Show us your Kit Cars You've just taken 2 years to build your pride and joy, right? Then why not show it off here. Let us see your creations. |
11th March 2010, 18:41
Right, no more leaks (I hope) it starts, ticks over when warm and bedded the cams in with little problems. Early indications are pretty quick pickup but the gear selector decided it doesn't like reversing at the moment so can't really take it on the road yet
11th March 2010, 18:50
Have you had you box rebuilt by any chance?
I had the same issue after rebuilding mine. Simple fix once the box is apart if I remember correctly.
11th March 2010, 19:09
Nope, i swapped over to an mgf gear change so hopefully it's just an adjustment of one of the cables. Couldn't do any more on the car today (back playing up again) so might be able to do it tomorrow
14th March 2010, 20:23
Sorted, the linkage was fouling a bolt so ground down area required.
Just did 20 miles and OMFG it's quick!!! Even with no boost!
15th March 2010, 05:21
He does take a while to become one with the car again. No boost helps get used to the car again.
But once mapped and boost turned up, it will be totally differnt again and will need to learn to drive it all over again!
15th March 2010, 09:26
Considering I set it up by eye it handled really well to!
Got a long list of things to sort now after it's first shakedown and I've downloaded the ecu log to analyze. There's an oil leak somewhere and one of the driveshaft rubbers has perished, but overall a very sucessful test session
18th May 2010, 07:37
Turned up to 1bar now 150 miles of pure unashamed massive grin from ear to ear with a few scary bits thrown in!
I still can't believe it's so quick, the speedo looks like a rev counter it moves so quickly!
Once up to 300 miles i'll put the propper oil in and send it over to get mapped. It's not actually too far off already, just running a little on the rich side and i'm sure there's more ignition adavnce to be had, plus i can't quite get the idle right
18th May 2010, 16:20
It nice when the power's turned up. :-)
All be it a bit nervy and a shock to the system.
18th May 2010, 16:53
just hit 280 miles, so the running in is virtually complete, few little niggles still but it's been running all day without any problems at all! got the thing idling just about now so it's a bit easier to drive.
Done a little setup work, tyre pressures at 20psi front and 36psi rear, 5 clicks on the front and 12 on the rear shocks and it feels a lot more stable coming off power now
Time to change all the fluids...
27th May 2010, 17:44
36psi???
I run 17 psi in the 5exi.
ECU wiring looks very neat.
27th May 2010, 17:58
Not sure what tyres you are running but I am using 205/50/15 Toyo T1-R's on the back, you need the extra pressure to stop the sidewalls from falling over in the corners and it takes the squirm out when you throttle off, they don't look over inflated.
If you look at most mid engined cars, the tyre pressure is significantly higher on the rear and should be a reinforced multiply sidewall, unfortunately I ordered the reinforced tyre but only got a single ply one so I will just have to wear them out soon Snetterton next month....
17 sounds right for the front but way low for the rear.
Thanks re the wiring everything worked on first power up too! it's the original loom I'm having problems with atm!
27th May 2010, 21:47
195/50/15 Toyo T1-S and Toyo 888. Toyo recommend 17-20psi for a sub 800kg car. My 1500kg daily driver runs 35psi in the fronts, with a (for arguments sake) 60/40 weight split (so 450 kg per front tyre), thus 36 in a relatively light car seems seriously high. If it works, fair enough, but it seems theoretically quite some way from optimal.
I don't have any problem with excessive sidewall deflection with 17psi - it was one of the first things I checked when reviewing cornering shots.
13th July 2010, 05:23
A bit rough and ready at the moment as I need to get the mic positions sorted but here's a taster
Last time I tried to embed a video it messed up so see the link below
http://www.vimeo.com/13283903
