Old 5th October 2019, 17:14
andysharrock's Avatar
Talking
quick update on today's work after measuring 10 times I worked out the grill was an inch to one side so that has been pulled out and glassed back in and the slots have been roughed in each side of the grill,
thought it would look good with an air scoop so a bit of card and tape latter came up with this
I glassed over it then when it was dry pulled it of cut it down and glassed it back on minus the cardboard
hopefully this should be the last sanding down so I will put a bit of primer on to see how it looks
Managed pick up a 2.8 1997 local to me for a change well that can only mean one thing next kit ordered just don't tell the wife
Old 6th October 2019, 16:57
front end is coming together now will just needs fine filling and sanding
I wasn't going to put vents in the rear end but things change lol, I will see how it looks as things progress it can always be filled back in the beauty of fiberglass
Old 6th October 2019, 17:11
Looking forward to seeing the final result on this one. I think the rear grill vents will add to the final race inspired version you are building.
Old 16th October 2019, 12:53
quick update spent most of the weekend removing the dash ready to fit the new one .there is a lot of work in making up the dash the old top under the window screen needs to cutting off the old one and be bonded onto the new one to keep the air vents. also the sides where the dash bolts onto the body also need cut off and bonded on.
this is a pic is not the best but its of the underside of the new dash with the old vent boneded on
trial fitting of new dash still loads to do i've filled the middle in with a bit of spare fiberglass
I have taken a mould off the top so I can pad it and cover it in leather then stick it back on when the dash is covered. not pretty but it will do the job when its cut down
this stuff is my savior setts in 5 to 10m mins expands setts like rock and can be sanded back what else do you need from a glue. just run out but 12 tubes on the way.
bring on the weekend
Old 21st October 2019, 12:49
Default dash vinyl wrap
spent 4 hours prepping the dash applied a heat proof glue then wood grain vinyl wrap stood back and looked at it bleeding horrible so off it come again.
striped it again primed and painted satin black if I change the colour again it will be while it's in the car its a pain in the arse to remove and refit
think I can live with it for now still work to do as always but its back in all working
not 100% what to do with the carpet its tan colour I have got some black die that's a job for next weekend thou
