14th August 2013, 19:37
Paul, for inside corners get yourself some rubber or vinyl gloves £6 or £7 a box, you can then apply the filler using your finger to the inside corners then drag your fingers down it and you should have an almost perfect finish.
Keep up the good work.
14th August 2013, 20:18
Hi Paul,
I like what you are doing. I'm sure sanding en painting will transform this workpiece in something very pretty. And I'm confident that the welds wil hold too. I had doubts about the strengt of my own welding. On the chassis etc. But then I considered the state of corrosion that had been there in the first place. It couldn't have more then 15% of the original strength left. The welds would sure do better then that!
15th August 2013, 18:45
Mac - I was actually using those rubber gloves, but the filler was setting too quickly on me.
Michiel - Thanks, although your chassis welding looks a lot neater than mine.
Dodging the rain...
Despite the weather forecast predicting a dry day today, it kept bucketing down.
So it was quite late in the day when I finally had a chance to tidy up the body filler.
It was a complete mess in places, but at least it was set hard...
Given that this is not external bodywork, or on show in any way, it was grinding time.
Whilst this certainly speeded up the process, it did sent filler dust everywhere...
Then it was simply a case of brushing the areas down & wiping them with white spirit.
I then gave each section another coat of etch primer so they will be ready for black paint soon.
Oops, looks like I didn't actually take an "after" photo of the view above.
I needed to apply a last bit of filler on a small section that I managed to miss yesterday...
I also remembered I want to weld in a repair piece to this section of the boot floor...
This is where my rear silencers will be mounted once I have drilled some holes in the right places.
( I will also strengthen this area when the rear arches are finally fitted. )
The forecast for tomorrow is some serious rain, so we will see if I can get anything done.
I think I'm having problems with my old camera as I have just bought a new "bridge" camera.
And you know how jealous these electronic gadgets can get.
I have still got to get the hang of it, but I took this photo last night.
The view from my bedroom window during the England vs. Scotland match.
( Obviously the zoom makes it appear a bit closer than it actually is. )
16th August 2013, 08:53
Good job - It looks as if it could've just left the Triumph factory!
I hope that isn't too much of an insult...
16th August 2013, 12:00
Not raining at the moment, Paul... but i can't see Wembley today.
16th August 2013, 16:49
Mr T - I assume you are referring to factory output on a Friday afternoon?
Which would certainly account for the collapse of the British mass produced car industry.
GaryH - With that many train tracks near by I hope your windows are sound proofed.
Back to Black...
It was raining / wet for most of the morning, but I did get a break in the late afternoon.
Let me start with the "after" photo I forget to take yesterday.
First job was to give a quick grind & clean up of the body filler I applied yesterday...
Then this was given a quick coat of etch primer...
And later on, when that was dry, it got a coat of black bitumen paint...
This was actually the last bit I painted, as I did the most of the underside first...
The good news is that with all the "boxed in repairs now one colour they look much better.
The bad news is that because that colour is black it is hard to get a good photo.
Driver's side:
Passenger side:
Then I flipped the whole thing over so I could paint the "top side"...
( Note: I've left the boot floor for now, as there is a lot of repair work required in that area. )
Driver's side:
Passenger side:
So slow progress, but still progress none the less.
16th August 2013, 17:47
It looks very good. I'm curious how it all turns out when everything is in place.
Michiel
17th August 2013, 11:45
Michiel - So am I!
I will need to add spacers between the chassis & the rear mounting point of the rear arches.
This will "lift" the hand brake section higher than stock, which would have sat flush on the chassis.
As I need to put the internal framework & floor pans on top of the Spitfire chassis.
Then the hand brake panel should sit on top of that ( touch wood).
Take Cover...
I will have to focus on some domestic matters for the next 2 weeks.
So this morning was a race against the rain promised this afternoon to "tidy up".
I put the rear wheel arches and the rear internal framework together...
Then I had to drag a pile of stuff from the front drive, through the house, into the back garden.
Front Drive - Before:
Front Drive - After:
This pile includes the front bulkhead frame & various other pits & pieces...
And another job done...
Apart from tidying up the front drive, there was another reason to move this parts.
The next big job for me will be to finally fit the rear suspension lowering block.
And in order to do that, I will need space to the side to pull the leaf spring out.
With a bit of luck & a fair wind, I will start on that the first week in September.
Until then, take care, Paul.
17th August 2013, 14:48
Hi Paul,
I haven't figured out yet what the problems are with the hand braking. I really don't get the arguments. The cable runs to a fixed position on the chassis. (these slot bends). I don't understand why placing the handbrake/pull mechanism a little different would make braking any better or worse. You have to adjust the cable between the two brakes with suitable tension and the pull cable. I see no problem there.
