17th February 2020, 18:37
Does my rear look good.........
After hours of fettling I've finally finished fitting the rear lights and bumper.
Rear Lights and Bumper by Sabrebuilder, on Flickr
To meet the IVA requirements the fog light is positioned more than 100mm from the brake light and I've added push-on PVC trim to cover the 'sharp' edges of the bumper. The stainless steel exhaust tips are genuine BMW accessories which look smart and have rounded edges. Reflectors are still to be added. I was really lucky to find the chromed badge plinth in the box of bits that came with the car.
Next up will be finishing off a few small jobs in the engine bay before the final fitting of the front inner wings.........
....peter
25th February 2020, 18:52
A little update......
Just a little clue of what I'm working on in the garage this week...........
Radiator grill by Sabrebuilder, on Flickr
29th February 2020, 20:35
Originally Posted by kon
Looking good
Is that the alternator immediately below the new screen washer bottle? My aim when filling up the washer fluid in my car isnt the best, so do you think it's worth putting in some sort of shield to protect it? I believe alternators are one of the few things in an engine bay which dont take kindly to getting wet.
I got around to making a drip tray to stop any screen washer over-spill getting into the alternator.
Windscreen washer bottle drip tray by Sabrebuilder, on Flickr
The edges were turned up to stop any over-spill going off the side and to add stiffness.
And here it is in place....
(the last picture has made the shield look smaller due to perspective but it is actually wider than the bottle and slopes back towards the bottle)
Thanks again to Kon for pointing out this potential problem.
...peter
1st March 2020, 02:39
Well done!
1st March 2020, 17:35
Radiator Cowl Grill fitting
Thanks, Jack.
Over the last week or so I have been fitting the trim and grill to the radiator cowl so here is a summary of how I did it.........
I first fitted the chrome/plastic trim. This comes with an adhesive bead inside that is supposed to stop it coming off. On the day I fitted it, it was very cold in my garage so I put the trim in the tumble drier for a while to warm it up and make it easier to form round the bends. Plastic trim has a tendency to shrink over time so I cut the trim about 3mm oversize and then forced the last section in so that the joint is under compression.
Radiator cowl trim by Sabrebuilder, on Flickr
I then cut the grill to size. I have chosen a stainless steel mesh with a 5mm pitch. My tin snips could only manage one wire at a time so a slow process to get the right shape. I bought two pieces of mesh, each 200x400mm because that was cheaper than one large piece. I then polished the front side of the grill.
Radiator grill fitting by Sabrebuilder, on Flickr
Then I glued a length of rubber hose with PU18 adhesive to the cowl. The hose is just a gap filler to attach the grill to. (Note: I later discovered the PU18 softened the black 'schultz' coating my painter put on the inside of the cowl so I had to redo this stage after removing the schultz to get a good bond with the GRP. A messy job with white spirit but no harm was done)
I then made up the centre clamping bar made from 1mm steel strip.
I then held the grill tightly in place with some wooden splints and cable ties......
....before running a bead of adhesive along the grill above the rubber hose making sure it was pressed down to fill any gaps.
So here is the final result fitted to the car!
Radiator Grill final by Sabrebuilder, on Flickr
I'm very pleased with the result
Next up will probably be the bonnets.......
.....peter
1st March 2020, 19:58
Looking Great! Lovely finishing touches
1st March 2020, 22:37
Excellent job, perfect!
2nd March 2020, 08:30
Wow! That front looks awesome, excellent work
Nice splash-guard too.. sorry about the extra work
Cant wait to see this car in the flesh.
3rd March 2020, 18:29
And so you should be.
7th March 2020, 07:07
Always love your attention to detail.
Your car is going to look great.
7th March 2020, 07:34
Are you planning to get to Stoneleigh?
7th March 2020, 18:45
No, I won't be finished for this years show but maybe next year?
12th March 2020, 20:17
A bit early for Easter bonnets.....
Thanks to all for the positive feedback..........
