30th June 2015, 08:06
That is looking great! I went to the Tribute premesis last week, saw the two being built and have decided I will be doing a SWB ! Will be using mine for sprint / hill climb competition so working out a few details, currently thinking of using a Z3. 3.0 as a base, and hopefully at the end when finished supercharging it. Going to sell my bike engined car to make room first.
1st July 2015, 22:20
Nice build looks like the rear adjusters need to be removed. Are you planning to stay with black? Looks good. I would like a like kit next year. Jeff
5th July 2015, 20:46
exhaust sorted
thought I would have a pop at the exhaust while I am killing time waiting on the window frames and grill to arrive. I had a back box off a Audi avant kicking around with some good bends on little bit chopping a grinding and this is what I come up with.
tail pipes are way to small ebay clanger they did look a lot bigger but they were ok for the mock up. the audi has a wicked tail pipe so I may need to find a other to match it.
my spinners came this week 50quid with delivery off ebay bargain of the month.
jeff for now I want to run it rat look in black but it will be in silver if not before Christmas just after. andy
5th July 2015, 21:02
Andy, i think i bought the same tail pipes off ebay! And they did look a lot a lot bigger on the advert!
5th July 2015, 21:07
lol, the Audi one is spot on but it means buying a box just to cut off the tail pipe. I feel a visit to a scrap yard coming on
12th July 2015, 19:28
D seemed
spent the weekend rubbing out joint lines from the moulding bit of before and after for you.
The plan never was to get it perfect but at first glance it is passable for now. as you can see form the pics I had to do some filling I did try to cut it back but the step was to big and I went through the gel coat and some.
The pictures make it look better than it is but experience has tort me to get it passable then let the experts do a proper job when I get it painted.
The boot latch handle has gone in favour of the original bmw latch on a boot pull off a mx5. I like the smooth look of the rear, I moved the handle twice then just took it off a filled in the holes .
12th July 2015, 21:50
Originally Posted by andysharrock
...The pictures make it look better than it is
but it is looking good.
Oh the beauty of GRP bodies- just keep the filler as thin as possible so it won't shrink in future.
14th July 2015, 19:53
must be old age or just the fact that I now try to do it right well most of the time , I glassed it over first then used a bit of good old gobo to smooth it out
19th July 2015, 20:24
Your car is looking brilliant Andy, the stance and wheels are spot on.
Really sorry for the delay on side windows and grille, I have been let down by suppliers of glass and grille slats as you know, but they will be finished this week and making their way to you via courier. Keep up the great progress..
1st August 2015, 17:24
quick update
I have just been in for an opp so the cars not had a lot dune but sitting around is driving me mad as the windows and grills come time to have a pop just slow.
I recessed the rear of the door handles to make them look like they belong on the car.
fitted the side widows door skins are now bonded on and the grill and side repeaters are now on .
roof lining fitted ive run it all the way down so it matches in the back when you look through the window
the original internal door panel has been reworked so it will fit with the new lower window frames
just waiting on the good old DVLA to pull there finger out so we can get it back on the road and start looking for a show or two.
9th August 2015, 17:31
few more bits sorted
problem with waiting for the dvla to get the paper work sorted is I am already changing things on the car and its never been off the bloody drive. lol
so this weekend made a boot stay to hold it up its hit me on the head to many times, fitted fog and reverse light flush mounted
eBay item number:23161552530 so they dont look to stand out.
fitted door rubbers eBay item number:121432862268 good stuff for a change also cut out all the vents and fitted this stuff eBay item number:251831841139 good stiff mesh not the fly screen stuff. gone a bit old school and added the AA badge on the grill and I must admit I nicked the road runner badge idea from Garry aka NED but I could not resist it.
10th August 2015, 00:07
You've added some nice detail there, which will make such as difference to the finished car. I particularly like the sunken reversing and fog lamps.
26th August 2015, 17:05
finally got a V5 so we are good to go
well today I got the go from the DVLA the car is now fully road legal as a kit car. I could not call it a Italia 250 swb because that was the next speck up from my car so its a BMW tribute 250. I have waited that long and filled out that many bits of paper.I would have called it a bloody vesper if they were happy to register it.
test drive was sort of ok until I worked out one of the wire wheels is slightly buckled above 30 its ok under its got a clunk so back on ebay we go
26th August 2015, 17:44
just (maybe) a small point - the 'tripods' on the headlights look to be in different positions........ are the beams set correctly, or do they need rotating some?
26th August 2015, 19:35
Andy, don't clergymen wear vesper?
26th August 2015, 21:20
My first road going mobile was a vespa pk50 at the the age of 16! My dad was a mod so thats what i got. Now im older and ive moved on to the lambretta's (i think for more style however they are a lot more un-reliable)
Mines the stage 5 tuned racer on the right lambretta gp225. The other 2 classics are my dads. 1 vespa special and 1 mk1 li lambretta
26th August 2015, 21:58
Is that a frame breather in the middle
I used to have street racer bitza...drop bars ,rearsets ,190 tuned engine big dellorto,Kegra race pipe etc etc
26th August 2015, 22:27
Wot, only 3 between you?
Anyone remember the Wal Phillips "fuel injectors" ?
27th August 2015, 12:37
liking the roadrunner badge!!
