seemed pretty good!
And did a very bad job of wrinkle paint on the cam cover!
Before installing it
And it fired up pretty much first time (other than an immobiliser issue that was quickly solved)
Here is a vid of it starting:
https://youtu.be/2nXUdBjyIZY
Really pleased!
Old 21st February 2018, 17:18
So, this has been a long time in the making.... but inspired by a flurry of MRS200 activity here I thought it was time!
The Roll cage took a very long time - mainly because I'm not a great welder, didn't have much free time and only had a tiny space to work in!
Tacked into place:
Then welded in sections:
Then assembled in the car and welded in:
I then mocked up a centre consol:
I managed to re-use the existing heater controls too
I then painted the cage and centre consol
That took ages.... ages and ages!
Old 21st February 2018, 17:20
Then comes the beginning of the 3D printing - started with the guage pod - I bought a set of VDO guages then started CAD modelling them.
The part was deisgned to fit around the cross bar on the roll cage - it bolts straight on there with a bracket.
It then modelled the handbreak surround too:
and send them to print - here are the printed items in their natural finish off our SLS machines.
The parts were then dyed black and polished
And assembled
And then installed:
Followed by some seriously amateur upholstery!
Which was then installed
Old 21st February 2018, 17:21
I also did a bit more printing after that for the heater control guages - I had the OEM unit, but no facia to match - I also had to relocate the buttons as they would clash with the cage.
I also integerated the hazard light switch too:
And dyed black to match
Similar with the gear gator surround:
I then took the old gator and cut it up:
Did my first bit of sewing ever:
Then Double Din Stereo - Because RALLY MAPS!
In the mean time I'd also painted the interior, engine bay and roll cage - all with Raptor bed liner paint with a roller - it works pretty well if you use a lot of rollers and do it in sections as it cures quite fast. Makes it a bit more expensive.... but worth it!
Seats have arrived too:
Old 21st February 2018, 17:22
Finally it is time for assembly!
It looks awesome...
I've still got a little way to go..... but then I'm on the the body.... FINALLY!
Old 21st February 2018, 17:46
redratbike's Avatar
Wow that looks great
Good move on the engine ....imagine doing all the work to have a messy Iva ...you do hear of horror stories
Old 21st February 2018, 17:49
Barber's Avatar
Barber Barber is offline
This is impressive.
Old 21st February 2018, 17:53
Man, that looks awesome! Really impressed with the 3d designed and printed dash. Reminiscent of the original without being a carbon copy. I'd like to point out that you felted the other side of the bit that says felt this side joking aside, great job! Good idea on the rally maps. You'll need to find a GPS sat Nov voice that sounds like Robert Reid.
Old 21st February 2018, 18:01
molleur molleur is offline
Impressive!
Old 21st February 2018, 20:56
JG's Avatar
JG JG is offline
Big Cheese
JG has disabled reputation
Very impressive, love the 3D printed parts and the overall look of the interior, great job
Old 22nd February 2018, 06:07
DaveP DaveP is offline
I echo what all have said.
Well done that man!
Old 23rd February 2018, 07:21
Wow Badrep - how fantastic! 3D printed parts would put many production kits to shame.