So the next job was to fix the bonnets.
First I fixed the bonnet catches with polished stainless steel m4 screws.
Bonnet Catch by Sabrebuilder, on Flickr
Again, I was lucky to find a complete set of new catches in the large box of parts that came with the car.
The original stainless steel bonnet hinge cleaned up and polished quite well. Royale suggest you pop rivet the hinge to the bonnets but I preferred to use screws and nuts so I counter sunk the holes.
Bonnet Hinge by Sabrebuilder, on Flickr
Then, after carefully masking the top side and edges of the first bonnet I attached the hinge.
Then after masking up the second bonnet I could attach it.
Here are both bonnets joined together with the hinge. I also fixed the lower bonnet catch plates at this stage.
Bonnets by Sabrebuilder, on Flickr
I then had to fit the bonnet seal which requires careful cutting and is quite tough on the fingers pushing the seal on all the way round.
The bonnet seals close off the engine compartment so that only fresh air can enter the heater inlet. (Which is an IVA requirement).
Bonnet Seal by Sabrebuilder, on Flickr
The original builder had fixed the seal to a metal strip that was fixed with pop rivets to the four holes shown here, but it didn't really hold the seal in the right place so I made up new support strips that are made of angle.
Bonnet seal by Sabrebuilder, on Flickr
Then it was just a matter of carefully positioning the bonnets and fixing in place with the hinge end plates.
Next up I've got to make some bonnet stays which unfortunately did not come with my car and weren't in the box of spares either. I've also got to fit the seal that goes along the back edge of the bonnets. Then I hope start on the fitting the front wings.........
.......peter
12th March 2020, 22:35
Nice work as usual!
25th March 2020, 19:06
Stay awhile.........
Thanks, Jack.
This week I've been working on designing and making some bonnet stays.
So far I've come up with this...........
Bonnet stay by Sabrebuilder, on Flickr
The top mounting is designed to be 'windproof'. The stay doesn't fall out when the wind lifts the bonnet.
Bonnet stay top by Sabrebuilder, on Flickr
And here is the lower mount....
Bonnet stay bottom by Sabrebuilder, on Flickr
I'd like to get the parts plated but that will have to wait for another day.
Not yet sure how to secure the stays when not in use so the design may evolve a bit.
Now to make another one for the other side........
..........peter
26th March 2020, 05:19
Originally Posted by molleur
Nice work as usual!
+1
26th March 2020, 11:38
26th March 2020, 17:02
Exactly my initial thoughts but my current design causes the stay to rest on the engine cover which doesn't seem right to me as the engine moves slightly.
I need to rethink the bottom mount...
26th March 2020, 19:18
Winging it....
Originally Posted by Paul L
+1
Thanks Paul.
I was bit bored with bonnet stays so, taking advantage of the warm spring sunshine here today, I drove the car out of the garage so that I could retrieve some of the body panels from my garage's loft.
IVA status March 2020 by Sabrebuilder, on Flickr
Looking a bit like a hot rod without it's wings and doors
I could then retrieve some of the body panels from the loft. My wife helped me get the wing down as it's very large and awkward.
Bodywork by Sabrebuilder, on Flickr
I then laid some carpet offcuts on the garage floor and then 'parked' the car as near to the far wall as possible, giving me space to work on the nearside wing. This was the first time I have unwrapped the wing since it was painted last year!
Nearside wing by Sabrebuilder, on Flickr
The camera on my phone has made the wing look a weird shape and I should really go back to using my proper camera.
This shot reminded me of this one..........(taken Sept. 2010)
Wing removal by Sabrebuilder, on Flickr
Now I've just got to fit the wing without scratching it
..............peter
28th March 2020, 20:29
Trial fitting the first wing. I have temporarily fitted the lights to work out the wiring routing under the wing.
First Wing fitting by Sabrebuilder, on Flickr
...........peter
Currently Active Users Viewing This Thread: 2073 (0 members and 2073 guests)
