Viatron - Hi Mac, this frame difference was at the front, causing a problem with the floor.
Although the fix you have done at the back covers the issues I had with the wheel arches not lining up.
As I said to
Mr T I am not looking forward to checking for voids, but my shell really needs it.
All tips and advice are always welcome.
Bank Holiday Monday:
First job of the day was a trip to Machine Mart to pick up some welding wire.
Was reminded of a Phil & Barry's run out as I passed two classic racers in convoy.
Not sure what they were, but both looked something like this...
I then passed a Bugatti Veyron Convertible going the other way on the way home.
Must be something about the sunshine that brings everyone out.
Anyway, back to my build & I started by welding up the holes in the passenger side floor.
It was really windy outside which wasn't helping, but I did get it all sealed up.
( Not that you will be able to see much of a difference in this photo.
I started working on the floor as I didn't want to start the angle grinder up before mid-day.
I then got the rear frame back out so I could work out where to put the rear seat belt mounting.
I am going to use my 3 point harness & want it to start behind the seat around here...
Initially I was going to run box section across the whole length of the cockpit.
Thankfully I remembered that the petrol tank needs space to be fitted.
So I decided to build a 90 degree frame that would extend from on top of an existing frame rail.
So it was time to set up a workshop picnic area to start cutting the box section to length...
This is what I ended up with, although the edges will be angled to match the frame when welded in...
Obviously I needed a matching set of box section for the passenger side too...
My wife took our girls to visit her sister, so I was able to set up another picnic inside the circus tent...
As by now it was just too windy to weld outside & the tent felt like it wanted to take off too.
If my bracket doesn't end up square, it will not be for want of trying...
Once the first two pieces were joined, I had to clamp everything together to get the 3rd piece in position...
Once the first joint was welded I could remove everything else & finish off all the sides...
Then it was time to clamp everything up for the final time...
With the seat belt mounting plate in the middle of the box section, I could weld on both sides.
But, unfortunately, my mate's welder decided to cut out at this point as it got too hot.
So I returned inside to do some hoovering (I kid you not) as I can't spend all day playing with my car!
Eventually I got back out & managed to finish one section completely...
I had been matching the other side section by section, so that is nearly done too.
( The welder packed up again as it was actually pretty hot inside the tent despite the wind outside. )
I will be the first to admit that my solution may have a
hint of over engineering about it.
But I am pretty happy that this be good and solid when finally welded to the frame.
It only took me 45 minutes to back up this evening, so I'm getting quicker.
The frame is now tucked away & under a cover given the weather forecast of rain...
I then had to spend some time pruning in the garden before the family returned.
Then my girls helped me take down the circus tent, which they really love.
Unlike my wife who has now insisted that this is never put up on the front drive.
Anyway, another good day's work, still a bit to do on these brackets, but getting there.
Quick Quiz - Just for fun:
What is the difference between this photo of my bracket which has cooled down...
And this photo of my bracket that was still very hot to the touch after welding...
Obviously the answer is there is no difference, which is why I picked it up with my bare hands!!
I was actually using the angle grinder outside the tent to dress the welds.
As I figured sparks inside the tent was not such a good idea.
So I kept changing gloves from my welding ones to my normal working ones.
Either way, my mind was clearly not thinking straight when I grabbed it.