And then you have the argument of lowering the suspension. I don't get that either. The slot bends are practically at the same place as the U-joints of the shafts. So if there is wheel travel, the cable should travel with the shaft having the same pivot point (approx).
Apperently it's not a very good design in the first place, maybe that is the trouble. I can see 1 catch however that could be looked over. I think you have to adjust the lever that converts the movement of the pull cable to the movement of the cable between the brakes. Firstly you can adjust the points where the cables meet the lever. And then you have to find the correct angle of the lever (which is the ballance between adjusting the pull cable and the cable between the drums). It's a sinus effect. When the lever is 90 degrees with the car, all pulling movement, will be translated in the "right" direction. But if the ever is more in line withe the car, you loose efficiency (the "slot bracket" pulling the drum cable is also moved to side, which is not going to help you braking) . I beleive you have to adjust the leverarm to 15 degrees "BTC". That way you get maximum efficiency when the lever is turning 30 degrees when pulled.
Michiel
17th August 2013, 15:51
The issue with the Herald/Vitesse handbrake mechanism is that the swing axle arrangement means that the levers on the rear brake cylinders that the brake cable running through the compensator (that 'U' shaped thing) attaches to move closer together or further apart depending on where the suspension is in its travel.
With the tension set correctly with the car at a standstill, if you take the weight off the back end, as if you were going over a hump back bridge, the tops of the wheels move further apart and pull the handbrake on. This hasn't been a problem on the road for me (so far), and I just explained the dynamics of it to the MOT chappy when he noticed that the rear wheels locked up when he jacked the back up.
I moved my curved guide tubes up onto extensions I welded onto the frame so that the cable wasn't sitting at an angle that was bound to lead to fraying and failure, and so far so good...
Hope that all makes sense
17th August 2013, 18:50
I don't have the guides on my Mk2...
18th August 2013, 06:00
Replies / Possible Crossed Wires?
I appear to be causing some confusion with my descriptions (again ).
I have no intention on re-inventing the hand brake mechanism itself.
The Spitfire hand brake panel will be in the same place as stock (if a little higher horizontally).
That way I can re-use the original hand brake and reconnect the existing cables.
This arrangement was tested by a garage before I removed the body tub and all worked OK.
( Although I will check that fitting a lowering block doesn't cause any problems. )
Hope that makes a bit more sense, Paul.
18th August 2013, 10:09
Hi Paul, MrT,
I have the same thought, I'm not looking for changes to the hand brakes as well.
Thank you Mr T for the explanation, how it works. So, it's a swing spring thing!
I wouldn't like it if the wheels are braking when you ride over a bump. But apparently it is not a issue in practice. That's good. We can proceed with convidence then
michiel
4th September 2013, 18:26
Quick Update:
I've not been able to work on the car recently as we went on a family holiday to Florida.
This is all part of leaving my job and getting a better balance between work & home.
We were staying in Orlando and did the usual theme and water park things which were great.
I also use the power of the internet to arrange a visit to see my dream kit car in the flesh.
I'd previously joined a US kit car forum as part of my research into building one of these...
One of the forum members who lived near where we were staying invited me to his garage.
It was great to chat with him and compare kit car building notes as this is a very high end kit.
The lesson's I've learnt from this build mean that I would love to build one of these cars one day.
However, that day is a long way off, as I would only consider it when I had a garage to work in.
I also know that I'd need a lot more time on my hands too (i.e. when my children have left home!).
We also picked up a couple of ideas for paint...
My daughters thought this pink Mustang was "cute":
Where as, deep down, I was drawn to the flames:
Hopefully I will be able to get back to my own car in the next few days.
4th September 2013, 18:55
Looks like you have had a great time in America. Nice pictures of cars..
I am leaving to go to Las Vagas on Saturday. I other half has rented me a Dodge viper for the two weeks . Should be a good time, i realy need a break
4th September 2013, 19:38
2 weeks in Vegas or are you starting from here?
Just returned from a month in California and took in Vegas and got married whilst I was there...elvis etc ha ha it was great
5th September 2013, 07:06
Starting in*Las*vagas*, and stopping several times working right down to * *san*Fransisco. We are also getting married in Vagas, the valley of fire..
5th September 2013, 11:19
5th September 2013, 12:44
Never been into Detroit Iron myself, but I love all of those!
Could make real use of the last one at work
5th September 2013, 16:52
Cool ....sounds like a blast ....congratulations on the forthcoming wedding
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
